DavidMil Posted April 21, 2019 Share Posted April 21, 2019 I have three 1050 drives. Two work beautifully and the third one works fine except: It will not format disks with DOS 2.5. It formats fine with MYDOS and the other two drives can read disks that it formats and writes in MYDOS, but it can't format in DOS 2.5. If I format the disk on one of the other drives, I can then read and write to the disk in the third drive without any problems, and both of the good drives can read what the third drive has written without any problems. I also ran the 1050 CPS disk several times through the test loops without any problems. I'm stumped. DavidMil Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted April 21, 2019 Share Posted April 21, 2019 Reading this, I think of a past post by tf_hh "HowTo: Adjust analogue part of FDC 279x in a 1050 disk drive" about the http://atariage.com/forums/topic/282626-howto-adjust-analogue-part-of-fdc-279x-in-a-1050-disk-drive/ The typical issues: - When the adjustment is absolute out of specs, you can´t successfully format or write to any disk. Reading might be okay - When the adjustment is nok ok, but not totally worse: Formatting and writing a disc with medium/enhanced/double density fails, but single density works - At all cases: You might can write format and write a disc with medium/enhanced/double density flawless, but no other drive can read your formatted discs... The symptoms seem to partially match, but you indicate you can still write to the disk in the 'bad' drive after formatting medium/enhanced/double density in another drive... Was the mech swapped to that drive/motherboard from another drive? Quote Link to comment Share on other sites More sharing options...
DavidMil Posted April 21, 2019 Author Share Posted April 21, 2019 Was the mech swapped to that drive/motherboard from another drive? That brings up a good point, Let me swap the drive mechanisms with one of the good drives and see which part the problem follows. Thanks, David Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted April 21, 2019 Share Posted April 21, 2019 Looks like you'd need a good oscilloscope to measure the 3 test mode frequency pulses being provided to the FDC chip, for potential adjustments to TP10, TP11, and R3. Write precompensation output (pin 31) / TP11 affects double density, MFM mode. Re-reading tf_hh's post, the concern isn't if the MECH was changed but if the FDC chip was changed (WDC 2793 or WDC 2797). Those three adjustments are factory tuned to the FDC chip originally installed on the PCB. Quote Link to comment Share on other sites More sharing options...
DavidMil Posted April 21, 2019 Author Share Posted April 21, 2019 Well, I'd have lost money on this bet... I was sure it was an problem with the transport, but when I switched it with one of my known good 1050's it worked beautifully. And the problem stayed with the printed circuit board. So I pulled the metal housing off and found an Hitachi HN462732G EPROM with a sticker that said, " TANDON REV K". The Controller is a Western Digital WD2733PL-02. I've included a couple of pictures. I'm open to suggestions here? DavidMil Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted April 22, 2019 Share Posted April 22, 2019 Are you sure the WDC is 2733? It should be 2793 or 2797. In your pictures I can barely make out anything on that chip, I presume you're having similar difficulty. It's probably 2793, since 2797 only works with ROM rev L... 2732 eprom should be fine... it's working with single density so I'm not concerned about the ROM. couldn't hurt to try a Rev L, but unlikely it will make a difference. The issue only impacting DD still points to the 3 adjustments I mentioned previously being out. You could try the WDC 2793 chip from another PCB to see if it helps, but make sure to put it back in it's original PCB after since the adjustments on the PCB are tuned to the chip originally installed. Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted April 22, 2019 Share Posted April 22, 2019 The Controller is a Western Digital WD2733PL-02. So, looking at your picture and comparing to a chip of mine, the top line of yours is definitely "WDC'82" But the rest is illegible... Can you confirm? A similar chip in a drive of mine reads: WD2793A-PL02 I wonder if it's possible to measure the variable capacitor value to compare between boards. The other 2 trimpots may be easy with just a multimeter to read resistance... Just to see if one of them are way out of whack compared to another drive. An excerpt from the 279x datasheet that coroborates tf_hh's 1050 specific additions: Also mentioned on that thread how most people have found 1050's configured with a 230KHz data rate, rather than the 250Khz suggested in the datasheet, plausibly due to the reduced RPM 288 vs standard 300... 1 Quote Link to comment Share on other sites More sharing options...
E474 Posted April 22, 2019 Share Posted April 22, 2019 Hi, I did this with an old analogue oscilloscope, but it was right at the limit of the oscilloscope's sensitivity. In the end, I took photos of readings from a good drive, and adjusted the suspect drive until it matched. This seemed to work. 3 Quote Link to comment Share on other sites More sharing options...
E474 Posted April 22, 2019 Share Posted April 22, 2019 Hi, I did this with an old analogue oscilloscope, but it was right at the limit of the oscilloscope's sensitivity. In the end, I took photos of readings from a good drive, and adjusted the suspect drive until it matched. This seemed to work. Quote Link to comment Share on other sites More sharing options...
DavidMil Posted April 23, 2019 Author Share Posted April 23, 2019 Are you sure the WDC is 2733? It should be 2793 or 2797. In your pictures I can barely make out anything on that chip, I presume you're having similar difficulty. It's probably 2793, since 2797 only works with ROM rev L... 2732 eprom should be fine... it's working with single density so I'm not concerned about the ROM. couldn't hurt to try a Rev L, but unlikely it will make a difference. The issue only impacting DD still points to the 3 adjustments I mentioned previously being out. You could try the WDC 2793 chip from another PCB to see if it helps, but make sure to put it back in it's original PCB after since the adjustments on the PCB are tuned to the chip originally installed. I answered this yesterday but my post seems to have disappeared. Who knows, maybe I forgot to POST it after I finished. I used a large magnifier and a set of 6x glasses and I can barely see that it is a 2793 chip. Since then I found the problem to be in the controller chip. Suspecting that the problem was the EPROM Rev K, I swapped it out first but nothing changed. So I swapped out the controller with a 'new' chip from Best and the drive formats fine except it was is having problems reading disks it didn't write and the other drives have problems reading the disks it formats. I took the rev L chip out and put the rev K back in and it is better but still having problems reading the outer tracks of disks written by other drives. I'm guessing it needs to be realigned now? David 2 Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted April 23, 2019 Share Posted April 23, 2019 ...it is better but still having problems reading the outer tracks of disks written by other drives. I'm guessing it needs to be realigned now? By 'outer' do you mean tracks 0-19, or 20-39? Write pre-compensation for MFM (double density) operation only kicks in on tracks 20-39 to "pre-compensate" for the increased physical density on the inner tracks. To me that behaviour further supports that the write precompensation variable resistor is too far off spec from 230ns... It's adjusted at R3, and measured at TP11 (pin 31 on the WDC controller) It could also be that your other drive is out of spec, causing the disk to be not readable in this one... Quote Link to comment Share on other sites More sharing options...
DavidMil Posted April 24, 2019 Author Share Posted April 24, 2019 By 'outer' do you mean tracks 0-19, or 20-39? Write pre-compensation for MFM (double density) operation only kicks in on tracks 20-39 to "pre-compensate" for the increased physical density on the inner tracks. To me that behaviour further supports that the write precompensation variable resistor is too far off spec from 230ns... It's adjusted at R3, and measured at TP11 (pin 31 on the WDC controller) It could also be that your other drive is out of spec, causing the disk to be not readable in this one... 20 to 39. But there is something very wrong with that CB. Many chips and resistors and the larger electrolytic caps start getting very warm to darn right hot if the power is left on for awhile. I'm going to have to see where all that current is coming from. Maybe a bad vreg. The power supply is good as I've been using it on my 850 for some time. I hope it hasn't damaged anything else. I'll let you know. David 1 Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted April 24, 2019 Share Posted April 24, 2019 the modern drop-in replacement "switch mode" voltage regulators work well in 1050s - really keeps the heat down! (theyre also known as "buck converters", but i would advise against the variable output voltage types) Quote Link to comment Share on other sites More sharing options...
DavidMil Posted April 26, 2019 Author Share Posted April 26, 2019 Ok, here's what I have currently... U2 and U3 were getting so hot that when I wet my finger and touched them the moisture started to bubble. Also U7 (the 6532 chip) was very hot. Placing the 6532 chip in another drive yields a dead drive till the original 6532 chip was reinstalled (but no heat). The controller chip seems to have been damaged too. R56 was also very hot! With those four chips removed nothing gets hot and I'm getting a rock steady 12V and 5V from Q8 and Q7. I've ordered replacements from Best and I've socketed U2 and U3 so I'm going to try replacing the four chips (starting with U2 & 3) and watch to see what happens. Could the stepper motor have a short that's drawing all that current? David 1 Quote Link to comment Share on other sites More sharing options...
1050 Posted April 27, 2019 Share Posted April 27, 2019 More likely you have the jack installed backwards. Or somebody else did and that is what pooched the U2/3 chips. But the windings ohm out at 30ish for all four with 5 and 6 pins being common ground. Use an ohm meter and find out if it's shorted. It sounds like you've got your problem pinned down at the very least and that's half the battle anyway. 1 Quote Link to comment Share on other sites More sharing options...
DavidMil Posted April 28, 2019 Author Share Posted April 28, 2019 (edited) R More likely you have the jack installed backwards.Or somebody else did and that is what pooched theU2/3 chips. When you say 'jack', are you referring to J15? Remember that this drive worked ( well, mostly worked) for awhile when I first tried to use it. Then I could smell the burning and it's been dead ever since. I don't think that removing the EPROM and putting a ROM in there for a few seconds before I remembered the jumpers that needed to be changed would cause this problem. With either chip in the drive it started heating up. When I get the replacements for U2 & U3, I'm going to try turning it on with J15 disconnected. (That's after I ohm out the stepper motor). David Edited April 28, 2019 by DavidMil Quote Link to comment Share on other sites More sharing options...
DavidMil Posted April 28, 2019 Author Share Posted April 28, 2019 The problem is the stepper motor! I pulled the transport out and plugged it into one of a good 1050. As soon as I turned on the drive the stepper motor started vibrating back and fourth maybe a mm and everything started getting hot! I guess the motor started dying when I first discovered the problem and has now died totally. Anybody know where I can get a MSAF200A91 Sanyo Part # 4Z26 12V DC stepper motor? David Quote Link to comment Share on other sites More sharing options...
1050 Posted April 29, 2019 Share Posted April 29, 2019 Yes, J15. You still could be still plugging it in backwards from the times it did work right. And my bad. Pin 5 and 6 of the jack goes to 12+ rail not ground. Seems to be certain death for U2 is in store if the jack is used backwards. Can't imagine what could be wrong inside the motor that would make it do that. Did you ever do the reasonably careful thing and ohm it? Short look for the number brought up only german eBay. Doesn't look good for a replacement. Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted April 29, 2019 Share Posted April 29, 2019 Does the stepper manually turn? Either by plyers on the wheel itself, or moving the head by hand? I know you previously said it was working but not on the higher tracks... I've received drives with steppers that were seized from years of non-use, but yours seems to have degraded *with* use... Quote Link to comment Share on other sites More sharing options...
