R0ger
2 button joystick ?
I often use a nail or something similar to make a dimple in the center before drilling. You want something for the drill bit to start in to keep it centered.
6 hours ago, biobern said:
Maybe this drill will produce less melting plastic cause it only cuts a circle?
https://www.idealo.de/preisvergleich/OffersOfProduct/494089_-lochsaege-30-mm-2608584623-bosch.html
Maybe with fixed drill, but in hand this drill is totally unusable. It's also somewhat rough, it's usually intended for dry wall.
Not appealing to 400/800/XE/XEGS owners, I think something less model specific might work better
You can always just buy an existing donor controller/joystick for any system, and replace hardware/wiring as you please (versus trying to find a project enclosure that may work):
This was originally a Sega Saturn controller that looked like this:
That way you end up with a good looking controller, and it will be big enough to provide adequate hand/wrist support when playing.
If you're drilling a hole with a hand-held drill (any type of bit) there is always going to be some amount of "walking" of the bit no matter what you do, but a center-punch can help with the starting of your small pilot bit.  I use a CNC we have at work for most of my projects, but for 1 off designs where I don't want to bother to program the CNC, I'll print an actual-size layout template, transfer the hole center points and use an electric/hydraulic knock-out punch for the joystick/pushbutton holes.
That's great work! How did you do the wooden surface?
Normally, I'd say that modern fighting sticks look too big for our little Ataris. And "just not 80s enough". But this one looks marvellous!
Bern
Wow! But not an easy printout!
Edited by biobern
Bern
For the wood grain CPO...I had used some adhesive-backed wood grain vinyl for another project I did.  So for this one I scanned in at 600 dpi, a large 11"x17" sample of that vinyl, then high resolution photo-printed and heat laminated it.  In my opinion, this donor controller/housing, at approximately 11.75" wide x 9.25" deep, is about as small as I would say is comfortable for a table/lap top arcade stick.  Too much smaller and you end up with something like this:
...where your hands/wrists/palms have no support, hang off of the edges, or have to hover in mid-air to use.  Not to mention, a little extra size always adds a little extra weight so that the controller doesn't feel so cheap and flimsy.
Absolutely right! I don't understand why so many fighting sticks do not mount the buttons near the backside. (there is a reason however not to mount the _joystick_ near the backside, because the case could tilt if you can't use the wrist-rest for some reason.)
