Sign in to follow this
BeeryMiller
Assembly Language Instruction
OK, I was using an assembly language instruction I have never used in the past.  I am obviously using it incorrectly as I am not getting expected results.  Please advise what I might do to correct.  Thanks.
P.S., I ended up using the MOV instruction which used another word of instruction that solved the issue, but I would still like to understand where I am making my mistake.
START
            SETO @TOGGLE
            ABS    @TOGGLE
            JNE      SEC1
SEC2     BLWP   @THERE
             JMP      END
SEC1     BLWP   @HERE
END       BLWP    @>0000
TOGGLE DATA     0
I thought my code should JMP to SEC1, however it appears the EQ bit is not set and goes to SEC2.  Is there something I am overlooking with the use of the SETO command to set it to >FFFF I am overlooking?
Thanks for the feedback.
Beery
I just tested this in Classic99 and it worked as expected. ABS on a value of -1 converts it to 1, which fails to set the equality bit, as it's not equal to zero.
Hmmm, will need to check my code again.  Something wasn't adding up, somewhere.  My code is a bit more complicated than that example, so something else must be happening after I go through all the program initialization.
Beery
9900 Family Systems Design p 8-132 says Single Operand Instructions that compare results to zero are:
INV, NEG, INC, INCT, DEC, DECT
These do NOT compare results to zero:
B, BL, BLWP, CLR, SETO, ABS, SWPB, X
So, either SETO or ABS leave the jump undetermined.
That's interesting because both the TI Tech Pages and Classic99 contradict that.
Page 41 of the E/A manual is my goto when I am confused.
Well actually I used to be confused, but now I am not too sure. 😟
0xBF
0xBF
Aha, there is a footnote to ABS. "Operand is compared to zero for status bit." Not the result.
So, the status tells you about prior to ABS.  I would expect
 ABS R1
 JLT  HERE
to jump if the sign had been -1 before ABS.
I've never known or knowingly relied on this.
Actually, there is an error in the Editor/Assembler manual concerning the ABS command. It says that the Carry bit is unaffected, but I just tested it on my Geneve (TMS9995), and the Carry bit is always reset.
*           LAECOPX
*   FFFE    10000***
*   FFFF    10000***
*   0000    00100***
*   0001    11000***
*   0002    11000***
*   7FFE    11000***
*   7FFF    11000***
*   8000    10001***
*   8001    10000***
I'm glad to say that I did it right with ABS in MAME (had to make sure first). This can be the cause of such extremely rare bugs that stay unnoticed for years.
*           LAECOPX
*   FFFE    10000***
*   FFFF    10000***
*   0000    00100***
*   0001    11000***
*   0002    11000***
*   7FFE    11000***
*   7FFF    11000***
*   8000    10001***
*   8001    10000***
So the table on page 41 is correct for ABS right?
Yes, and the corresponding information in the 9900 and 9995 specs.
BTW, this was one of the rare occasions where I used the LST command of the 9995 (to preload the status flags).
