+eebuckeye Posted November 12, 2015 Share Posted November 12, 2015 I bought a disk drive that worked on a few disks and then was only loading sometimes. I cleaned the disk head gently with alcohol and it worked again, however, now it does not load any disk. I tried cleaning again with no luck. The disk spins and the head makes contact but it does not load and I have tried with many disks (some loaded fine before). Anything else I can try? Thanks! Quote Link to comment Share on other sites More sharing options...
MarkO Posted November 12, 2015 Share Posted November 12, 2015 I bought a disk drive that worked on a few disks and then was only loading sometimes. I cleaned the disk head gently with alcohol and it worked again, however, now it does not load any disk. I tried cleaning again with no luck. The disk spins and the head makes contact but it does not load and I have tried with many disks (some loaded fine before). Anything else I can try? Thanks! Which Computer System is this Drive for?? Apple ]['s have various issues that the C64 Don't usually have... MarkO Quote Link to comment Share on other sites More sharing options...
+eebuckeye Posted November 13, 2015 Author Share Posted November 13, 2015 The drive is for a TI99.. it was reading fine but now I can not get it to read any disks even after cleaning the head. Are there other adjustments I could try? Thanks! Quote Link to comment Share on other sites More sharing options...
MarkO Posted November 16, 2015 Share Posted November 16, 2015 I am affraid I know little about the TI disk system.. A TI expert must arrise to answer this question.. Quote Link to comment Share on other sites More sharing options...
MarkO Posted November 16, 2015 Share Posted November 16, 2015 Also you posted this thread in the general "Classic Computer", rather than under the TI-99 Forum, so I wouldn't know which type of system this is used with.. MarkO Quote Link to comment Share on other sites More sharing options...
