+DZ-Jay Posted July 22, 2016 Share Posted July 22, 2016 My voice encoder needs a word per channel per frame. Using 3 channels, it takes 6 bytes per frame, i.e. 360 bytes per second of speech. So I think DZG should safely fit in a plain rom without bank switching. The current problems are about partitioning the code and the data across the holes in the memory layout, but the whole rom atm is barely 30K Then that should be easily addressed using the ORG statement. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted July 24, 2016 Share Posted July 24, 2016 I think distribution of game over the 42K space is pretty easy. Although somewhat illogical because programmer should monitor the occupation of the memory map over several programs. Compile your program wonkie.bas Assemble your program (wonkie.asm -> wonkie.bin + wonkie.cfg) Read the cfg file (the map file) Draw a rectangle in paper showing addresses $0000-$ffff, draw frontiers showing addresses available for cartridges, mark the CFG file zones in this rectangle. If any zone crosses over any cartridge frontier, then your program will crash. Insert ASM ORG $xxxx statements over your code. Repeat step 4 and 5 to check if your program now fits. You'll note that when developing is easiest to keep static data in upper segments because you know the size. The assembler code is hardest to "distribute" over, but you can select your "finished" procedures and keep all them in a segment, getting it to grow as you work. Quote Link to comment Share on other sites More sharing options...
artrag Posted July 24, 2016 Author Share Posted July 24, 2016 Thanks! I succeeded to assemble and get a .CFG file Only I cannot get what it means exacly Here it is the one from dfg.bin [mapping] $0000 - $08F7 = $2100 $08F8 - $0905 = $4800 $0906 - $1905 = $5000 $1906 - $1DAA = $6000 $1DAB - $2A4C = $A000 $2A4D - $3137 = $C040 [vars] ecs = 1 But I was expecting code in these areas: REM ------------------------------------------------------------------------- REM 42K ROM memory map REM ------------------------------------------------------------------------- REM SEGMENT ADDRESS RANGE SIZE NOTES REM ======= ============== ===== ===== REM 0 $5000 to $6FFF $2000 - Default segment REM 1 $A000 to $BFFF $2000 REM 2 $C040 to $FFFF $3FC0 - Avoid STIC aliasing. REM 3 $2100 to $2FFF $0F00 REM 4 $7100 to $7FFF $0F00 - Avoid EXEC's ECS ROM probe. REM 5 $4810 to $4FFF $0800 - Account for game's ECS ROM mapping out code. REM ------------------------------------------------------------------------- Why my code seems allocated below 0x5000 ? Quote Link to comment Share on other sites More sharing options...
First Spear Posted July 26, 2016 Share Posted July 26, 2016 What I have done for my game is create a kind of "pre processor" as a quick-and-dirty .NET console app. It takes the DATA statements, counts the words/commas, and then re-organizes the .BAS file and inserts ASM ORG statements. I think distribution of game over the 42K space is pretty easy. Although somewhat illogical because programmer should monitor the occupation of the memory map over several programs. Compile your program wonkie.bas Assemble your program (wonkie.asm -> wonkie.bin + wonkie.cfg) Read the cfg file (the map file) Draw a rectangle in paper showing addresses $0000-$ffff, draw frontiers showing addresses available for cartridges, mark the CFG file zones in this rectangle. If any zone crosses over any cartridge frontier, then your program will crash. Insert ASM ORG $xxxx statements over your code. Repeat step 4 and 5 to check if your program now fits. You'll note that when developing is easiest to keep static data in upper segments because you know the size. The assembler code is hardest to "distribute" over, but you can select your "finished" procedures and keep all them in a segment, getting it to grow as you work. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted July 26, 2016 Share Posted July 26, 2016 What I have done for my game is create a kind of "pre processor" as a quick-and-dirty .NET console app. It takes the DATA statements, counts the words/commas, and then re-organizes the .BAS file and inserts ASM ORG statements. Ok, good enough while your important data isn't break into separate pieces. I intend to put someday automatic code ordering but that would involve structuring DATA segments, kind of STARTDATA and ENDDATA. 1 Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted July 28, 2016 Share Posted July 28, 2016 (edited) Ok, good enough while your important data isn't break into separate pieces. I intend to put someday automatic code ordering but that would involve structuring DATA segments, kind of STARTDATA and ENDDATA. But do you really need STARTDATA and ENDDATA when you have a fancy compiler? I do that in my framework because I am (ab)using the pre-processor and there is very limited information that I have on a single pass. Couldn't IntyBASIC just collect all data statements and break them (if necessary) when it finds a naturally occurring boundary, such as a label, opcode, procedure open/close, etc.? For instance: ' [A] ' ... code ... If (foo = 0) Then Goto @@Somewhere Return ' [-] ' [B] @@table1: Data $0000, $0000, $0000, $0000 Data $0000, $0000, $0000, $0000 Data $0000, $0000, $0000, $0000 Data $0000, $0000, $0000, $0000 ' [-] ' [A] @@Somewhere: Call DoSomething Return ' [-] ' [C] @@table2: Data $0000, $0000, $0000, $0000 Data $0000, $0000, $0000, $0000 ' [-] ' [D] @@table3: Data $0000, $0000, $0000, $0000 Data $0000, $0000, $0000, $0000 ' [-] ' A End ' [-] ' [E] ' ... code ... The above would result in five distinct blocks that could be rendered, if necessary, in different segments (A, B, C, D, and E). Of course, this wouldn't work if the programmer gets too fancy with overlapping data segments, but there is no reason why IntyBASIC could promote and support a certain way of organizing code. The idea is that procedure code must not cross boundaries, and that contiguous data blocks must fit within a single segment. The former is easy to detect; the latter could be inferred from its usage. Explicit "Begin" and "End" boundaries for Data statements are fine; I just think they are a crutch and that there may be enough information to always Do The Right Thing as long as the programmer conforms to certain simple conventions which are not really onerous. -dZ. Edited July 28, 2016 by DZ-Jay 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted July 28, 2016 Share Posted July 28, 2016 Not a bad idea Quote Link to comment Share on other sites More sharing options...
freewheel Posted July 29, 2016 Share Posted July 29, 2016 Just make an IDE that keeps a word count of every instruction and automatically shifts things as necessary. In real-time. As you watch. Sadly, this is roughly what my subconscious does as I approach our 42K barrier. Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted July 30, 2016 Share Posted July 30, 2016 (edited) The strategy I use for ROM allocation (which I have to employ every time I decide to make a change to my game since it's such a cow!), is as follows: Store procedures in their own module file, or group small related procedures together in the same module. Typically, I make a distinction between "public" procedures (those available to the general program), and "private" procedures (those that serve as utility functions for a specific routine). I tend to group "private" procedures within the same module as the "public" one they support. I further categorize my modules into "code" and "data," and try to keep modules for each category together with their kind. "Code" modules contain utility functions and sub-routines; while "data" modules include look-up tables, graphics data, etc. Thus, my libraries fall neatly into "code segment" and "data segment." I use the INCLUDE directive at the top of my "main" module to include all modules. As mentioned above, I neatly group them by category. So it looks something like this: ;; ======================================================================== ;; ;; DATA ;; ;; ======================================================================== ;; ; BACKGROUND DATA INCLUDE "data/intro/intro_drops.dat" INCLUDE "data/intro/intro_btab.dat" INCLUDE "data/scene/scene_gift_btab.dat" INCLUDE "data/scene/scene_trap_btab.dat" INCLUDE "data/scene/scene_title_btab.dat" INCLUDE "data/maze/maze_base.dat" INCLUDE "data/maze/maze_info.dat" INCLUDE "data/maze/maze_btab.dat" INCLUDE "data/maze/maze_vmap.dat" INCLUDE "data/menu/menu_btab.dat" ; AUTO-PILOT SCRIPTS INCLUDE "data/scripts/aps_winner.aps" INCLUDE "data/scripts/aps_seq_1.aps" INCLUDE "data/scripts/aps_seq_2.aps" INCLUDE "data/scripts/aps_seq_3.aps" INCLUDE "data/scripts/aps_seq_4.aps" INCLUDE "data/scripts/aps_seq_5.aps" INCLUDE "data/scripts/aps_seq_6.aps" INCLUDE "data/scripts/aps_seq_7.aps" INCLUDE "data/scripts/aps_seq_8.aps" INCLUDE "data/scripts/aps_elf.aps" ;; ======================================================================== ;; ;; CODE ;; ;; ======================================================================== ;; ; UTILITIES INCLUDE "util/stic_util.asm" INCLUDE "util/ctrl_util.asm" INCLUDE "util/sprite_util.asm" INCLUDE "util/vmap_util.asm" INCLUDE "util/level_util.asm" INCLUDE "util/str_util.asm" INCLUDE "util/intro_util.asm" INCLUDE "util/task_util.asm" INCLUDE "util/random_util.asm" ; SPRITE MOVEMENT INCLUDE "game/move/mv_badtoy.asm" INCLUDE "game/move/mv_elf.asm" INCLUDE "game/move/mv_ghost.asm" INCLUDE "game/move/mv_snowman.asm" INCLUDE "game/move/mv_pathfinder.asm" INCLUDE "game/move/mv_enemy.asm" ; OBJECT COLLISION INCLUDE "game/collision/c_items.asm" INCLUDE "game/collision/c_candy.asm" INCLUDE "game/collision/c_present.asm" INCLUDE "game/collision/c_ghost.asm" INCLUDE "game/collision/c_snowman.asm" INCLUDE "game/collision/c_badtoy.asm" Now, if the entire program and its data were small enough to fit into the default segment, then I'd be done. However, as the size of the program increases and reaches or exceeds the limits of the default segment, my first strategy is to split it into "Code" and "Data" segments. For this I have a handy macro that just injects the necessary ORG directive to switch segments. My "default" segments are typically the default for "Code" and the largest one available for "Data". Following the CART.MAC memory map, it'll be segments #0 and #2, respectively: ; -------------------------------------- ; Memory map for 42K ROM cartridge ; -------------------------------------- ; SEGMENT RANGE ; 0 $5000 - $6FFF : 8K <-- Code ; 1 $A000 - $BFFF : 8K ; 2 $C040 - $FFFF : 16K <-- Data ; 3 $2000 - $2FFF : 4K ; 4 $7100 - $7FFF : 4K ; 5 $4800 - $4FFF : 2K As the code and data modules grow, I start breaking up my module groups and placing them in different segments. I don't give it much thought, just pick the next segment available and split the modules between them. My main module then starts to look like this: ;; ======================================================================== ;; ;; DATA ;; ;; ======================================================================== ;; ; BACKGROUND DATA ROMSEG 2 ; Use Segment #2 INCLUDE "data/intro/intro_drops.dat" INCLUDE "data/intro/intro_btab.dat" INCLUDE "data/scene/scene_gift_btab.dat" INCLUDE "data/scene/scene_trap_btab.dat" INCLUDE "data/scene/scene_title_btab.dat" INCLUDE "data/maze/maze_base.dat" INCLUDE "data/maze/maze_info.dat" INCLUDE "data/maze/maze_btab.dat" INCLUDE "data/maze/maze_vmap.dat" INCLUDE "data/menu/menu_btab.dat" ; AUTO-PILOT SCRIPTS INCLUDE "data/scripts/aps_winner.aps" INCLUDE "data/scripts/aps_seq_1.aps" INCLUDE "data/scripts/aps_seq_2.aps" INCLUDE "data/scripts/aps_seq_3.aps" INCLUDE "data/scripts/aps_seq_4.aps" INCLUDE "data/scripts/aps_seq_5.aps" INCLUDE "data/scripts/aps_seq_6.aps" INCLUDE "data/scripts/aps_seq_7.aps" INCLUDE "data/scripts/aps_seq_8.aps" INCLUDE "data/scripts/aps_elf.aps" ;; ======================================================================== ;; ;; CODE ;; ;; ======================================================================== ;; ; UTILITIES ROMSEG 0 ; Use Segment #0 INCLUDE "util/stic_util.asm" INCLUDE "util/ctrl_util.asm" INCLUDE "util/sprite_util.asm" INCLUDE "util/vmap_util.asm" INCLUDE "util/level_util.asm" INCLUDE "util/str_util.asm" INCLUDE "util/intro_util.asm" INCLUDE "util/task_util.asm" INCLUDE "util/random_util.asm" As I start reaching the limits of the initial segments, I start playing what I call "musical ROM segments" , which is pretty much just shuffling stuff around until I get a successful build. On a pinch, I could calculate the size of a module and see where I can squeeze it. For data modules, this is rather straightforward since it's a matter of counting the DECLEs (DATA statements). However, this is seldom necessary (at least to me), since I can just easily move the INCLUDE directives around and get it out of the way. Obviously I need to mind any dependencies between modules. However, in practice, this is not really an issue and I mainly try to keep the modules small and concise for this reason. Eventually, my main module stars to get messy with the ROMSEG directive as I shuffle stuff around, but it is still easy to follow and group all modules, and does not require much thought or cognitive burden. This is an excerpt of my final source, for illustration: ;; ======================================================================== ;; ;; BACKGROUND DATA ;; ;; ======================================================================== ;; ROMSEG 1 INCLUDE "data/intro/intro_btab.dat" INCLUDE "data/scene/scene_trap_btab.dat" INCLUDE "data/scene/scene_gift_btab.dat" ROMSEG 4 INCLUDE "data/intro/intro_drops.dat" ROMSEG 0 INCLUDE "data/scene/scene_title_btab.dat" ROMSEG 2 INCLUDE "data/maze/maze_base.dat" INCLUDE "data/maze/maze_info.dat" INCLUDE "data/maze/maze_btab.dat" INCLUDE "data/maze/maze_vmap.dat" INCLUDE "data/menu/menu_btab.dat" Notice that nothing changes in the actual code, and it's just a matter of shuffling things around until they fall on a spot that builds. It also helps that I have a handy library that prints out the used and available ROM space. I rely on this output as a guide to know where I can stuff things better. ROM USAGE: Used: Segment 0 (8K): 8157 words. Segment 1 (8K): 7853 words. Segment 2 (15K): 16150 words. Segment 3 (3K): 3837 words. Segment 4 (3K): 3838 words. Segment 5 (2K): 2041 words. TOTAL: 41876 words. Available: Segment 0 (8K): 35 words. Segment 1 (8K): 372 words. Segment 2 (15K): 200 words. Segment 3 (3K): 3 words. Segment 4 (3K): 2 words. Segment 5 (2K): 7 words. TOTAL: 619 words. I do the above on Assembly Language, but I don't see why it wouldn't work with IntyBASIC. The segment selecting macros can be implemented using the IntyBASIC user macros, and the compiler already supports the INCLUDE directive. Plus, modularization of code and data tables is always a good practice. -dZ. EDIT: Updated with relevant illustrative examples. Edited September 13, 2016 by DZ-Jay 3 Quote Link to comment Share on other sites More sharing options...
artrag Posted September 12, 2016 Author Share Posted September 12, 2016 New version using compiler v1.2.7 New voice player integrated using VARPTR in data 1 Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted September 13, 2016 Share Posted September 13, 2016 New version using compiler v1.2.7 New voice player integrated using VARPTR in data Do you have a new binary to share? By the way, not that I expect you to still be waiting for it, but the DZ Gorf screen I was working on is still making its way up through my TO DO queue. I'll get to it soon (along with the new and Mac version of the SDK). Sorry. In the meantime, I'd like to try out your latest bin with voice samples, if possible. -dZ. Quote Link to comment Share on other sites More sharing options...
artrag Posted September 13, 2016 Author Share Posted September 13, 2016 Look at the first post Use ecs for voice Quote Link to comment Share on other sites More sharing options...
artrag Posted October 29, 2016 Author Share Posted October 29, 2016 New version in the first post http://atariage.com/forums/topic/243150-deep-zone-gorf/?p=3330672 Now compiled with intyBasic v1.2.8 1 Quote Link to comment Share on other sites More sharing options...
Rev Posted October 31, 2016 Share Posted October 31, 2016 Here you can find the last update of a test game born to test intybasic and overgrow out of control update: 6 kinds of enemies: 1 spinning left 2 spinning right 3 linear at random position 4 linear close main ship position 5 zig zag 6 homing (now slower than the main ship) Features: - Speed tuning, variable speeds for warp, enemies and ship - Level increases after you pass the 6th enemy type (shown in the top right corner, in yellow) - You pass to a new swarm after that 5 enemies of a given type have been killed - Support for score and lives - Gyrus controls on 16 directions - Game over sequence - New animation for the space warp - Slowed bullets from main ship - New music (2 channel chords courtesy of First Spear) - Game over music (courtesy of First Spear) - Bosses appear after each 6 waves (no interaction ATM, press buttons to cycle them all and enter to skip the boss phase) - New title screen - Added 5 sfx and 5 voice samples in the test screen Now compiled with IntyBasic v1.2.8 Is this the newest rom? I have a previous rom, want to make sure. Is there a way you can post multiple rom versions? Quote Link to comment Share on other sites More sharing options...
artrag Posted October 31, 2016 Author Share Posted October 31, 2016 The last rom is in the package with its source. Use ECS for voices in the test screen. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted December 2, 2017 Share Posted December 2, 2017 I've made a video https://www.youtube.com/watch?v=6QpjQkcg-Vg Quote Link to comment Share on other sites More sharing options...
+cmart604 Posted December 3, 2017 Share Posted December 3, 2017 Looks promising! Quote Link to comment Share on other sites More sharing options...
artrag Posted December 3, 2017 Author Share Posted December 3, 2017 (edited) Nice! How do you record an avi file in the inty emulator? Edited December 3, 2017 by artrag Quote Link to comment Share on other sites More sharing options...
HawkMines Posted December 3, 2017 Share Posted December 3, 2017 When's the cart release? You might as well just take my money now. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted December 3, 2017 Share Posted December 3, 2017 Nice! How do you record an avi file in the inty emulator? In the latest jzintv version you press Alt Win+A to start/finish recording (Cmd A in Mac) The generated file can be directly uploaded to Youtube. Quote Link to comment Share on other sites More sharing options...
artrag Posted December 3, 2017 Author Share Posted December 3, 2017 (edited) jzIntv v1.0 under windows seems to not support ALT+A Where should I find the video file after recording ? Edited December 3, 2017 by artrag Quote Link to comment Share on other sites More sharing options...
mthompson Posted December 3, 2017 Share Posted December 3, 2017 I believe the video file gets saved to the same directory that jzintv is located. The file you're looking for will be named "avi_0000.avi" and subsequent videos increment the number in the file name. Quote Link to comment Share on other sites More sharing options...
artrag Posted December 3, 2017 Author Share Posted December 3, 2017 No way to get an AVI file with ALT+A All I get is a .IMV file when I press some function key (I think F9 or something like that) But I do not know a way to use IMV files in youtube PS I compiled the game with in v1.2.9 and I uploaded it in the first post. All seems to work fine. Quote Link to comment Share on other sites More sharing options...
+Tarzilla Posted December 3, 2017 Share Posted December 3, 2017 Recording of a video in windows is Windows key and A, works in windows 7. In windows 10 try F8-A Or edit the kbd hack file. 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted December 3, 2017 Share Posted December 3, 2017 No way to get an AVI file with ALT+A All I get is a .IMV file when I press some function key (I think F9 or something like that) But I do not know a way to use IMV files in youtube PS I compiled the game with in v1.2.9 and I uploaded it in the first post. All seems to work fine. Recording of a video in windows is Windows key and A, works in windows 7. In windows 10 try F8-A Or edit the kbd hack file. Sorry, my fault, I've corrected my post, Tarzilla is right. Quote Link to comment Share on other sites More sharing options...
