pimpmaul69 #251 Posted January 24, 2015 Joymap is for the 5200. i just put in everything i didnt have but i get permission denied trying to run the coleco Quote Share this post Link to post Share on other sites
mthompson #252 Posted January 24, 2015 i just put in everything i didnt have but i get permission denied trying to run the coleco Maybe try adding "sudo" at the beginning of the run command. I had to do that to get the Apple II emulator to launch. Quote Share this post Link to post Share on other sites
pimpmaul69 #253 Posted January 24, 2015 Maybe try adding "sudo" at the beginning of the run command. I had to do that to get the Apple II emulator to launch. i will try that. Quote Share this post Link to post Share on other sites
BBWW #254 Posted January 24, 2015 So awesome! Time to by another Pi! To be clear on what I am delivering. I am making all my setting available where you can just copy them. A requirement is the Ultimate Interface as that I the interface I used to configure everything. Also, I used the Intellivision controller. A Coleco controller will work but I use the bottom right side button to exit the Colecovision emulator. If you use a Coleco controller, you will not have a controller option to exit the emulator. You will have to use a keyboard. For 2600 games, either the Coleco or Inty controller should be fine. For the 5200, the right controller is needed to set the configuration of the game. Quirky? Yes but it all works by just copying over everything and loading up your roms. Quote Share this post Link to post Share on other sites
pimpmaul69 #255 Posted January 24, 2015 Maybe try adding "sudo" at the beginning of the run command. I had to do that to get the Apple II emulator to launch. did it now all it does is go to a black screen then go back to the game menu. After that anything i do will cause it to get stuck on a black screen. I have to reboot to do anything else other than ftp'ing Quote Share this post Link to post Share on other sites
intvdave #256 Posted January 24, 2015 Try running it at the command line. Did you fix the gamelist error? Quote Share this post Link to post Share on other sites
intvdave #257 Posted January 24, 2015 Odyssey 2 and Atari 7800 would be nice :-) For the O2, this may be of some help; I just havent gotten around to seeing if I could do this myself: http://www.raspberrypi.org/forums/viewtopic.php?f=78&t=86888 I have the Odyssey2 emulator running. Now to configure the joystick, create the theme, and add it to Retropie. 2 Quote Share this post Link to post Share on other sites
pimpmaul69 #258 Posted January 24, 2015 Try running it at the command line. Did you fix the gamelist error?i have no idea why i get the gamelist error. I get it on other emus that work too. Is there a place i am supposed to put the coleco bios? Quote Share this post Link to post Share on other sites
Rick Reynolds #259 Posted January 24, 2015 I have the Odyssey2 emulator running. Now to configure the joystick, create the theme, and add it to Retropie. David, you're once again turning into my hero! I've got to get this project rolling (on my end) so I can get your latest-and-greatest once it's available! Quote Share this post Link to post Share on other sites
intvdave #260 Posted January 24, 2015 (edited) David, you're once again turning into my hero! I've got to get this project rolling (on my end) so I can get your latest-and-greatest once it's available! Ok...please do not drag copyright questions into this please. I have completed the theme and configuring the controller. I will be updating the package and webpage. I have frogger and tuntankham working but other roms I tried did not work. I do not know what game uses the side button so this probably is not configured correctly. I need help from those of you that actually own the games (this is where your rights issues come in) and can tell me which one uses the side button. Edited January 24, 2015 by intvdave Quote Share this post Link to post Share on other sites
pimpmaul69 #261 Posted January 24, 2015 (edited) Ok...please do not drag copyright questions into this please. I have completed the theme and configuring the controller. I will be updating the package and webpage. I have frogger and tuntankham working but other roms I tried did not work. I do not know what game uses the side button so this probably is not configured correctly. I need help from those of you that actually own the games (this is where your rights issues come in) and can tell me which one uses the side button. some games use right controller. Some games use the left controller. You have to play odyssey 2 with 2 controllers. Plus you have to have a keyboard hooked up too. The keyboard has a button you have to start a lot of games with. Edited January 24, 2015 by pimpmaul69 Quote Share this post Link to post Share on other sites
Rev #262 Posted January 25, 2015 Soon, I'll get a Pi. But I have NO clue how to set up. But I must say thanks to everyone for the great info, and David of course. Ive been mostly following this thread from the beginning. :-) Pimpmaul has offered to set me up! One question, maybe I missed it. But, with all the various controllers, how do you cconnect them all? I know about the intv/atari adapters.....but what about nes? 1 Quote Share this post Link to post Share on other sites
pimpmaul69 #263 Posted January 25, 2015 Soon, I'll get a Pi. But I have NO clue how to set up. But I must say thanks to everyone for the great info, and David of course. Ive been mostly following this thread from the beginning. :-) Pimpmaul has offered to set me up! One question, maybe I missed it. But, with all the various controllers, how do you cconnect them all? I know about the intv/atari adapters.....but what about nes? the way i did for the nes controller is remove the ic chip and cable and use a genesis controller cable and wire it to function with the same controls as a colecovision flashback controller. I will wire up a genesis, super nintendo, turbografx 16 and sega master system controller the same way. Atari controllers dont need to be modified. Quote Share this post Link to post Share on other sites
intvdave #264 Posted January 25, 2015 Or maybe just use the Intellivision controller for all the emulators? Quote Share this post Link to post Share on other sites
pimpmaul69 #265 Posted January 25, 2015 Or maybe just use the Intellivision controller for all the emulators?i find the disc way too sensitive for systems not designed to use them. Plus i am always about the authentic controller feel. Hence why i have 20+ retro controllers setup to work on my wii. The odessey 2 emulator on the wii isnt designed where i can use a modified controller so it will be nice to use an odessey 2 joystick when i play. Quote Share this post Link to post Share on other sites
intvdave #266 Posted January 25, 2015 Odyssey 2 and Atari 7800 would be nice :-) Is there a linux/unix 7800 emulator? I am only seeing Windows versions. Quote Share this post Link to post Share on other sites
intvdave #267 Posted January 25, 2015 That's a great list. I'm new to the Raspberry Pi (just arrived yesterday and haven't tried it yet), but what other systems are emulated on it? I wanted to do the above, but also mame, c64, atari 8bit, and amiga. -mike The problem with Mame is finding the game sets that actually work on the version of Mame. What other Atari 8 bit systems are there? Lynx? I thought I had the major 2 with the 2600 and 5200. The 780 had a short life not that the 5200 was popular either but it is essentially the 800. The C64 and Amiga are computers to me. Just play these on the PC? Quote Share this post Link to post Share on other sites
pimpmaul69 #268 Posted January 25, 2015 The problem with Mame is finding the game sets that actually work on the version of Mame. What other Atari 8 bit systems are there? Lynx? I thought I had the major 2 with the 2600 and 5200. The 780 had a short life not that the 5200 was popular either but it is essentially the 800. The C64 and Amiga are computers to me. Just play these on the PC? i would rather have the 7800 than the 5200. I never knew anyone that had a 5200 Quote Share this post Link to post Share on other sites
intvdave #269 Posted January 25, 2015 i would rather have the 7800 than the 5200. I never knew anyone that had a 5200 Find me a 7800 linux emulator and I will try to get it working. The 5200 rocked! Shame you did not know anyone that had one or have one yourself. Quote Share this post Link to post Share on other sites
intvdave #270 Posted January 25, 2015 i find the disc way too sensitive for systems not designed to use them. Plus i am always about the authentic controller feel. Hence why i have 20+ retro controllers setup to work on my wii. The odessey 2 emulator on the wii isnt designed where i can use a modified controller so it will be nice to use an odessey 2 joystick when i play. I doubt most people will do what you did and have 20+ different controllers that work on one console (wii). 1 Quote Share this post Link to post Share on other sites
pimpmaul69 #271 Posted January 25, 2015 I doubt most people will do what you did and have 20+ different controllers that work on one console (wii). that is true. For me it is about the retro experience without a bunch of systems that take up a lot of space that i dont have room for in this tiny room i live in. So i keep everything in storage and play this way. Quote Share this post Link to post Share on other sites
+freewheel #272 Posted January 25, 2015 i have 20+ retro controllers setup to work on my wii. I won't lie, I haven't read all 11 pages here, so apologies if I've missed it - how did you hook up 20+ controllers to the Wii? Do you hardwire into Wiimotes or Gamecube controllers? Quote Share this post Link to post Share on other sites
+iesposta #273 Posted January 25, 2015 Is there a linux/unix 7800 emulator? I am only seeing Windows versions. What about those Linux handhelds? Here is source for gp2x. http://zx81.zx81.free.fr/serendipity/index.php?/categories/44-Atari-7800 I have it on PSP, and GCW-Zero. Quote Share this post Link to post Share on other sites
intvdave #274 Posted January 25, 2015 What about those Linux handhelds? Here is source for gp2x. http://zx81.zx81.free.fr/serendipity/index.php?/categories/44-Atari-7800 I have it on PSP, and GCW-Zero. What is the operating system for the GP2X? Is it linux based? Quote Share this post Link to post Share on other sites
+iesposta #275 Posted January 25, 2015 What is the operating system for the GP2X? Is it linux based? I don't know the operating system for GP2X. It is Linux based. The GCW Zero I have is Open Dingux based. Quote Share this post Link to post Share on other sites
