Marc Oberhäuser Posted August 26, 2015 Share Posted August 26, 2015 Hiho, Is there a simple way to get the controller to work in the 5200 mode? XL/XE mode works just fine. Marc. Quote Link to comment Share on other sites More sharing options...
phaeron Posted August 28, 2015 Share Posted August 28, 2015 You need to go to Input > Input Mappings... in the menu and create a new input map for it with a 5200 controller. Map Axis 1 to Left stick horiz. and Axis 2 to Left stick vert. This needs to be done manually, as if you try using Rebind or using the sticks in the Edit Mapping dialog, it'll try to bind the directional versions of the sticks instead and you'll only get the hard 8 directions. The Up/Down/Left/Right entries are for digital control of the stick. They can either be mapped to the D-pad directions if you want, or you can leave them unbound and use the D-pad for something else. There aren't enough buttons on the Xbox 360 controller for the keypad, so you'll need to bind those to the keyboard. Just select the first entry, click Rebind, hit the keys you want for each entry, and then Stop. It's possible to configure some of the controller buttons as shifters to flip the modes of other buttons, but it's best not to try that until you're familiar with the general way that input maps work. Example: Afterward, make sure that the new input map you created is checked (enabled) and that the rest are turned off. Quote Link to comment Share on other sites More sharing options...
Marc Oberhäuser Posted August 28, 2015 Author Share Posted August 28, 2015 Awesome, many thanks for your help Quote Link to comment Share on other sites More sharing options...
