AtariLeaf
Best source for Atari 8-bit ram chips?
Looking to replace some bad ram in an 800xl. What is the best source? Best Electronics? Ebay? Some other online seller I'm not aware of.
Also how many should I buy and what can I expect to pay? It would seem to me to be advantageous to buy more than 8 in case one or two are bad out of the gate.
Thanks for you time :)
Where are you from?
Which chips you want?
How many? :)
Sent from my LG-H850 using Tapatalk
I bought a nice lot of new "old stock" Texas Instrument chips off ebay for what I considered a great deal. Les than a $1 a chip.
http://www.ebay.com/itm/25x-TEXAS-INSTRUMENTS-TMS4164-15NL-16-Pin-Dip-DRAM-New-/332081794334?epid=1801591024&hash=item4d519e0d1e:g:G1sAAOSw44BYbW6C
TMS4164-15NL 16-Pin
Edited by NISMOPC
Where are you from?
How many? :)
I'm from Southern Ontario in Canada. I'd probably need 8 at least. As for which chips, I'm not sure what they are called but they are the 8 ram chips on the left of an 800XL board. This particular board is socketed , thank goodness so it should just be a simple thing to pop them in
Hmm. I'm from United Kingdom and post will be expensive. I have some spare chips and I'm able send it just for postage. But try find somewhere closer before :)
That link on eBay would be what you need.
Some reference #'s for you as well to search on. the farthest right part #. Found these from a ATARI vendor approved list document:
137339-001 IC,DRAM,64Kx1,tRAC=120ns,tCAC=100ns,NMOS,Tri,16pin MICRON_TECHNOLOGY MT4264N-12
137339-002 IC,DRAM,64Kx1,tRAC=150ns,tCAC=100ns,NMOS,Tri,16pin HITACHI_AMERICA_LTD HM4864P-2
137339-003 IC,DRAM,64Kx1,tRAC=150ns,tCAC=100ns,NMOS,Tri,16pin INTEL 2164A-15
137339-004 IC,DRAM,64Kx1,tRAC=150ns,tCAC=100ns,NMOS,Tri,16pin TOSHIBA TMM4164P-3
137339-005 IC,DRAM,64Kx1,tRAC=150ns,tCAC=100ns,NMOS,Tri,16pin OKI_SEMICONDUCTOR M3764-15
137339-006 IC,DRAM,64Kx1,tRAC=150ns,tCAC=100ns,NMOS,Tri,16pin TEXAS_INSTRUMENTS TMS4164-15NL
137339-007 IC,DRAM,64Kx1,tRAC=150ns,tCAC=100ns,NMOS,Tri,16pin FUJITSU MB8264A-15M
137339-008 IC,DRAM,64Kx1,tRAC=150ns,tCAC=100ns,NMOS,Tri,16pin FUJITSU SB9589-15P
137339-009 IC,DRAM,64Kx1,tRAC=150ns,tCAC=100ns,NMOS,Tri,16pin MICRON_TECHNOLOGY 4264N-15A
137339-010 IC,DRAM,64Kx1,tRAC=100ns,tCAC=70ns,NMOS,Tri,16pin INMOS IMS2600P-10
137339-011 IC,DRAM,64Kx1,tRAC=150ns,tCAC=75ns,NMOS,Tri,16pin MOTOROLA MCM6665-15
137339-012 IC,DRAM,64Kx1,tRAC=120ns,tCAC=75ns,NMOS,Tri,16pin TEXAS_INSTRUMENTS TMS 4164-12NL
  • Like 4
Oh I assumed you were showing me an example of ram chips on the TI side as an example. So these same ram chips work on the 800XL?
Old ISA cards used to be a great source for the 4x64k chips as used in XEGS, later XE, and 64K for 600XL upgrade.
These days though they'd be harvested, in use by retro collectors or just destroyed so specialist arcade suppliers and eBay auctions are probably the easiest.
So it's possible these chips may be hard to come by? I just assumed there was a reliable source or two out there since I read threads about bad ram or black screens on XL computers the response is usually to replace the ram. I perhaps improperly assumed that meant replacement chips were easy to find.
It's stuff that was probably not made beyond 1995. Chances are there would be dwindling NOS stocks, and a reasonable supply of salvaged ICs.
From what I've seen, prices are mostly affordable. But the price per Megabyte is and will probably stay such that for larger upgrades like 512K upwards it can be cheaper in reasonable volumes to just design and manufacture boards that use modern day SRams.
I wonder if one of the modern ram upgrades might be the better way to go instead of replacing old ram chips with more old ram chips.
In the context of reliability I think replacing the rubbish MT that later machines were infested with, with NOS or even used reputable brands of the day is fine.
Where the modern day upgrades shine is that they generally eliminate the rats nest of added wiring for some of the upgrades which in themselves become an easy point of failure.
One company I'd recommend if you're willing to buy from China is UTSource. I checked their prices recently and they seem as cheap, and often cheaper, these days as those who are on AliExpress. Whenever I have bought from UTSource in the past, the parts have been well packed and in excellent condition ... obviously NOS. The same can't be said about vendors on AliExpress. A few times I've ended up putting in a claim because the parts were in such poor cosmetic condition. AliExpress vendors tend to just wrap them up in cellophane, which is a pain to extract from the pins without bending or breaking them.
https://www.utsource.net/sch/HM4864P-2 - as an example.
TMS4164-15NL 16-Pin
Have you ever put them in an Atari 8-bit computer? If so, did they work?
UTsource, sometimes it's reclaimed stuff though, but it passes all the tests. If anything is wrong, I've had the part replaced or refunded without a hitch..
Edited by _The Doctor__
Yup! Saved a few 65XE's with these. No reason they shouldn't...
For reference from approved vendor list that I found (dated Dec. 8th, 2003)
PART
NUMBER DESCRIPTION
Edited by NISMOPC
PART
NUMBER DESCRIPTION
This is a great list, but do some of these require the newer ANTIC? CluaseB was saying that those 64x1s that have 256 cycle refresh, need the new ANTIC. The 400, 800, 1200XL and initial 600/800XLs had the older ANTIC. Later 600/800XL and XEs have the newer ANTIC. Does this list apply to the newer ANTIC?
For example: TI TMS4164-15NL are 256 cycle refresh. Will it work in a 1200XL with the older ANTIC?
Edited by ACML
If you'll use the additional refresh bit circuit to
allow for the use of the older ANTIC then yes, they
can be used. Otherwise, no.
Thank you for the clarity on this. What I learned;
[1] 64Kx1 DRAM with a 256 cycle refresh requires the newer 8 bit (counter) ANTIC.
[2] 64Kx1 DRAM with a 128 cycle refresh can use either version of the ANTIC
Without opening the system, is there a way to tell which version of the Antic one has? Of course now that I think of it, if you're trying to replace ram on a black screened 800xl it's a redundant question.
You just repeated the same, same as before.
So it sure sounds like you learned nothing from my
'clarity'? :)
You can use either ram with either ANTIC if you
will supply a refresh circuit for older ANTIC
when using them with 256 cycle refresh ram.
AtariLeaf, not redundant at all. Of course, if already
under the hood all you need to do is look at the
number on it, but as to a way to discover the difference
without looking, I do not know of a way. And it's a good
question.
Refresh bars on the left side of the RF picture can
be seen - has anybody counted them in a side by
side compare before? I sure haven't, not too sure as
to what I'm looking for either. One of those things
I never got around to actually doing. Finding an old
ANTIC, finding a new ANTIC and the work of recording
a difference in the RF screen they make. And I may not
understand the issue well enough myself in the first
place - the difference may not show itself here as I
can only imagine it might. Don't have a working Atari
station as it were.
