oo7 Posted December 6, 2019 Share Posted December 6, 2019 22 hours ago, Mclaneinc said: For me the best PCE emulator has been Otake and before that Magic Engine but I have to be fair and say I've not knowingly tried the Mednafen PCE emulation in LONG while.. Loved Magic Engine and am a registered license owner but Otake has snagged the best mantle with the work on input lag. Retroarch is what it is, its a Marmite emulator Magic Engine does a ok job, can not emulate sprite limitation and is riddled with timing hacks however does a decent job, ootake is more accurate however still full of hacks, mednafen is has 100% known compatibility to all titles no hacks and cycle accurate with proper sprite limit emulation even. retroarch, well im not a fan. Quote Link to comment Share on other sites More sharing options...
phaeron Posted December 8, 2019 Author Share Posted December 8, 2019 http://www.virtualdub.org/beta/Altirra-3.90-test20.zip http://www.virtualdub.org/beta/Altirra-3.90-test20-src.zip Fixed a bug with high-pass optimization at volume level 0 that was causing some PDM glitches. Fixed an issue with denormals since the split filter changes that was using a bit of CPU time when everything went quiet. This was previously handled, but the mitigation code was bypassed in the new code. Fixed an issue where sometimes UI wouldn't display in full-screen mode in DirectX 11 mode while the emulator was paused. (This doesn't apply to modal UI that forced an exit from full-screen mode.) Fixed enhanced text mode sometimes not drawing its first frame properly. Started on HUD customization, available from View menu -- you can now move and resize HUD elements. Currently this is only supported for a few of the audio graphs. Note that there was some major UI system rework under the hood, so there may be some bugs with indicators. Added audio scope that shows the waveform coming out of POKEY, with all four channels. This is tapped between the two amplifier stages, so it uses a 64KHz source and shows the short time constant high-pass effect. Fixed a bug in the CPU emulation where an NMI was being improperly held off for one instruction if it had been delayed due to RDY cycles from WSYNC. Those RDY cycles now count against the timing check. 11 2 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted December 8, 2019 Share Posted December 8, 2019 (edited) This just ran 'The BIG Demo' Beautifully. Edit: XP32. Edited December 8, 2019 by Kyle22 Clarification. Windows XPerfect. 2 Quote Link to comment Share on other sites More sharing options...
oo7 Posted December 10, 2019 Share Posted December 10, 2019 (edited) On 12/7/2019 at 8:03 PM, phaeron said: http://www.virtualdub.org/beta/Altirra-3.90-test20.zip http://www.virtualdub.org/beta/Altirra-3.90-test20-src.zip Fixed a bug with high-pass optimization at volume level 0 that was causing some PDM glitches. Fixed an issue with denormals since the split filter changes that was using a bit of CPU time when everything went quiet. This was previously handled, but the mitigation code was bypassed in the new code. Fixed an issue where sometimes UI wouldn't display in full-screen mode in DirectX 11 mode while the emulator was paused. (This doesn't apply to modal UI that forced an exit from full-screen mode.) Fixed enhanced text mode sometimes not drawing its first frame properly. Started on HUD customization, available from View menu -- you can now move and resize HUD elements. Currently this is only supported for a few of the audio graphs. Note that there was some major UI system rework under the hood, so there may be some bugs with indicators. Added audio scope that shows the waveform coming out of POKEY, with all four channels. This is tapped between the two amplifier stages, so it uses a 64KHz source and shows the short time constant high-pass effect. Fixed a bug in the CPU emulation where an NMI was being improperly held off for one instruction if it had been delayed due to RDY cycles from WSYNC. Those RDY cycles now count against the timing check. Altirra does not currently know the two following good firmware XL/XE 16kB OS roms ~~~~~~~~~~~~~~~~~~ Rev. System Date CRC-32 Part Nr(s) ~~~~ ~~~~~~ ~~~~~~~~~~~ ~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~ 11 1200XL 12/23/1982 0x1a1d7b1b CO60616B, CO60617B 3B 65XE 07/21/1984 0x45f47988 C101700 Atari Home Computer OS ROMs.zip Edited December 10, 2019 by oo7 Quote Link to comment Share on other sites More sharing options...
oo7 Posted December 10, 2019 Share Posted December 10, 2019 the following 2 crash during boot 130XE Auto Artshow (198x)(Antic Software)(US)[disk].zip Boulder Dash II (1985)(Databyte)(GB)[disk].zip Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 10, 2019 Share Posted December 10, 2019 (edited) Boulder Dash MUST have accurate sector timing ticked, not tried the other one but expect its the same...Some protection in there.. Edit: Not sure re the sldieshow, obviously it needs BASIC but I was getting rubbish on the screen while the slideshow was running, I swapped memory to 128K and used OS version 3 roms and put BASIC as B and all was well, so its one or more of those things.. Edited December 10, 2019 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
oo7 Posted December 10, 2019 Share Posted December 10, 2019 (edited) 7 minutes ago, Mclaneinc said: Boulder Dash MUST have accurate sector timing ticked, not tried the other one but expect its the same...Some protection in there.. This worked for you? Not here. Maybe cause im using latest beta 20. Gonna try and drop to latest stable. no go here. sio patch disabled, accurate sector enabled. gets stuck block 671` Edited December 10, 2019 by oo7 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 10, 2019 Share Posted December 10, 2019 (edited) No, don't do that, I'm on the same beta as you, its one of your settings, have you got a Happy drive set up? Most protection checks look for a happy / read in speed... Funky configs are nice but try and match exactly how a machine would be if plain out of the box, no fancy drives, ram or startup things...Also reread my last post as its updated.. Averys beta's are rock solid, going back to finals usually loses you nice updates and fixes... Edited December 10, 2019 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
oo7 Posted December 10, 2019 Share Posted December 10, 2019 (edited) 20 minutes ago, Mclaneinc said: No, don't do that, I'm on the same beta as you, its one of your settings, have you got a Happy drive set up? Most protection checks look for a happy / read in speed... Funky configs are nice but try and match exactly how a machine would be if plain out of the box, no fancy drives, ram or startup things...Also reread my last post as its updated.. Averys beta's are rock solid, going back to finals usually loses you nice updates and fixes... didnt set up drives, using standard emulation. do i need to setup full 1050 emulation and use 1050 firmware? I set up emulator to most accurate settings only thing left would be that so i enabled full 1050 emulation using a 1050 firmware and boulderdash 2 works. other still crashes. the antic show thats crashing is prob a memory compatibility thing. Edited December 10, 2019 by oo7 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 10, 2019 Share Posted December 10, 2019 (edited) I'm just running as a generic 1050, no special roms, in acceleration I untick fast boot although I don't think its that important and make sure D: disk SIO is unticked... I do this for problem disks or protected stuff.. EDIT: I bet you are in 800 mode and not XL? 800 mode reboots...I test initially in XL or XE mode because its the most normal, only if that fails do I go to OSA or B Edited December 10, 2019 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
oo7 Posted December 10, 2019 Share Posted December 10, 2019 19 minutes ago, Mclaneinc said: I'm just running as a generic 1050, no special roms, in acceleration I untick fast boot although I don't think its that important and make sure ? disk SIO is unticked... I do this for problem disks or protected stuff.. EDIT: I bet you are in 800 mode and not XL? 800 mode reboots...I test initially in XL or XE mode because its the most normal, only if that fails do I go to OSA or B I was in xl/xe mode. tried every mode. WOuld not work untill i added 1050 full emulation. When you say generic 1050. Isnt adding full 1050 emulation the only way to run as 1050?? Quote Link to comment Share on other sites More sharing options...
oo7 Posted December 10, 2019 Share Posted December 10, 2019 36 minutes ago, Mclaneinc said: I'm just running as a generic 1050, no special roms, in acceleration I untick fast boot although I don't think its that important and make sure ? disk SIO is unticked... I do this for problem disks or protected stuff.. EDIT: I bet you are in 800 mode and not XL? 800 mode reboots...I test initially in XL or XE mode because its the most normal, only if that fails do I go to OSA or B Ive tried all settings in every mode and unless I add 1050 emulation that boulder dash doesnt run. weird since it runs for you without it. The other image from antic still crashes. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 10, 2019 Share Posted December 10, 2019 No, in the file menu with disk drives you can set it to an emulated 1050 (and several other things) or you can go the whole hog and do the full emulation, the only full device based emulation I do is Happy 1050 but its not on all the time because I'm testing cracked and protected stuff so it rules one possible varmit out.. Didn't have to use full drive emulation to get boulder dash working, merely accurate sector timing as I could hear a protection check of some sort about 50% of the way in, also those slow reads that it does are usually a clue that its protected..Don't know the actual tech side of the protection but sometimes protection checks can be sloppy... Glad its working, don't have a clue as to why it needs the way its running for you, the emulated drive in software mode is always suitable.. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 10, 2019 Share Posted December 10, 2019 The Antic thing runs for me, as its for an XE it needs the 128K and BASIC ON, runs fine here, sets up the ram disk and then the autorun.sys boots in a bas program loads the various pics in to ram and does the slideshow...The pics are NOT amazing Quote Link to comment Share on other sites More sharing options...
oo7 Posted December 10, 2019 Share Posted December 10, 2019 (edited) 6 minutes ago, Mclaneinc said: The Antic thing runs for me, as its for an XE it needs the 128K and BASIC ON, runs fine here, sets up the ram disk and then the autorun.sys boots in a bas program loads the various pics in to ram and does the slideshow...The pics are NOT amazing hmmm didnt try basic i think lol. also i dont see an option for emulated 1050 other than full emulation. strange. Edited December 10, 2019 by oo7 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted December 10, 2019 Share Posted December 10, 2019 (edited) 13 minutes ago, oo7 said: also i dont see an option for emulated 1050 other than full emulation. strange. Go to File -> Disk drives ... and the check bottom line of the dialog. I guess that it is set to 810. Databyte's protection is one of the most stupid ones and in this case also one that fails 255:1 on 810s. Check this detailled post by ijor for that particular problem: https://atariage.com/forums/topic/282759-databyte-disks-on-atari-810/?do=findComment&comment=4112899 Edited December 10, 2019 by DjayBee Quote Link to comment Share on other sites More sharing options...
oo7 Posted December 10, 2019 Share Posted December 10, 2019 6 minutes ago, DjayBee said: Go to File -> Disk drives ... and the check bottom line of the dialog. I guess that it is set to 810. Databyte's protection is one of the most stupid ones and in this case also one that faile 1:255 on 810s. Check this detailled post by ijor for that particular problem: https://atariage.com/forums/topic/282759-databyte-disks-on-atari-810/?do=findComment&comment=4112899 Got it! thank you. I was looking under adding devices in config and didnt think to go to file/disk drives, now I know what Mclaneinc was saying. I guess Im too fresh to the emulator all sorted. Thanks again guys Quote Link to comment Share on other sites More sharing options...
Keatah Posted December 11, 2019 Share Posted December 11, 2019 Gotta learn it sooner or later.. 1 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 11, 2019 Share Posted December 11, 2019 I'm just glad its all sorted, @oo7 ask all the questions you like, one of us will know the answer and we know Phaeron ALWAYS knows the answer The amount of times we all do stuff like forget about BASIC etc is very normal, enjoy your emulation! Paul. Quote Link to comment Share on other sites More sharing options...
oo7 Posted December 11, 2019 Share Posted December 11, 2019 1 hour ago, Mclaneinc said: I'm just glad its all sorted, @oo7 ask all the questions you like, one of us will know the answer and we know Phaeron ALWAYS knows the answer The amount of times we all do stuff like forget about BASIC etc is very normal, enjoy your emulation! Paul. Thanks! Im actually in heaven with Altirra! its the ultimate tool for an Atari 8-bit user. Never thought Ide see an A8 emulator this well written and equipped. SO happy I get to use it. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 11, 2019 Share Posted December 11, 2019 (edited) Yes we are very lucky, initially it was a proof of concept project for Avery and then loads of us begged him to make it a long term thing and this is what we got. Simply an amazing bit of software that's got something for dev's, players, tinkerers and serious use people alike. And all for free, simply brilliant...Nothing will beat the buzz of the real hardware but Altirra sets the bar damn close..very damn close... Edited December 11, 2019 by Mclaneinc 1 Quote Link to comment Share on other sites More sharing options...
oo7 Posted December 11, 2019 Share Posted December 11, 2019 3 hours ago, Mclaneinc said: Yes we are very lucky, initially it was a proof of concept project for Avery and then loads of us begged him to make it a long term thing and this is what we got. Simply an amazing bit of software that's got something for dev's, players, tinkerers and serious use people alike. And all for free, simply brilliant...Nothing will beat the buzz of the real hardware but Altirra sets the bar damn close..very damn close... Before Altirra I used Atari 800WinPlus but always went back to my real hardware. With Altirra my real hardware is now a showpiece. One thing my real hardware wont to is NTSC and PAL. Now my PAL software doesnt run too fast or flicker or bounce. I love this emulator!!! Not too surprised. For years I used virtual dub which was amazing when I used it, when I visited his site and saw Altirra I was like no way awesome! Im so happy we have this. Very lucky. 2 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 11, 2019 Share Posted December 11, 2019 You went the way a lot of us did, via Atari800win, that was coming along really nicely then it stopped dead, a little later the Plus version came out but again the maintaining of it lapsed for various reasons and then it just stopped... Shame, a lot of us were beta testing it and adding idea's and then nothing, then welcome Altirra and then it all changed. I've avoided mentioning Atari++ and A800 simply because they have (for me) awkward interfaces with the SDL on ++ being such a pain imho. That said both are still being maintained which is great and A800 is a bloody good emulator with Atari++ a bit behind in some stuff but ticks over nicely. And yes, the ability to have both a PAL and NTSC machine all in one is great, I've always had just a UK model so playing US releases were something like 17% slower which on a shooter can be nice but you are not playing it as it was meant to be played, at 60Hz, also the artifacting support is ace, back then we edited the DLI to change the graphics mode from 0F to 0E so you got colour but its wasn't great so booting up Altirra and having it as per the US TV's is wonderful..Games like AE just come to life.. Any way, should not wax on about Altirra too much, Phaerons ego might go mad 3 Quote Link to comment Share on other sites More sharing options...
oo7 Posted December 12, 2019 Share Posted December 12, 2019 Thanks to altirra Im not getting any work done and lacking lots of sleep lmao I now have A8 on my workstation at work, media center in my living room and laptop to the tv in the bedroom lol Altirra has recently amplified my life long obsession. Quote Link to comment Share on other sites More sharing options...
R0ger Posted December 13, 2019 Share Posted December 13, 2019 Quick question .. is there a function to run simulation till next frame ? Of course it can be done somewhat easily in debugger, but outside of that ? Quote Link to comment Share on other sites More sharing options...
