+Larry Posted February 24, 2022 Share Posted February 24, 2022 Thanks! I will try it. I may have an original FM800 around here, but I'm not sure. I got a s-load of Atari soft and hardware years ago, and think I remember seeing it in there. But packed away, for years. Edit: Yes, yours appears to work 100% of the time with Translator A. I tried the Atarimania ATR, and it sometimes works, and sometimes it hangs when loading the Create module. Using APE, BTW. I also got motivated and found my original FileManager+, and it hangs 100% of the time at the same point. I have a little note on the disk (Version 4C) -- "needs 810 drive." I don't understand that, but that's what my note says -- from many years ago. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted February 24, 2022 Share Posted February 24, 2022 56 minutes ago, Larry said: I have a little note on the disk (Version 4C) -- "needs 810 drive." There are some types of bad sectors which return different error codes and lead to an 810-exclusivity of the disk if only this specific error code is allowed by the protection code. But I did not find anything like this of Filemanager. Just our of curiosity a 4C image for you to test: Filemanager+ v4C (1981)(Synapse Software)(US)[BASIC][OS-B][cr CSS].atr 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted February 24, 2022 Share Posted February 24, 2022 4C behaves similarly to the Atarimania version. Sometimes it works; sometimes it hangs. 4D has yet to hang. I've loaded it maybe 6 or 7 times. That's a bummer about my original disk. I gave my last 810 away maybe 25 years ago. Edit: I have tried the Atari Translator Side B (supposedly like OS A) with much better success with version 4C. It appears to work reliably -- 5 out of 5 loads were successful. Now to try some things with my original disk! Quote Link to comment Share on other sites More sharing options...
