mickcris Posted October 24, 2015 Author Share Posted October 24, 2015 bump Quote Link to comment Share on other sites More sharing options...
mickcris Posted December 16, 2015 Author Share Posted December 16, 2015 bump Quote Link to comment Share on other sites More sharing options...
mickcris Posted December 20, 2015 Author Share Posted December 20, 2015 bump. added rgb modded duo-r Quote Link to comment Share on other sites More sharing options...
mickcris Posted January 10, 2016 Author Share Posted January 10, 2016 bump Quote Link to comment Share on other sites More sharing options...
mickcris Posted January 24, 2016 Author Share Posted January 24, 2016 bump. added a few systems Quote Link to comment Share on other sites More sharing options...
mickcris Posted February 4, 2016 Author Share Posted February 4, 2016 bump Quote Link to comment Share on other sites More sharing options...
+chicgamer Posted February 6, 2016 Share Posted February 6, 2016 Sent you a PM about the RGB-modded Core Grafx. Quote Link to comment Share on other sites More sharing options...
+chicgamer Posted February 10, 2016 Share Posted February 10, 2016 Received the Core Grafx today. Absolutely thrilled with it! Quote Link to comment Share on other sites More sharing options...
XC-3730C Posted February 10, 2016 Share Posted February 10, 2016 @chicgamer, What display are you using? Got any screen shots? PC Engine is awesome in RGB! Sent from my SAMSUNG-SM-N910A using Tapatalk Quote Link to comment Share on other sites More sharing options...
+chicgamer Posted February 10, 2016 Share Posted February 10, 2016 I have it hooked up to a 40" HDTV via a SCART to HDMI converter. I actually was thinking of capturing some video from it tonight. So happy! Quote Link to comment Share on other sites More sharing options...
XC-3730C Posted February 10, 2016 Share Posted February 10, 2016 I would like to see some screens shots using your setup when you can. I have a Sony PVM-2530, and XC-3730C (both CRT), so I am curious to see the quality on an HDTV. I take it there are no scanlines? Sent from my SAMSUNG-SM-N910A using Tapatalk Quote Link to comment Share on other sites More sharing options...
mickcris Posted February 10, 2016 Author Share Posted February 10, 2016 Received the Core Grafx today. Absolutely thrilled with it! glad you are happy with it. Quote Link to comment Share on other sites More sharing options...
Coreyk78 Posted February 25, 2016 Share Posted February 25, 2016 Sent a PM about a Ten No Koe 2, thanks Quote Link to comment Share on other sites More sharing options...
Coreyk78 Posted March 1, 2016 Share Posted March 1, 2016 I got the Ten No Koe, wanted to let you know it works great and my white PC Engine looks fantastic on my BVM monitor, crisp image and no jail bars that I can see. Thanks a lot! 1 Quote Link to comment Share on other sites More sharing options...
mjsaville Posted March 5, 2016 Share Posted March 5, 2016 Hi MickCris, I'm looking for an amp + connector for a Core Grafx 2, shipped to the UK? Do you still have stock? Quote Link to comment Share on other sites More sharing options...
mickcris Posted March 5, 2016 Author Share Posted March 5, 2016 Hi MickCris, I'm looking for an amp + connector for a Core Grafx 2, shipped to the UK? Do you still have stock? sending you a pm. but yes, i do have plenty of stock. Quote Link to comment Share on other sites More sharing options...
Chris Leach Posted March 6, 2016 Share Posted March 6, 2016 Pmt. sent twice. Lol. Can't wait to get the goods. Quote Link to comment Share on other sites More sharing options...
Duster256 Posted March 8, 2016 Share Posted March 8, 2016 Sent a pm too, very excited Quote Link to comment Share on other sites More sharing options...
mickcris Posted March 26, 2016 Author Share Posted March 26, 2016 bump. new console added Quote Link to comment Share on other sites More sharing options...
mickcris Posted April 7, 2016 Author Share Posted April 7, 2016 i have started the process of updating the amp board to viletim's suggested resistance at the output. Will look the same as the previous version, but will be more correct. The old design was not hurting anything, but might as well make it better. Here is viletim's explanation:http://nfggames.com/forum2/index.php?topic=4822.msg34061#msg34061"Unfortunately the RGB signal the PC Engine is not 0.7 Vpp, it's actually 0.8 Vpp (I know because I bought a PC Engine a few months ago). To compensate for this I suggest attenuating the output slightly. Instead of a 75 ohm resistor in series with the output, you could use 86 ohms in series and 586 ohms to ground. This way it still looks like a 75 ohm output to the outside world. For E24 resistor values try 91 in series and 470 to ground. Not perfect but good enough - 0.67 Vpp is much better than 0.80 Vpp." Quote Link to comment Share on other sites More sharing options...
mickcris Posted April 12, 2016 Author Share Posted April 12, 2016 2 pre amped coregrafx added Quote Link to comment Share on other sites More sharing options...
mickcris Posted May 8, 2016 Author Share Posted May 8, 2016 I got a sample batch of the new pcbs in the other day. Have sent a couple out to get some feedback before I make an order for more boards.they are the same overall size as the old boards Quote Link to comment Share on other sites More sharing options...
mickcris Posted May 15, 2016 Author Share Posted May 15, 2016 OP updated. There are a few new boards available and have the old ones discounted if you dont care about the resistors being soldered to the back (its the same circuit). Quote Link to comment Share on other sites More sharing options...
mickcris Posted May 27, 2016 Author Share Posted May 27, 2016 got my shipment of pcbs in. should have enough that i will never have to order anymore. just need to start on building up some more. I have 5 ready to go. still also have about 10 "fixed" versions available also. Quote Link to comment Share on other sites More sharing options...
futtigue Posted June 22, 2016 Share Posted June 22, 2016 Hello there! Are any boards/din connectors/euro scart cable kits still available? Quote Link to comment Share on other sites More sharing options...
