plbyrd #1 Posted May 13, 2015 I am proud to announce the full availability of the new Disk Image Manager for the Coleco ADAM: ADAMDsk. The project is fully open-source and both source code and Windows executable are available on CodePlex. The documentation for ADAMDsk is located on the Adam Wiki. 5 Quote Share this post Link to post Share on other sites
NIAD #2 Posted May 14, 2015 Congrats on the release of v1.0... will be checking it out shortly. 1 Quote Share this post Link to post Share on other sites
jblenkle #3 Posted May 14, 2015 I get the following error when trying to run it in Windows XP: I am proud to announce the full availability of the new Disk Image Manager for the Coleco ADAM: ADAMDsk. The project is fully open-source and both source code and Windows executable are available on CodePlex. The documentation for ADAMDsk is located on the Adam Wiki. Quote Share this post Link to post Share on other sites
ValkerieSilk #4 Posted May 14, 2015 I am proud to announce the full availability of the new Disk Image Manager for the Coleco ADAM: ADAMDsk. The project is fully open-source and both source code and Windows executable are available on CodePlex. The documentation for ADAMDsk is located on the Adam Wiki. Awesome! Great Job and Thank You! Quote Share this post Link to post Share on other sites
plbyrd #5 Posted May 14, 2015 I get the following error when trying to run it in Windows XP: error.png Unfortunately, Microsoft ended support for .Net on XP at 4.0. ADAMDsk is written for .Net 4.5.1 and takes advantage of lots of new features in C# that are unavailable on XP. Given the fact that it's impossible to get security updates for XP, I would strongly recommend that you move to Windows 7 or 8.1. Quote Share this post Link to post Share on other sites
NIAD #6 Posted May 14, 2015 I get the following error when trying to run it in Windows XP: error.png Looks like you're finally going to have to join the modern era! Quote Share this post Link to post Share on other sites
jblenkle #7 Posted May 14, 2015 That's unfortunate...I have too many programs I use on a regular basis that won't run on anything higher than XP. Unfortunately, Microsoft ended support for .Net on XP at 4.0. ADAMDsk is written for .Net 4.5.1 and takes advantage of lots of new features in C# that are unavailable on XP. Given the fact that it's impossible to get security updates for XP, I would strongly recommend that you move to Windows 7 or 8.1. 1 Quote Share this post Link to post Share on other sites
plbyrd #8 Posted May 14, 2015 That's unfortunate...I have too many programs I use on a regular basis that won't run on anything higher than XP. Why won't they run on 32-bit Windows 7? I can see 64-bit causing an issue, but Windows 7 32-bit with backwards compatibility turned on runs practically everything that XP runs. Quote Share this post Link to post Share on other sites
jblenkle #9 Posted May 14, 2015 Some of the stuff I run probably shouldn't even run on Windows XP (yes, it's that old!!!). Can't afford to upgrade to Windows 7 or upgrade the programs. Why won't they run on 32-bit Windows 7? I can see 64-bit causing an issue, but Windows 7 32-bit with backwards compatibility turned on runs practically everything that XP runs. Quote Share this post Link to post Share on other sites
+digress #10 Posted May 14, 2015 I highly recommend vmware. You can run windows 7 or higher 64 bit or whatever and vmware can run windows xp in a emulation window but effectively. I use all my older software this way. It also a great way to run programs you think might have a virus as the virus could only infect the virtual machine. i use an olde vmware 6 and it works great you don't need the newest version. That's unfortunate...I have too many programs I use on a regular basis that won't run on anything higher than XP. Quote Share this post Link to post Share on other sites
plbyrd #11 Posted May 14, 2015 Windows 7 and 8 also ship with Hyper-V, which is free and Microsoft allows you to run XP for free in a VM (no license needed) on Windows 7 and 8. I highly recommend vmware. You can run windows 7 or higher 64 bit or whatever and vmware can run windows xp in a emulation window but effectively. I use all my older software this way. It also a great way to run programs you think might have a virus as the virus could only infect the virtual machine. i use an olde vmware 6 and it works great you don't need the newest version. Quote Share this post Link to post Share on other sites
plbyrd #12 Posted May 15, 2015 (edited) New version up tonight. This one can create blank disk images. Same URL as before: http://adamdsk.codeplex.com Edited May 15, 2015 by plbyrd Quote Share this post Link to post Share on other sites
jblenkle #13 Posted May 15, 2015 Does your custom disk image maker allow you to make multiple block directories? Because a 1 block directory is limited in how many entries it can hold. On bigger disks this becomes a problem. New version up tonight. This one can create blank disk images. Same URL as before: http://adamdsk.codeplex.com Quote Share this post Link to post Share on other sites
NIAD #14 Posted May 15, 2015 On the Wiki page, it is stated that Multi-block support will eventually be added. Easy enough for now to just INIT the newly created Disk or DDP image with File Manager using ADAMem. BTW... I dread the day that Windows Vista starts showing it's age like XP currently is as I hate Win 7 and 8. Part of the problem is that I have become an old dog that doesn't like to learn new tricks... nor have the time. Quote Share this post Link to post Share on other sites
plbyrd #15 Posted May 15, 2015 On the Wiki page, it is stated that Multi-block support will eventually be added. Easy enough for now to just INIT the newly created Disk or DDP image with File Manager using ADAMem. BTW... I dread the day that Windows Vista starts showing it's age like XP currently is as I hate Win 7 and 8. Part of the problem is that I have become an old dog that doesn't like to learn new tricks... nor have the time. Multi-block directories is next on my hit-list. I basically need to study some images that have multi-block directories and add the support in my image library. Vista may go the way of the dodo, but the underlying functionality that allows it to use .Net 4.5 where XP cannot, is the DNA for Windows 7, 8, and 10. Microsoft says that Windows 10 will be the last major release and that changes will come in a more organic fashion. I suspect that the bones instilled with Vista will always be the basis for Windows in the future. Quote Share this post Link to post Share on other sites
jblenkle #16 Posted May 15, 2015 It pained me when I upgraded to XP...I really liked Windows ME which was the last version my sound card and ADAMem got along with. XP screwed up the sound when using ADAMem. I still run a number of Windows 3.1 programs on my XP machine...barely... Yeah, it's nice to say, "you should upgrade"...but I simply can't afford to replace the software I use heavily let alone invest in a newer version of Windows. My newest piece of software (other than free stuff you can download) is Corel Draw 8 which I believe is about 17 years old. On the Wiki page, it is stated that Multi-block support will eventually be added. Easy enough for now to just INIT the newly created Disk or DDP image with File Manager using ADAMem.BTW... I dread the day that Windows Vista starts showing it's age like XP currently is as I hate Win 7 and 8. Part of the problem is that I have become an old dog that doesn't like to learn new tricks... nor have the time. Quote Share this post Link to post Share on other sites
phattyboombatty #17 Posted March 14, 2016 Bump for regained interest in this development! Any chance for a Mac OS X version? Quote Share this post Link to post Share on other sites
LoTonah #18 Posted March 15, 2016 Bump for regained interest in this development! Any chance for a Mac OS X version? Good question, now that Visual Studio can create OSX apps... is it as simple as a target platform toggle? Quote Share this post Link to post Share on other sites
jblenkle #19 Posted April 9, 2016 Had to load Windows 7 on my son's old computer so my wife could do our taxes using TurboTax. I decided to load ADAMDsk on it, but I am totally not seeing anything that lets you create a Disk Image. There is a tab that says "New Image" but nothing happens when I click on it. This is v1.01. Any ideas? New version up tonight. This one can create blank disk images. Same URL as before: http://adamdsk.codeplex.com Quote Share this post Link to post Share on other sites
plbyrd #20 Posted April 21, 2016 To get the disk creator up and running you need to select a target directory for it in the right panel first, then click the button to create a disk image. Quote Share this post Link to post Share on other sites
FmrAdamuser #21 Posted March 25 Is this still available anywhere? Apparently Codeplex is shutting down and this is no longer available from those links. Thanks, Paul Quote Share this post Link to post Share on other sites
NIAD #22 Posted March 26 8 hours ago, FmrAdamuser said: Is this still available anywhere? Apparently Codeplex is shutting down and this is no longer available from those links. Thanks, Paul AdamDsk is no longer supported by it’s author and Eric Pearson released a much better Windows utility for working with Adam images files called Adam Image Manager. Quote Share this post Link to post Share on other sites
FmrAdamuser #23 Posted March 26 18 hours ago, NIAD said: AdamDsk is no longer supported by it’s author and Eric Pearson released a much better Windows utility for working with Adam images files called Adam Image Manager. Thank you, I did find AIM and it was giving me issues which I why I was searching for an alternate. I finally got it to work, but I had to downgrade to 1.0 instead of using 1.1. Whenever I tried to add a file to an Adam disk image, the app would close itself with no error message and without writing the file. Using v1.0 will write the file and not crash. If there's a newer version than 1.1 (which I found on adamarchive.org), I would appreciate a pointer to it so I can give it a try. Thank you, again, Paul Quote Share this post Link to post Share on other sites
NIAD #24 Posted March 27 The last version that I recall being released by Eric Pearson is v1.1.1.0. I've attached it here for you and others. ADAM Image Manager v1.1.1.0 (2019) (Eric Pearson).zip 1 Quote Share this post Link to post Share on other sites
FmrAdamuser #25 Posted March 27 Thanks, I'll give it a try. Quote Share this post Link to post Share on other sites
