+therealbountybob #1 Posted February 3, 2017 I'd like to pay homage to Red Dwarf and use the intro music (not the whole song, just a few seconds) for my game Space Fortress Omega. About 12 or 24 seconds of this: Here is a link to it being played by an orchestra: https://www.youtube.com/watch?v=quTktctks30 Here is a link to some sheet music: https://musescore.com/user/154204/scores/2474021 I have not got RAM for a player (e.g. RMT) so I'm after the note values, durations and any audio settings, but even the notes would be a good start Thanks 1 Quote Share this post Link to post Share on other sites
_The Doctor__ #2 Posted February 3, 2017 (edited) a lot of red dwarf music was other works redone to fit the show, but the it's cold outside bit was the theme everyone knows... so I'd pick it up with the horns and trumpets after the singing... keeping the comical, happy timber going. It's tongue in cheek folks dunn din duuhh This might be of more help for our musicians ... Edited February 3, 2017 by _The Doctor__ 2 Quote Share this post Link to post Share on other sites
_The Doctor__ #3 Posted February 3, 2017 (edited) An intro, and outro, and some in game incidentals? I wonder what emkay could do with this? but I guess you just want note score and pokey values Edited February 3, 2017 by _The Doctor__ Quote Share this post Link to post Share on other sites
+playsoft #4 Posted February 3, 2017 Hi Jason, if this is of any use I made an edit of the midi file from the sheet music link and converted it to (frame delay, AUDF) pairs in output.txt. I've included ca65 source for playing it. red.zip 3 Quote Share this post Link to post Share on other sites
Rybags #5 Posted February 4, 2017 No production with reference to Red Dwarf would be in any way near complete without... Quote Share this post Link to post Share on other sites
RedThunder #6 Posted February 4, 2017 (edited) https://musescore.com/user/154204/scores/2474021 As above. Missed the link already provided. Edited February 4, 2017 by RedThunder Quote Share this post Link to post Share on other sites
+therealbountybob #7 Posted February 4, 2017 Hi Jason, if this is of any use I made an edit of the midi file from the sheet music link and converted it to (frame delay, AUDF) pairs in output.txt. I've included ca65 source for playing it. Wow thanks Paul but(!) it's the darker intro part (first 24 seconds) often used at the start of each episode as it pans through space that I'm after, rather than the tune itself. This is more in keeping with the game Quote Share this post Link to post Share on other sites
McKong #8 Posted February 4, 2017 Got me wanting to watch Red Dwarf now! 1 Quote Share this post Link to post Share on other sites
+playsoft #9 Posted February 4, 2017 Wow thanks Paul but(!) it's the darker intro part (first 24 seconds) often used at the start of each episode as it pans through space that I'm after, rather than the tune itself. This is more in keeping with the game Smeg! In this one if you only want the first two parts remove all the bytes in the .if 1/.endif in output.txt. red2.zip 3 Quote Share this post Link to post Share on other sites
+therealbountybob #10 Posted February 5, 2017 Thanks Paul, this is brilliant I think I've got my long standing annoying bug fixed, improved the title screen and still have a whopping 50 bytes left so play with so I can concentrate on getting some bits of music in next 1 Quote Share this post Link to post Share on other sites
+therealbountybob #11 Posted February 14, 2017 Somehow and surprisingly I've just succeeded in 'translating' the ca65 code into MAC/65 and got the object file to play the tune! (Used altirra's paste and MAC/65s text mode with auto number to get the lines to type themselves in first.) Slight issue is some noises before it starts, possibly this bit: ; for each audio channel, the AUDF value and index into the AUDC envelopechannel_data:.repeat CHANNELS .byte $00,audc_data_end-audc_data.endrepeat In MAC/65 I have put this - please can you confirm what the above does, should the 2nd value be table length or is this populated and used on the fly so blank values are ok? CHANNELDATA .BYTE $00,$00 .BYTE $00,$00 .BYTE $00,$00 .BYTE $00,$00 In this bit I used CPX #4 instead of the calculation, is this correct ? next: inx inx cpx #(2 * CHANNELS) bne loo Thanks Quote Share this post Link to post Share on other sites
+playsoft #12 Posted February 14, 2017 Slight issue is some noises before it starts, possibly this bit: ; for each audio channel, the AUDF value and index into the AUDC envelope channel_data: .repeat CHANNELS .byte $00,audc_data_end-audc_data .endrepeat In MAC/65 I have put this - please can you confirm what the above does, should the 2nd value be table length or is this populated and used on the fly so blank values are ok? CHANNELDATA .BYTE $00,$00 .BYTE $00,$00 .BYTE $00,$00 .BYTE $00,$00 That will be it. The second value of the pair is an offset into the audc_data volume curve: ; AUDC volume curve, used for all notes audc_data: .byte $C5,$A6,$A6,$A6,$A6,$A6,$A5,$A5,$A5,$A5,$A5,$A5,$A5,$A5,$A5,$A5 .byte $A5,$A4,$A4,$A4,$A4,$A4,$A4,$A4,$A4,$A4,$A4,$A4,$A4,$A4,$A3,$A3 .byte $A3,$A3,$A3,$A3,$A3,$A3,$A3,$A3,$A2,$A2,$A2,$A2,$A2,$A2,$A2,$A2 .byte $A1,$A1,$A1,$A1,$A1,$A1,$A1,$A0 audc_data_end: .byte $00 When nothing is playing it should index the $00 byte at the end. Above audc_data_end - aud_data will result in a value of 56 ($38). 1 Quote Share this post Link to post Share on other sites
+playsoft #13 Posted February 14, 2017 In this bit I used CPX #4 instead of the calculation, is this correct ? next: inx inx cpx #(2 * CHANNELS) bne loo I had used all 4 audio channels, so it should have been cpx #8. With cpx #4 it is only using 2 channels. I just tried and it sounds ok, but not as good as it does with all 4 channels. 1 Quote Share this post Link to post Share on other sites
snicklin #14 Posted February 15, 2017 No production with reference to Red Dwarf would be in any way near complete without... I had this in my head for days after watching this again after all these years. Thanks - but no thanks! 1 Quote Share this post Link to post Share on other sites
