Bryan Posted June 21, 2016 Share Posted June 21, 2016 eBay Auction -- Item Number: 331881959148 This is a RAM module with some extra chips added. Anyone know what they're for? It looks pretty simple and my first thought was it might be a copy protection dongle for something. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted June 21, 2016 Share Posted June 21, 2016 Interesting that the chip markings on the add-on perfboard there are obscured. Quote Link to comment Share on other sites More sharing options...
Rybags Posted June 21, 2016 Share Posted June 21, 2016 (edited) My guess would be a write protect switch which would allow uncracked contiguous 16K cartridge copies to be run. The white wire goes to Pin 13 which corresponds to R/W. It's hard to tell though if the extra board has a physical switch on it. If it doesn't then logically the write protect would be engaged by a write to the $D5xx area. Removed chip markings... yeah, something that was seemingly common in the day for what's effectively a very cheap to make device, as in a few bucks which was probably then sold for 10 times or more that amount. Edited June 21, 2016 by Rybags Quote Link to comment Share on other sites More sharing options...
1050 Posted June 21, 2016 Share Posted June 21, 2016 And back then they had no idea that today we can use a $40 USB programmer to detect what each logic chip is with ground off numbers anyway. Kinda silly and cute to see such efforts. Black object at top of perf board is two DIP switches I believe and I'm thinking it's a rom emulator on the order of a home rolled Pill. Two switches may allow for 8K/16K selection as well. The green wire underneath does connect to pin 3, R/W, of 4116. Copy protection dongle it is. I don't recall seeing any others like it though. Quote Link to comment Share on other sites More sharing options...
Rybags Posted June 22, 2016 Share Posted June 22, 2016 8/16K makes sense if you want to use programming language carts and maximize available memory. For games, doesn't really matter. Most games run with 16K Ram, probably all the ones that need 40K or more are banked carts anyway. Quote Link to comment Share on other sites More sharing options...
