twoodland Posted May 29, 2019 Share Posted May 29, 2019 Good day everyone, I have a friend who contacted me recently. She dug her SX-64 out of storage that she bought new to run some games that she enjoyed playing some years before. She turned it on, and only gets a black screen (well, she described it as a white screen because she turned up the brightness when it didn't display anything). I told her that I would look at it, so I drove over to check it out. I confirmed that it displayed a black screen, no garbage. When I took the cover off, the rail on the right (from looking from the back of the unit) was broken. I asked her if she or anyone had it apart, and she told me that to her knowledge it had never been opened. The inside looked all original and I did not see anything that had been replaced. I spent some time cleaning it and checking all of the wire and board connections. I started to re-seat the socketed chips. The CPU board is a Rev A and I noticed that the 6510 MPU (ceramic type - original?) had thermal grease on the legs. I took it out and saw that the rightmost bottom leg (2?) was bent under the chip not inserted into the socket. I carefully straightened the leg and re-inserted it into the socket. No Change in symptoms. I tried taking out the SID, no change. I swapped out the PIA, no change. I swapped out the Kernal, no change. I am unable to locate a MPU to swap it out and I do not have the diagnostic cart & cables. Does anyone know where I can get a replacement MPU? If I can get a replacement and if it does not fix the issue, what should I try next? Does anyone offer diagnostic services? Quote Link to comment Share on other sites More sharing options...
adam242 Posted June 4, 2019 Share Posted June 4, 2019 I've owned two non-working SX-64s with the same blank screen. Both had bad PLA chips. Attached is a document I've found helpful troubleshooting and repair. sx64.txt Quote Link to comment Share on other sites More sharing options...
