MrFish
Mr. Do - Graphical Improvements
One of my top 5 Atari games. A nearly perfect arcade port, with great attention to detail. I never thought it needed much polishing;
but now that I've had a bit of a closer look, I can see there are plenty of things that can be done to make it an even better port.
A great example of using character-based softsprites; one of the best from BITD, I'd say. There are a few minor slowdowns when
the action gets heavy; but Tim Ferris did a remarkable job.
For starters, I wanted to get rid of that 1st level background pattern. The black that was in it caused interference with the stems on
the cherries, and wouldn't help the cherries I've designed here either. So then, of course, I've changed the apples and cherries;
getting them closer to the arcade graphics.
This hack will take a while, as there are a lot of animations and other graphics to work on. Plus I'll be adding some title/marquee
and possibly other splash graphics.
I haven't decided what I want to do with the hi-res font lines yet. Obviously these aren't so great for PAL; but at least the upper ones
(artifacted graphics) have some meaning to what's going on in the game. They could be switched to Antic 4, which would solve the
problem.
I'll start posting binaries once some significant changes have been made.
Edited by MrFish
  • Like 13
This was a port that was done right - I stumbled across Mr Do on MAME and when I played the 8bit version I couldnt believe how close to the arcade was - this simply wasnt done back when Mr Do came out. Interesting to see how you can make a great port even better.
I never really played Do back in the arcade days. I remember watching people play it, and I probably played a game or two at times. But recent years (since 2005) was really my introduction, and that on the Ataris. Since I love Dig Dug, Do is just Dig Dug on steroids. It's one of the few games that enticed me to play in the high score club once. I got second place, but I guess Fandal is a pro; although he's playing at PAL speed, which would make a difference; and I never tried that.
Mr. Do! (High Score Club)
Edited by MrFish
Here's something a lot of people might not be aware of in Mr. Do!
When you start each level, the initial path that's carved is in the shape of the level #.
It becomes more apparent when zoomed out.
The first level is a "D" for "Do".
This is from the arcade version, but the Atari version follows it also.
Edited by MrFish
  • Like 12
I'd never noticed before either, until about 5 years ago when I saw those thumbnails on the Wiki. Interestingly,
I didn't read it on the Wiki, and I don't see where they mention it anywhere either (although I haven't combed
through the Wiki completely). It must be mentioned on some websites out there; as I'm sure I'm not the first
one to notice it.
Edited by MrFish
Doh! I never noticed but it's less obvious on the A8 version and I didn't like the arcade version. The shrill sounds were off putting. And now with my 60 yr-old (almost) reflexes I don't like the frenetic pace of that version.
I'm very comfortable with the more "tactical" pace of the A8 version. :D
-a8isa1
The A8 version is a little easier than the arcade. It feels a little less cramped than the arcade too; maybe a lower sprite size to playfield ratio.
The diggers guys (whatever they call them) are a more active on the arcade version (at least in the early levels), which makes a big difference.
And then the dynamics are somewhat different, having a wide playfield as opposed to a tall one. I like both versions though; it's just a fine game.
I love the DO! It really enjoy the Atari version, It's one I come back to time after time. It should be interesting to see it graphically tweaked to be even more arcade like. I had no complaints, and that's what makes it a tough bit of work to improve on.
Mr. Do! (the clown) is at least as cool as (spaceman?) Dig Dug.The enemies in Do! are maybe not as memorable as Pooka and Fygar,
but the gameplay in Do! more than makes up for any lack of cuteness in the enemies; and the cool bonus system gives you an "EXTRA"
goal to achieve, above points totals and conquering levels.
A little good news is that Do! himself is made of P/M's. I thought he might be playfield, since he was using the same colors.
So, they decided to make him the same red as the playfield, which I think is a mistake. The same thing was done in the
original version of Donkey Kong, with jumpman (mario). If his color is at least slightly different, it will help make him stand
out and add color to the whole display.
They chose (for NTSC) what I like to call the ketchup or tomato paste red, as opposed to the more fire engine red. I'm
thinking they chose that because it allows PAL machines to have the more fire engine red. It's kind of a lazy method of
accommodating PAL and NTSC, since there are a number of variations for each color (i.e. several greens, several blues,
etc.), and they can get them both in the same ballpark by shifting a color here and there.
That being the case, I may just end up doing a separate version for NTSC and PAL.
Here's Do! in fire engine red and maroon. The maroon is kind of nice, because it lets him stand out more when the blue
guys start marching and the screen goes red. It's also possible to use a more non-standard color for him; but I'd like to at
least stay near to the arcade.
These shots also show some of the font changes I've done so far, and how they look with artifacting set to how it is on my
800XL.
Red Do!
Maroon Do!
Edited by MrFish
  • Like 7
The same thing was done in the original version of Donkey Kong, with jumpman (mario).
I should clarify here: I'm talking about the original Atari version of Donkey Kong. But I'd forgotten that I found out it wasn't
as bad as I initially thought. My initial impressions were coming from emulation (I didn't have this game BITD), before I
started using real hardware after returning to using the 8-bits here in the 21st century.
So, they actually did do what I'm talking about here, which is give jumpman (mario) the fire engine red, while making the
playfield use the ketchup red. I didn't find out until I played it on real hardware, and later when I used emulators with better
NTSC color palettes (Altirra). So they had the right idea, but they did use a blue that was closer to the playfield blue than
what they could have. That would have given jumpman (mario) a little better distinction from his surroundings. [Note: the
yellow on mario was playfield, so no way of getting around that with the given constraints.]
This is one of the best games on the a8 - thank you for doing this :)
Totally agree with you here. I think I put more hours into this than any other game.
Here's what all the Atari levels for Do! look like zoomed out.
Pretty close to the arcade for carving out the level #'s, aside from being a little squished vertically.
  • Like 4
Great job MrFish ! Cant wait for a work in progress download !
What tool are you using to edit character-based soft-sprites ?
I absolutely love the 8-bit version and these little improvements make it even better.
Now if someone can remake a homebrew version on the 2600 to replace the original abomination I'd be forever in their debt.
Love the work MrFish, as always top stuff but what has floored me more is the revelation (to me) about the map numbers..
Me and a mate LOVE MrDo, he plays it constantly and got the who strategy down to a T but when I said about the level numbers being part of the map he was as blind as I was :)
Can't believe I never noticed something so right in my face...
D'oh!!
