globeron
Mechatronic 80 Column Card (Side Card)
Mechatronic 80 Column Card (9-pin) RGB interface  to SCART/RGB plug
Pin 1 = Ground     to  Pin 18 is Composite Input "Ground" / Sync input "Ground"
Pin  2 - not used
Pin 3  = Red         to Pin 15
Pin 4 = Green       to Pin 11
Pin 5 = Blue          to Pin 7
Pin 6 - not used
Pin 7 = +5V ("RGB trigger") to Pin 16 Fast Switching
(if you get Black and White / Grey pictures, probably you still use Composite and it is not triggered to use RGB)
See:
https://www.retrogamingcables.co.uk/trouble-shooting-guide-for-rgb-scart-cables
https://en.wikipedia.org/wiki/SCART#Blanking_and_switching
Pin 8 = Synchronization TTL (Transitor Transitor Logic)  to Pin 20 Composite video input / Sync. input
Pin 9 - not used
Audio - Need to come from the 6-DIN plug (European consoles) or 5-DIN plug (USA consoles)
and need to go to
5-DIN Pin 3 Audio to  Pin 2 - Audio input Right
5-DIN Pin 3 Audio to  Pin 6 - Audio input Left
(Combine Pin 3, as the TI-99/4A is mono audio output)
https://justinpaulin.com/2014/04/21/testing-a-texas-instruments-ti-994a-without-power-or-video-cables/
Use Pin 2 = Ground to  Pin 4 Audio Ground
For Audio on a Europen console (DIN-6)
6-DIN Pin 5 Audio to  Pin 2 - Audio input Right
6-DIN Pin 5 Audio to  Pin 6 - Audio input Left
Use Pin 6 = Ground to  Pin 4 Audio Ground
Edited by globeron
  • Like 4
TIPI and CRU?
To connect the TIPI to the Mechatronic 80 Column Card, the CRU (Communication Register Unit)
address had to be changed (it did not work on the TIPI somehow, but I changed DIP Switch 3
last pin (and no clue which CRU address it is now. Default is >1000, and advised not to change it
according the Mechatronic manual. (Is TIPI also is using CRU >1000 ? when the jumper is on the
bottom two pins, see the video)
I tried to move the jumper between pins on the left side pins, without a working result
https://github.com/jedimatt42/tipi/wiki/crubase
According this the TIPI  CRU base is at address  >1100
https://github.com/jedimatt42/tipi/wiki/tipi-installation
Does someone know a program to see all the CRU occupations ?
(in an easy to understand format ?)
With the TIPI connected, I can save programs to the TIPI (DSK2.80XBTEST)
Mechatronic 80 Col. Card - demo of 26 rows (= Max.) and 27 rows
(note that row 26 gets refreshed when reaching row 27 and if you do more rows
you see it blinking)
https://www.youtube.com/watch?v=hqIzsAoGQLA
The left button is used (pressed) to fixed the screen-mode in case it is locked-up
in the graphical mode. Sometimes just enter something like 1 REM  (ENTER) and
it also switches back to text mode.  Sometimes it is locked up, then remove all
power of all devices (remove power from the TI-99/4A, Mechatronic 80 Col. card,
remove power from the 32K + TIPI, etc.), wait for a few seconds and start-up again.
Hi Ronald,
a fine card you have. I'm still waiting for the next F18A/mk2 for two of my TI systems.
Attached is a EA5 Program to scan all the CRU adresses in your TI-system.
DSRSCAN
After loading the program DSRSCAN you see the first used CRU adress and some more informations about the device.
with selection 5 you change to the next CRU adress til the last used adress.
With the selection 6 you go back to the previous CRU adress.
Regards
Wolfgang
8 hours ago, wolhess said:
Hi Ronald,
Regards
Wolfgang
Thanks Wolfgang!
The TIPI is on CRU >1000 and the Mechatronic 80 Col on CRU >1100
IMG_20190621_011003.thumb.jpg.7d14b3636bfa15190bef283310b7adf1.jpgIMG_20190621_011049.thumb.jpg.7fe88bc18b60b167dd0a66542680fc05.jpgIMG_20190621_011033.thumb.jpg.fd942af6a3f6ff6b6a534264f681b199.jpgIMG_20190621_011021.thumb.jpg.ca17342c852ce0d5d297c63544be9596.jpg
Thanks Greg, that was my next step to connect the CPS9900 to the system.
See also: https://github.com/jedimatt42/tipi/wiki/crubase
I just checked all the Dip Switch 3 pins (as it is not documented)
DipSW3 has 4 pins.
If all are pushed to the top it is "ON" = 1
(just opposite as the table of jedimatt42)
1111 = >1000   Used by TIPI (on 32K of Jedimatt) / Hard & RAM drives
1110 = >1100   TI / Corcomp / Myarc FDC / Atronic CPS9900 (Floppy Disk Controller)
1101 = >1200   Mechatronic 80 Column Card
1100 = >1300   RS232-1/2
1011 = >1400   128 KByte Speichererweiterung mit Centronicsschnittstelle  (128K Memory Expansion with Centronics Interface)
1010 = >1500   RS232-3/4
1001 = >1600
1000 = >1700  Hexbus (for TI-99/8 and CC-40 and similar)
0111 = >1800
0110 = >1900  Myarc 512k Memory
0101 = >1A00
0100 = >1B00
0011 => 1C00
0010 => 1D00  Triple Tech Clock  (CorComp)
0001 => 1E00  SAMS (Memory)
0000 => 1F00  P-Code  (UCSD Pascal)
http://ftp.whtech.com/datasheets and manuals/Hardware/Mechatronic/mechatronics 80 column peripheral manual.pdf
It is curious that Mechatronics manual says that for 'error free' operation of the card the crubase must be '>1000'
There are the special DSRs for manipulating the color palette or printing to the 80 column screen. That manual doesn't say what fails to work correctly if running at a crubase other than '>1000'
[email protected]
Oh, one interaction with VDP RAM is in the floppy controllers, ( or TIPI when running at >1100 ) as they adjust the stack pointer in VDP to allocate space for open file buffers. This is done in the controller's power-up routine.  Power-up routines are executed in order of crubase.
Do we have a rom dump for this card? it would be interesting to look at the DSR header, and see if there is a power-up routine, and read what that power-up routine actually does...  It would let us know why the docs say this actually has to be at crubase >1000 for proper functioning.
[email protected]
[email protected]
I also noted it, but it seems to work fine so far on other CRU base
As the 80-Col. and console are my fathers' one, I swapped them today
(my card has a power switch and Dipswitch 3 are red. Also the startup
is a bit different, it does not go through another screen Sync. Cycle
and the EEPROM might have different versions as well.
Not sure about the ROM-dump or how to do it.
(let me know the normal procedure or other ways
Finally, made the complete cable including audio
* video comes from the Mechatronic 80 Column card. to SCART/RGB
* Audio from the TI - USA version console 5 DIN-port Pin-3 (Audio) and Pin-2 Ground to the SCART/RGB (pin 2 - Audio In Right channel and Pin 4 Audio Ground)
Yesterday I swapped the Mechatronic 80 card and TI-99/4A as they are my father ones
(and got my own system back, see other upcoming videos as the card has an on/off switch
and the DipSwitch 3 has red switches).
Here is my father's system in action:
More videos where I tested combinations with Atronic CPS99 system (32K + Diskdrives + RS2323)
Mechatronic 80 Column Card, Mechatronic 128K Ram (32K + 3x 32K banks to store files. DSKR + Centronics "PORT" (PIO))
1.
2.
3.
My card with a Power On/Off switch
1. Dip Switch Bank 2, the 2nd switch (Keyboard Interrupt need to be in OFF position to use the left key
    to correct from graphics mode to normal mode). It is written wrong (opposite) in the manual.
    The key is needed when going to TI-BASIC for example and you get the graphic (purple) screen lock
2. NTSC mode is sharper on the LCD (compared to PAL), Dip Switch bank 2, Switch 1 in ON position
3. Screen Adjustments can be done using DipSwitch Bank 1.
Programs for the TI-99/4A with Mechatronic 80 Column Card (and I guess any card with a V9938 Chipset).
Funnelweb 4.4 with 80 Columns loading from the TIPI / RPI
(the original file on FTP.WHTECH.COM was to large to unpack on the TIPI?  I splitted it into two files
and then via SSHv2 logged into the RPI and merged them together into 1 directory.
Disk images and video below:
Funnel81.dskFunnel80.dsk
X80 demo (Alexander Hulpke, Germany)
Note: you need to load the X80 library first.
10 CALL INIT
20 CALL LOAD("DSK1.X80")
 X80.dsk
Other programs for 80 Column,
but I did not manage yet to get them to work:
1. Multiplan with disk  (disk is based on name and not on number.   DSK.TIMP.xxx)
2. TurboForth 80 Column
3. Telco V2.3  (Terminal Emulator)
4. Menu (but is for Myarc Geneva9640  MDOS). However for the F18A there is a 80 Column Menu system
    (not too sure if it works with the Mechatronic 80 Column Card)
If there are any other 80 Column programs let met know (Direct Message me and I will post them here if they work with the Mechatronic 80 Colum)
