bugbiter
can a program disable basic by its own?
I'm tired of pressing option to boot without basic. Why can't a program do that for itself when starting?
I just added
lda #243
sta portb
as the first statements in a XEX's init block. That should disable basic, keep OS ROM and normal RAM bank for subsequent main program load. Init code block is $3E00-$3FED.
Under SpartaDOS 3.3 I get some strange behaviour - black screen and infinite key click sound.
I'm not in the mood for intense debugging so I just ask you guys..Whats wrong with my idea?
Well,
i am not a programmer, so I have no idea. But, errm, Bill Wilkinson was one of the authors of Atari Basic and also author of the book "Inside Atari Basic" - and he released a short utility in Compute! magazine, named "BASOFF.COM".
This utility has a length of only 57 bytes, it uses page 4 to switch off Atari Basic, right after that page 4 is available again... (maybe you want to disassemble this utility and see what it does or just use it)...
BASOFF.XEX
Edited by CharlieChaplin
I am pretty sure you want to do a
lda portb
and %11111101
sta portb
This leaves PORTB intact, and only turns off bit 1 (BASIC enable).
Bit 1 is a BASIC disable bit, so:
	lda #1
	sta $03F8 ; basicf
	lda $D301
	ora #$02
	sta $D301
	lda #$C0
	sta $6A ; ramtop
Setting BASICF and RAMTOP avoids any nasties.
You'd also have to reopen E: as BASOFF.XEX does to actually relocate screen memory upward.... but yes, it's nicer for programs to auto-disable BASIC instead of requiring users to do it manually.
Here's the disassembly. I can't quite understand the need to open E: in mode 12, then set RAMTOP, then open E: again in mode 3.
            org $0400
L0400:      lda PORTB
            ora #$02
            sta PORTB
            lda #$01
            sta BASICF
            lda #$0C
            jsr OpenE
            lda #$C0
            sta RAMTOP
            lda #$03
OpenE:      sta IOCB0+ICCOM
            lda #<Name
            sta IOCB0+ICBAL
            lda #>Name
            sta IOCB0+ICBAH
            ldx #$00
            jmp CIOV
            .byte $00
            org $02E2
            .word L0400
I've updated the corresponding section in the Atari 8-bit Programming Tips and Recommendations
http://www.wudsn.com/index.php/productions-atari800/tutorials/tips
EDIT: hehe, concurrent post. My version uses a bit shorter code for E: and only re-opens it, if RAMTOP was not yet correct.
This way it does not flicker if somebody already did press OPTION before.
Edited by JAC!
            org $0400
L0400:      lda PORTB
            ora #$02
            sta PORTB
            lda #$01
            sta BASICF
            lda #$0C
            jsr OpenE
            lda #$C0
            sta RAMTOP
            lda #$03
            lda #<Name
            sta IOCB0+ICBAL
            lda #>Name
            sta IOCB0+ICBAH
            ldx #$00
            jmp CIOV
            .byte $00
            org $02E2
            .word L0400
It doesn't open the editor twice. The first call to "OpenE" passes the CIO close channel code in the accumulator, so it's a close/open sequence.
Thanks, I didn't know 12 $0C was close. I looked through the CIO stuff in Mapping, and must have missed it. :)
I found it deep in the IOCB section.
For the ICCOM field, the following values apply (BASIC XIO
     commands use the same values):
     Command                       Decimal   Hex
     Open channel                      3       3
     Get text record (line)            5       5   BASIC:
                                                   INPUT
                                                   #n,A
     Get binary record (buffer)        7       7   BASIC:
                                                   GET #n,A
     Put text record (line)            9       9
     Put binary record (buffer)       11       B   BASIC:
                                                   PUT #n,A
     Close                            12       C
     Dynamic (channel) status         13       D
Hmm.. it's not working right. The init code block turns basic off all right, but after the main program is loaded, Basic is back on.
It seems SpartaDos turns it back on during continued loading. It's using RAM under the OS, right? So it sure meddles with portB..
I simply switch off Basic again in the main program, that's done the trick..
Little off-topic...
I am still not 100% sure if Mad Pascal disables BASIC on program run or not. I checked the programs which use memory addresses beyond $A000 for storage data, but all of them work in text mode 0 with no additional call to InitGraph (I still have to test those examples on real hardware). I experimented with other modes by calling InitGraph procedure, which consequently blocked the usage of this area (I couldn't store values there anymore).
Possibly it does dynamic storage allocation for stuff like stacks and arrays?
Fair chance it doesn't play with the Basic switching, especially if it came out before 1984.
You could probably work it out if you had a compiled program then try it in various configurations in emulation.
On the XL operating system and Os++, this is normal if you run through a reset. The state of the basic switch is stored in address $3f8. The byte at this address shall be non-zero to enforce that the Basic ROM stays disabled after going through the reset vector.
On a second matter, it is in general not sufficient to switch basic off just before the binary starts. You need to turn it off before the binary loads. That is, you need to prepend a small code to the actual that is run through the init-vector of the dos loader, which turns basic off both through PIA Port B, through the BasicDisabled flag at $3f8, then adjusts memtop, then re-opens the editor, then continues loading.
This is because a binary may well use addresses above $a000 to load to, and this would fail if Basic would be still on during loading.
Hi,
    won't RAMTOP be wrong on a 16K 600XL? Am asking in context of a boot disk rather than XEX, though I think this would also apply to code after $2000.
3 hours ago, E474 said:
Hi,
It would wrong, of course. There would need to be certain logic checking the RAMTOP and adjusting it.
On the other hand, software that really needs RAM below BASIC wouldn't work on a computer with less than 48 KB RAM anyway.
Thanks for info! I was not aware of the flag at $3f8.
If the program knows that the machine won't reboot then it can be easier to just set the flag at $3F8 and call a warmstart $E474 - then the OS takes care of the memory management and proper E: stuff.
There is also one thing specific to the CC65 and its ATARI target and runtime library.
It is, to my surprise, using MEMTOP to position its C runtime stack, though it is documented. So, for this specific situation, adjusting MEMTOP is also needed, even though it is a vector used by BASIC.
I didn't do it in the TRAIN 2 game and its loading screen gets a little glitch (P letter appears briefly on screen). Apart from the glitch, there is no other damage, fortunately.
A circumvention is to boot with the OPTION key pressed.
Edited by baktra
MEMTOP is maintained by the OS and will be set when E: or S: is OPENed, pointing to the byte before the start of the Display List.
APPMHI ($E,$F) is the pointer that applications, languages and programs should use to tell the OS the highest address it should not use - a screen open that violates it will fail.
The 800 OS has a bug where if you set it above where the default Gr. 0 DList would appear then do a warmstart, the machine will become unrecoverable since E: can't open so no input is possible.
The XL OS has a check for this condition and will adjust APPMHI to allow E: to function normally if an open fails on warmstart.
A common mistake some people make is adjusting RAMTOP based on it's "current" value which can cause Basic programs to have memory creep issues.
The proper way is to use RAMSIZ ($2E4) as the reference to the actual top of RAM then adjust RAMTOP from that value.
Thanks. I didn't know. In my program, I do not re-open the E: device (I just close it as I don't use it later).
Here is Mad Pascal code which writes two consequent bytes to $A000 area even if BASIC is still ON. It does use code from JAC!'s page. I only removed program starting address setting and error trapping in case $A000 cannot be written to. Program runs in graphics mode 12 and shows results in text area (reading default values and then writing new values).
program testmem;
uses
  graph, crt;
const
  ram = $a000;
var
  mem : array [0..0] of byte;
begin
  asm {
       LDA #$c0 ;Check if RAMTOP is already OK
       CMP $6a ;This prevent flickering if BASIC is already off
       BEQ RAMOK
       STA $6a ;Set RAMTOP to end of BASIC
       STA $2E4 ;Set RAMSIZ also
       LDA $d301 ;Disable BASIC bit in PORTB for MMU
       ORA #$02
       STA $d301
       LDA #$01 ;Set BASICF for OS, so BASIC remains OFF after RESET
       STA $3f8
       LDX #2 ;Close "E:" before re-openining it again
       JSR EDITOR
       LDX #0 ;Open "E:" to ensure screen is not at $9C00
EDITOR LDA $e401,x ;This prevents garbage when loading up to $bc000
       PHA
       LDA $e400,x
       PHA
RAMOK
  InitGraph(12);
  mem := pointer(ram);
  Writeln('Read  $A000 = ', mem[0], ' $A001 = ', mem[1]);
  mem[0] := 1;
  mem[1] := 2;
  Writeln('Write $A000 = ', mem[0], ' $A001 = ', mem[1]);
  repeat until keypressed;
end.
Too late. Remember, a program may want to load into the $a000 area, thus at the time you run through warmstart, the conflict already happened.
