Bob_63 Posted February 20, 2017 Share Posted February 20, 2017 Hello all I am a just beginning to develop a new game for Atari Lynx console up to know, I have follow the tutorial in the famous "diary of a atari lynx developer" and for me , it 's fine to begin, thanks problem : I can't manage to make srpite collision In fact, I don't have the TGI_detectioncollision function, so I have used the fonction tgi_ioctl(5, 1); and I would like to sceening the depository value for One of my sprite, but nothing appear on screen. => I try after that to fit in the link assembly the - C lynx-coll.cfg, but surprse : I don't succeed to compile my C code=> error appear (error 2 => function expected ). After analysing standard lynx.cfg and lynx-coll.cfg, I have lot of differences, My conclusion up to this day is that my version of assembler is obsolete... Someone could help me. I have spend lot of time to try to solve my problem and now, i think that I am bloqued Thanks a lot By advance. Quote Link to comment Share on other sites More sharing options...
tonma Posted February 21, 2017 Share Posted February 21, 2017 You are using Windows or Linux ? You can see the name of the function in include / lynx.h. You use TGI_detectioncollision instead of tgi_setcollisiondetection. Maybe it's a first mistake, but using tgi_ioctl (5, 1) it's the same #define tgi_setcollisiondetection(active) tgi_ioctl(5, (void*)(active)) Can you put your code for the the depository ? Something like this would work and draw 0 on screen. Don't forget the drawing order. Maybe your text is under Sprite. typedef struct { byte depository; SCB_REHV_PAL scb; } sprite_collideable; sprite_collideable robot = { 0x0, { BPP_4 | TYPE_NORMAL, REHV, 0x01, 0, robot, 20, 50, 0x0100, 0x0100, { 0x01, 0x23, 0x45, 0x67, 0x89, 0xab, 0xcd, 0xef } } }; tgi_sprite(&robot.scb); itoa(robot.depository, text, 10); tgi_outtextxy(30, 48, text); 1 Quote Link to comment Share on other sites More sharing options...
Bob_63 Posted February 21, 2017 Author Share Posted February 21, 2017 Hello Chopper Commander Thanks a lot for your Help!! FIrst , I 'm working on windows With your Help , I can now screening the depository number I also have the tgi_setcollisiondetection function working well => this is a big step but, strangly, when I make my sprite collision, the depository number stay at 0 I'm wondering If I need to add in my Make File the attribute -C Lynx-coll.cfg? on this case, the compilation don't work anymore Quote Link to comment Share on other sites More sharing options...
Bob_63 Posted February 21, 2017 Author Share Posted February 21, 2017 Humm sorry, I made a mistake,.. your Nickname : => Tonma (and not chopper commander) ... Quote Link to comment Share on other sites More sharing options...
tonma Posted February 22, 2017 Share Posted February 22, 2017 Hello Chopper Commander Thanks a lot for your Help!! FIrst , I 'm working on windows With your Help , I can now screening the depository number I also have the tgi_setcollisiondetection function working well => this is a big step but, strangly, when I make my sprite collision, the depository number stay at 0 I'm wondering If I need to add in my Make File the attribute -C Lynx-coll.cfg? on this case, the compilation don't work anymore Ok, I don't working on windows. Post your code ! Have you declare other sprite depository like the example, you should have 8 : sprite_collideable wall = { 0x0, { BPP_4 | TYPE_NORMAL, REHV, 0x8, 0, singlepixel_data, 50, 20, 0x0a00, 0x1a00, { 0x01, 0x23, 0x45, 0x67, 0x89, 0xab, 0xcd, 0xef } } }; You need Lynx-coll.cfg only if you have this file. If you only have one .c file like hello world template, you don't need to add the cfg. You can see an example here that should work for windows: http://sebastianmihai.com/main.php?t=49 Humm sorry, I made a mistake,.. your Nickname : => Tonma (and not chopper commander) ... Quote Link to comment Share on other sites More sharing options...
Bob_63 Posted February 22, 2017 Author Share Posted February 22, 2017 Hello Tonma this is my code : the only one difference I have seen is the byte variable=> in windows, I have to use unsigned or signed char in place of byte. for the sprite declaration: (smiley and soucoupe)typedef struct { unsigned char depository; SCB_REHV_PAL scb;} sprite_collideable;sprite_collideable smileydraw = { 0x0, { BPP_4 | TYPE_NORMAL, REHV, 0x1, 0, &smiley, 30, 30, 0x0100, 0x0100,{ 0x01, 0x23, 0x45, 0x67, 0x89, 0xab, 0xcd, 0xef } }};sprite_collideable soucoupedraw ={ 0x0, { BPP_4 | TYPE_NORMAL, REHV, 0x8, 0, &soucoupe, 30, 30 ,0x0100, 0x0100, { 0x06, 0x78, 0x9a, 0xbc, 0xde, 0xf0, 0x12, 0x34 }}}; for the screening: void show_screen(){ tgi_clear(); tgi_sprite(&soucoupedraw.scb); tgi_sprite(&smileydraw.scb); itoa(smileydraw.depository, text, 10); tgi_outtextxy(50, 90, text); tgi_updatedisplay(); while (tgi_busy());}the initialization void : void initialize(){ tgi_install(&lynxtgi); joy_install(&lynxjoy); tgi_init(); tgi_setcollisiondetection(1); CLI(); while (tgi_busy()); setpalette(palette_Atlantis), tgi_clear(); } And the main void : void main(void){ initialize(); show_screen(); } Not possible for me to make appear a depositary value different from 0 value. I try a lot of test (inverting the sprite apparition), moving sprite in the screen, moving the tgi_setcollisiondetection(1); in place of byte, trying char, unsigned ans signed char, etc... Thanks again to follow my post, this is a important help for a rookie as me! Quote Link to comment Share on other sites More sharing options...
tonma Posted February 22, 2017 Share Posted February 22, 2017 I try on Linux and it's working. The only thing, I don"t use lynxtgi but lynx_160_102_16, it's just the same file for linux I think. You draw the sprites in the right order. I do not know for the mistake, maybe someone on windows may find. Do you have some warnings when compile ? #include <lynx.h> #include <tgi.h> #include <6502.h> #include <joystick.h> #include <stdlib.h> #include <conio.h> char allcolors_data[17] = { 0x04, 0x98, 0x09, 0x18, // 1 0011 0000 0001 0010 0011 000 0x04, 0x9a, 0x2b, 0x38, // 1 0011 0100 0101 0110 0111 000 0x04, 0x9c, 0x4d, 0x58, // 1 0011 1000 1001 1010 1011 000 0x04, 0x9e, 0x6f, 0x78, // 1 0011 1100 1101 1110 1111 000 0x00 }; typedef struct { unsigned char depository; SCB_REHV_PAL scb; } sprite_collideable; sprite_collideable smileydraw = { 0x0, { BPP_4 | TYPE_NORMAL, REHV, 0x01, 0, allcolors_data, 30, 30, 0x0100, 0x0100, { 0x01, 0x23, 0x45, 0x67, 0x89, 0xab, 0xcd, 0xef } } }; sprite_collideable soucoupedraw = { 0x0, { BPP_4 | TYPE_NORMAL, REHV, 0x8, 0, allcolors_data, 32, 32 ,0x0100, 0x0100, { 0x01, 0x23, 0x45, 0xbc, 0xde, 0xf0, 0x12, 0x34 } } }; char text[16]; void main(void) { tgi_install(&lynx_160_102_16); tgi_init(); tgi_setcollisiondetection(1); CLI(); tgi_setcolor(COLOR_GREEN); while (tgi_busy()) ; while (1) { while (tgi_busy()) ; tgi_clear(); tgi_sprite(&soucoupedraw.scb); tgi_sprite(&smileydraw.scb); itoa(smileydraw.depository, text, 10); tgi_outtextxy(50, 90, text); tgi_updatedisplay(); } } You must use a while to run show_screen () again and again. Otherwise after the function "show_screen" the software stops. void main(void) { initialize(); while(1) { show_screen(); } } Have you tried with the same picture. I think it's perfect collision so if you two sprites collide with the transparent color, they do not collide. game.zip Quote Link to comment Share on other sites More sharing options...
Bob_63 Posted February 25, 2017 Author Share Posted February 25, 2017 Hello Tonma Thanks a lot for your precious help unfortunately, i think Windows version work differently with collision. Maybe, it is the reason why I fail in the collision programming I m going to continue to looking for the solution and if I'll find something I will give you the solution Bye Quote Link to comment Share on other sites More sharing options...
LX.NET Posted February 26, 2017 Share Posted February 26, 2017 I will try to look at the windows version tomorrow. Quote Link to comment Share on other sites More sharing options...
Bob_63 Posted February 27, 2017 Author Share Posted February 27, 2017 Thanks for your help LX.NET. Let me know if you find something than can Help. Bye Quote Link to comment Share on other sites More sharing options...
