+mizapf Posted November 28, 2016 Share Posted November 28, 2016 I can only imagine that this was some power-2 simplification idea. As I said, 16 sectors vs 18 sectors just means you have bigger gaps; you cannot change the width of the cells which could serve for a more robust recording. For that reason, bad media would not have become more reliable. Error correction code (ECC) is not used for floppy disk controllers; would require much more processing power, as found in a HD controller. And the intention to speed up loading is well covered by interleaving. Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted November 28, 2016 Author Share Posted November 28, 2016 (edited) There is a formatting routine inside the controller ROM that creates a floppy file system with some default settings. Yes. To format a floppy disk, just tape: OPEN #1:"HEXBUS.FORMAT.MEDIA.device_number" CLOSE #1 with TI-BASIC on a computer or : FORMAT device_number on the CC-40. Where device_number can be 101 to 104, depending the drive you want to use. By default, the command will initialize the disk as 40-track, DS, DD. Edited November 28, 2016 by fabrice montupet 1 Quote Link to comment Share on other sites More sharing options...
kl99 Posted December 1, 2016 Share Posted December 1, 2016 Yes. To format a floppy disk, just tape: OPEN #1:"HEXBUS.FORMAT.MEDIA.device_number" CLOSE #1 with TI-BASIC on a computer So I don't need to get Disk Manager II for formatting disks? I seem to have forfotten about that important addition to the TI-OS, even though I now remember having read it once. I anyway have had trouble using the internal Disk Drive from the Hex-Bus Disk Controller. I used the external connector of it to connect a second disk drive. Will take the controller apart once I have more time. Btw: I was able to communicate from the 99/2 to the Pc (Usb to Serial) via Hex-Bus Rs232. I am using OPEN/CLOSE/PRINT/INPUT/LIST so far. However the documentation says, there is no support for OLD/SAVE within Hex-Bus Rs232, so I don't see an easy Bootstrap option for Web99 like OLD RS232.BA=9600 on the 99/4A to load a program sent by another system. The same limitation is true for the Hex-Bus Modem. BUT i have aquired the TI-74 Pc Interface, which provides you with connection from the Intelligent Peripheral Bus (the new name for Hex-Bus) to a parallel port. I will try to simulate a whole Hex-Bus Device from Pc side by imidating the communication protocol. First on Windows, later maybe Raspberry PI, Beaglebone, Arduino or some other thing. 1 Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted December 4, 2016 Author Share Posted December 4, 2016 I forgot to show you a zoomed picture of my Hexbus Controller PCB, here it is: I made some minor changes on it since the shooting. 7 Quote Link to comment Share on other sites More sharing options...
Diecrusher Posted December 8, 2016 Share Posted December 8, 2016 I forgot to show you a zoomed picture of my Hexbus Controller PCB, here it is: I made some minor changes on it since the shooting. FANTASTIC! Absolutely beautiful! Quote Link to comment Share on other sites More sharing options...
