BillC Posted January 25, 2021 Share Posted January 25, 2021 (edited) 1 hour ago, vinniet said: On the picture I have included I have numbered the leads. Can you let me know which two are ground? As 2 of them are supposed to be ground you could check for continuity between them, the 2 that are connected would be ground. Edit: Viewing the PCB images in post 1 I can see that the inside pins(2&3) are connected to the ground plane, while header pin 1 connects to socket pin 27 and header pin 4 connects to socket pin 1. Edited January 25, 2021 by BillC 1 Quote Link to comment Share on other sites More sharing options...
vinniet Posted January 26, 2021 Share Posted January 26, 2021 17 hours ago, BillC said: As 2 of them are supposed to be ground you could check for continuity between them, the 2 that are connected would be ground. Edit: Viewing the PCB images in post 1 I can see that the inside pins(2&3) are connected to the ground plane, while header pin 1 connects to socket pin 27 and header pin 4 connects to socket pin 1. Thanks .. what I thought. Did not think of checking for continuity. Quote Link to comment Share on other sites More sharing options...
JGRAHAM2 Posted March 19, 2021 Share Posted March 19, 2021 On 4/21/2020 at 12:42 AM, BillC said: The DP4T rotary switch below looks small from the images, unable to confirm but think the pin spacing is likely 0.1". It's the only one I can find at a reasonable price that's easy to mount. https://www.ebay.ca/itm/2PC-10mm-DP4T-Rotary-Switch-Double-4-Position-15mm-Knurled-Shaft-PC-Mount-Switch/111989402572?hash=item1a1316abcc:g:SaEAAOSw9etXQYf- I bought these and they work great both in size and function. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted May 26, 2021 Share Posted May 26, 2021 I have 30 of these 4xOS PCB's onhand. It might be a while before I get a chance to build them up, so in the mean time I'm making these available if you're handy with a soldering iron. Actually I can probably throw in the headers, socket, and resistors too. Extra if you need a programmed EPROM. -- $5ea, postage $2 Canada/USA, $3 International Or wait until I have some more assembled. Quote Link to comment Share on other sites More sharing options...
vinniet Posted July 17, 2022 Share Posted July 17, 2022 On 5/26/2021 at 2:21 AM, Nezgar said: I have 30 of these 4xOS PCB's onhand. It might be a while before I get a chance to build them up, so in the mean time I'm making these available if you're handy with a soldering iron. Actually I can probably throw in the headers, socket, and resistors too. Extra if you need a programmed EPROM. -- $5ea, postage $2 Canada/USA, $3 International Or wait until I have some more assembled. Do you have extra pcb board assembled? I bent pin and it broke off. Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted July 18, 2022 Share Posted July 18, 2022 On 7/16/2022 at 8:13 PM, vinniet said: Do you have extra pcb board assembled? I bent pin and it broke off. Sorry for delayed response - PM sent! Quote Link to comment Share on other sites More sharing options...
