redsteakraw Posted February 22, 2019 Share Posted February 22, 2019 so my Atari 2600 4 switch woody's left joysick up stopped working I tried multiple joysticks and the up direction doesn't work anymore. I have the pictures of the board what should I do? Now that I have the board out what would you do? I can solder but I don't know where to start. Also should I clean the board and how should I clean it up? Quote Link to comment Share on other sites More sharing options...
fluxit Posted February 23, 2019 Share Posted February 23, 2019 You checked that all nine pins are still there in the port, right? Up is pin 1, which is leftmost on the upper row I believe. Quote Link to comment Share on other sites More sharing options...
SoundGammon Posted February 23, 2019 Share Posted February 23, 2019 Pin 1 goes to pin 8 of the 6532 RIOT chip, check continuity between them. If open, bad trace, if good bad 6532 RIOT chip! Quote Link to comment Share on other sites More sharing options...
