mamejay Posted May 14, 2019 Share Posted May 14, 2019 Hey everyone, I am looking at making a few SIO cables using 3D printed parts. Just need to order some of the Molex crimp terminals. I found these which look correct. Can someone confirm? https://www.ebay.com.au/itm/Lots-Terminal-Crimp-Pin-For-Fan-Connector-Plug-Molex-KK-Style-2510-2-54mm-PC-Mod/283084312616?hash=item41e923d028:m:mW9KwFWUAmh_cHIRtFGzsPw&frcectupt=true Thanks Quote Link to comment Share on other sites More sharing options...
E474 Posted May 14, 2019 Share Posted May 14, 2019 Hi, You need the 3.96 kk Molex connectors. 2 Quote Link to comment Share on other sites More sharing options...
Gavin1968 Posted May 14, 2019 Share Posted May 14, 2019 For the hundreds of cables I have made, I use MOLEX 08‐50‐0105. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted May 14, 2019 Share Posted May 14, 2019 For the hundreds of cables I have made, I use MOLEX 08‐50‐0105. What are you using for the cable? Quote Link to comment Share on other sites More sharing options...
mamejay Posted May 14, 2019 Author Share Posted May 14, 2019 What are you using for the cable? Going to be making a couple of SDrive-Max devices for a local computer group here in Australia. I know you can get ready made connectors but I like to do things the hard way Quote Link to comment Share on other sites More sharing options...
Gavin1968 Posted May 15, 2019 Share Posted May 15, 2019 What are you using for the cable? Some wire I found on Amazon. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted May 15, 2019 Share Posted May 15, 2019 Some wire I found on Amazon. I usually can't find enough conductors or the right thickness, would be curious of the source of yours Quote Link to comment Share on other sites More sharing options...
E474 Posted May 24, 2019 Share Posted May 24, 2019 Hi, What connectors did you end up ordering, and how did they work out? Quote Link to comment Share on other sites More sharing options...
mamejay Posted May 25, 2019 Author Share Posted May 25, 2019 Hi, What connectors did you end up ordering, and how did they work out? I ended up grabbing these. Have not received them yet but they should do https://www.ebay.com.au/itm/CH-3-96MM-Pitch-Crimps-Connectors-Terminals-Molex-Contact-Plug-Socket-PCB-Copper/254187025602?hash=item3b2eba34c2:m:mZOL-exyk7owx4yP9tFYw8g&var=553553374570 Quote Link to comment Share on other sites More sharing options...
