Franco Catrin Posted April 29, 2015 Share Posted April 29, 2015 (edited) Hi! I'm using DASM and I don't know if I am doing something wrong or this is just a bug on the compiler. I have this code in one .asm file: genAutoMaskTable ldx #0 On other .asm file, I just include the first file and use the names as if they were local jsr genAutoMaskTable When I run DASM, genAutoMaskTable points to GENAUTOMASKTABLE: 0bd1 And the JSR from the main file is right, as you can see: 1C:06 20 D1 0B jsr genAutoMaskTable But.... the code is not there, it is one byte after the calculated address D2:0B A2 00 ldx #0 Any ideas? Edited April 29, 2015 by Franco Catrin Quote Link to comment Share on other sites More sharing options...
JamesD Posted April 29, 2015 Share Posted April 29, 2015 (edited) I'm not familiar with DASM so I don't know how much help I can be but I'll give it a shot. So you are getting the symbol table from the first file but not the code.How did you include or link to the first file? Edited April 29, 2015 by JamesD Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 29, 2015 Share Posted April 29, 2015 I'd give Dasm, AtAsm, most others a big miss. I wasn't aware of such problems in Dasm but do know there were some nasty bugs in older releases of AtAsm that'd give similar results to what you have. Probably best off using MADS - the syntax can take some getting used to but it's the premier assembler package for doing projects for the 8-bit computer. 1 Quote Link to comment Share on other sites More sharing options...
danwinslow Posted April 29, 2015 Share Posted April 29, 2015 Or ca65.... Quote Link to comment Share on other sites More sharing options...
+JAC! Posted April 29, 2015 Share Posted April 29, 2015 (edited) The SF version of DASM had the wrong binary for quite a long time. Just some days ago the correct build with a lot of fixes was released. You should make sure you have that version. See http://www.wudsn.com/index.php/126-compilers-download-update And many more improvements are coming https://sourceforge.net/p/dasm-dillon/activity?page=0&limit=100#553bd2ea2718464513c7dd08 Edited April 29, 2015 by JAC! 3 Quote Link to comment Share on other sites More sharing options...
Franco Catrin Posted April 30, 2015 Author Share Posted April 30, 2015 I was wrong... I was using ATASM!! Today I got to dig into it and finally found the bug. I wrote a sample code and reported to the ATASM guys: https://sourceforge.net/p/atasm/bugs/7/ 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 1, 2015 Share Posted May 1, 2015 I had similar problems with earlier builds of AtAsm... destinations would sometimes be one off. Updating to the latest version fixed it. Can't say I've had problems since, though I started doing new stuff with MADS a couple of years ago. My advice - if you have older versions of AtAsm, get rid of them. Use a modern build otherwise it's asking for problems. Also noticed in your bug report re addressing. I don't think there's a way of forcing one or the other type as with some assemblers, e.g. on the 2600 it's often desirable to force absolute to give an extra cycle delay, e.g. lda.w $40 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 1, 2015 Share Posted May 1, 2015 I also recall encountering the same issue but understood it to be fixed in a later version. I switched to MADS partly because of Atasm's funky reordering of code segments (although it's possible to force the order you want using directives). Quote Link to comment Share on other sites More sharing options...
+JAC! Posted May 1, 2015 Share Posted May 1, 2015 (edited) Just verfied the bug is also there in the lasted build (V1.08-trunk100), which will released once I got it to compile as 32-bit WIN. Yet the problem can be solved be re-ordering the code to help the parser a little: * = $600 lda levelMap+1,x lda levelData rts levelData .byte 0 levelMap = levelData + $1000 yields the correct output. Edited May 1, 2015 by JAC! 1 Quote Link to comment Share on other sites More sharing options...
