globeron #26 Posted June 23, 2019 fbForth 2.0:8 80 Column 1 Quote Share this post Link to post Share on other sites
globeron #27 Posted June 30, 2019 To test Multiplan with the "TIMP" disk (meaning that the Multiplan module is searching for DSK.TIMP. which means that the disk can be in any of the diskdrive (DSK1. DSK2. DSK3. etc.) I wanted to use the nanoPEB (as TIPI is not be able to emulate a .dsk / image) However I am facing issues, see the video here: Quote Share this post Link to post Share on other sites
globeron #28 Posted June 30, 2019 Mechatronic 80 Column Card, with Multiplan module (loaded from FinalGrom) and TIMP disk image loaded from the Atronics99 Disk Drive. TIMP disk is updated for 80 Column mode: TIMP80.dsk TIMP disk for 40 columns: TIMP.dsk 1 Quote Share this post Link to post Share on other sites
globeron #29 Posted June 30, 2019 Y.A.P.P. (Yet Another Painting Program) with the Mechatronic 80 column 0207-YAPP-YetAnotherPaintingProgram.dsk 1 Quote Share this post Link to post Share on other sites
globeron #30 Posted June 30, 2019 (on the same Y.A.P.P. disk, see image above). GIF99 2 Quote Share this post Link to post Share on other sites
globeron #31 Posted June 30, 2019 Telco v2.3 - Terminal Emulator with Mechatronic 80 Column Card TELCO.dsk 2 Quote Share this post Link to post Share on other sites
globeron #32 Posted June 30, 2019 Here is another disk with tools of Ton Brouwer, but I did not figured out yet how to get these programs to work (it seems that the TIWALT Extended Basic program is having an error) and there is a Script file with a sequence to load object files, but I cannot remember how to use it with UTIL commands. 0206-V9938-Demo-3D-Vector.dsk Quote Share this post Link to post Share on other sites
globeron #33 Posted July 14, 2019 My Mechatronic 80 Column Card uses MSX2 V9938 Yahama chipset 1 Quote Share this post Link to post Share on other sites
globeron #34 Posted July 14, 2019 @Schmitzi Good to meet up yesterday in Amsterdam! I found the lists with all the software, the most important one for the Mechatronic 80 (V9938 chip) is this PDF list: https://atariage.com/forums/applications/core/interface/file/attachment.php?id=504929 Other 80-Column related complete lists: 1 Quote Share this post Link to post Share on other sites
TInaut #35 Posted July 15, 2019 On 6/21/2019 at 5:50 PM, globeron said: 1111 = >1000 Used by TIPI (on 32K of Jedimatt) / Hard & RAM drives 1110 = >1100 TI / Corcomp / Myarc FDC / Atronic CPS9900 (Floppy Disk Controller) 1101 = >1200 Mechatronic 80 Column Card 1100 = >1300 RS232-1/2 1011 = >1400 128 KByte Speichererweiterung mit Centronicsschnittstelle (128K Memory Expansion with Centronics Interface) 1010 = >1500 RS232-3/4 1001 = >1600 1000 = >1700 Hexbus (for TI-99/8 and CC-40 and similar) 0111 = >1800 0110 = >1900 Myarc 512k Memory 0101 = >1A00 0100 = >1B00 0011 => 1C00 0010 => 1D00 Triple Tech Clock (CorComp) 0001 => 1E00 SAMS (Memory) 0000 => 1F00 P-Code (UCSD Pascal) Some things to note: If there is not an RS232 card at >1300, but there is one at >1500, it responds as RS232-1/2. The Myarc 512k card responds at >1000 and >1900 and its memory is paged into the 32k space, thus no other 32k containing card should be used with it. Quote Share this post Link to post Share on other sites
mizapf #36 Posted July 15, 2019 8 hours ago, TInaut said: Some things to note: If there is not an RS232 card at >1300, but there is one at >1500, it responds as RS232-1/2. Interestingly, while checking this, I found an obviously long-standing typo (6+ years) in MAME which made it impossible to switch the CRU base. You can now (next release) insert two RS232 cards and configure their CRU bases in the OSD. And yes, it proves the mentioned handling of a single card at 1500. 1 Quote Share this post Link to post Share on other sites
+RXB #37 Posted July 16, 2019 On 6/30/2019 at 1:23 PM, globeron said: Y.A.P.P. (Yet Another Painting Program) with the Mechatronic 80 column 0207-YAPP-YetAnotherPaintingProgram.dsk 400 kB · 4 downloads YAPP works best with a Serial Mouse or Serial Trackball, I have both. (But my TIM card died so no longer have card to use them.) Quote Share this post Link to post Share on other sites
fabrice montupet #38 Posted November 22, 2019 For those interested, I have dumped the EPROM of my Mechatronic 80 Columns, here: http://www.ti99.com/ti/data/images/MECHA80.BIN 7 2 Quote Share this post Link to post Share on other sites
globeron #39 Posted November 24, 2019 80 Zeichen 4 Quote Share this post Link to post Share on other sites
globeron #40 Posted November 24, 2019 ASSembler programpacket 80 4 Quote Share this post Link to post Share on other sites
globeron #41 Posted November 24, 2019 EXB 80 4 Quote Share this post Link to post Share on other sites
globeron #46 Posted November 24, 2019 (I came along this, I did not validate it with the cable I made last time, but also @fabrice montupet mentioned that the audio have to be on certains PINs on the SCART interface to get audio). 4 Quote Share this post Link to post Share on other sites
+OLD CS1 #47 Posted November 25, 2019 @globeron Appreciate the dump. That is a lot of images across a number of posts. Could you Zip all that up into a single file and post for download? 2 Quote Share this post Link to post Share on other sites
+Schmitzi #48 Posted November 25, 2019 Yes please And in HiRes, if possible Quote Share this post Link to post Share on other sites
globeron #49 Posted November 25, 2019 Mechatronic80.zip Probably I do not have time so sson to redo the scans (more people asked for it), but here is the 1 zip file. 1 2 Quote Share this post Link to post Share on other sites
humeur #50 Posted November 25, 2019 Thank for the scan, i have receive the packet today thank Jean Louis 2 Quote Share this post Link to post Share on other sites
