+FarmerPotato Posted July 16, 2019 Share Posted July 16, 2019 Has anybody made (for sale) a test point adaptor for Pbox card, sidecar, or cartridge port? I've seen pictures of a Pbox card riser with a card on top. Ideally there would be a row of pin headers to attach probes to, so that you can watch the bus without adding test points for all the common signals to hardware under development. I drew up a PCB for the cartridge port, 3" long and 2" wide (just a bit wider than the 2x18 card edge.) It takes a 2x18 header for test leads, and a pass-thru 4A cartridge port (either pointing up, or reuse the right angle adaptor.) I'm kind of balking at the fab cost which is the same as a regular cartridge run. Ideas to make it more useful would be to squeeze in some pads for GROM, EPROM, bank latch, and maybe even a tiny prototype area. So it becomes both a cartridge debugger AND an experimenter board. Test points board. 50mm wide x 75 mm long. ||||||||||||||| -|||||||||||||||- ||||||||||||||||| ||||||||||||||||| ||||||||||||||||| ||||||||||||||||| ||||||||||||||||| |***************| test point |***************| headers ||||||||||||||||| ||||||||||||||||| |@@@@@@@@@@@@@@@| cartridge port \@@@@@@@@@@@@@@@/ pass-thru Experimenter add-on board. 50mm wide x 100mm long. ||||||||||||||| -|||||||||||||||- | | |LLLLLL GGGGGG | LATCH and GROM socket |LLLLLL GGGGGG | | | |RRRRRRRRR | EPROM socket |RRRRRRRRR | |RRRRRRRRR | | | |***************| breakout all pins |***************| in rational order |...............| protoboard |...............| |...............| . . |...............| |...............| |...............| Two boards can be panelized in a 100x100mm job ($16.95 at dirtypcbs.com), two for the price of one. Here's another inspiration for an experimenter board: https://store.digilentinc.com/breadboard-expansion-with-mxp-connectors-for-ni-myrio/ 4 Quote Link to comment Share on other sites More sharing options...
+helocast Posted July 16, 2019 Share Posted July 16, 2019 40 minutes ago, FarmerPotato said: Has anybody made (for sale) a test point adaptor for Pbox card, sidecar, or cartridge port? I've seen pictures of a Pbox card riser with a card on top. Ideally there would be a row of pin headers to attach probes to, so that you can watch the bus without adding test points for all the common signals to hardware under development. I drew up a PCB for the cartridge port, 3" long and 2" wide (just a bit wider than the 2x18 card edge.) It takes a 2x18 header for test leads, and a pass-thru 4A cartridge port (either pointing up, or reuse the right angle adaptor.) I'm kind of balking at the fab cost which is the same as a regular cartridge run. Ideas to make it more useful would be to squeeze in some pads for GROM, EPROM, bank latch, and maybe even a tiny prototype area. So it becomes both a cartridge debugger AND an experimenter board. https://store.digilentinc.com/breadboard-expansion-with-mxp-connectors-for-ni-myrio/ There was a basic one a while back @ OSH Park w/o a pass-through. Still expensive, imo. https://oshpark.com/shared_projects/AJqKJwMn 2 Quote Link to comment Share on other sites More sharing options...
Stuart Posted July 16, 2019 Share Posted July 16, 2019 Not sure if Ksarul is still stocking them ... 2 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted July 16, 2019 Share Posted July 16, 2019 I recently sold the last one of these I had hiding in my spare parts boxes a couple of months ago. I made 20 of them based on the expressed community need back then. I'd have to have about ten more people looking for them to make another run of them economical (I have enough of the connectors, so that part isn't a problem). 5 Quote Link to comment Share on other sites More sharing options...
wolhess Posted July 18, 2019 Share Posted July 18, 2019 Hi Ksarul, please put me on your list for 1 of the PEB extender cards, I have a broken Geneve card, which I will soon try to get back into service. For initial tests and measurements, a PEB extender card is very helpful! Thanks. Quote Link to comment Share on other sites More sharing options...
+FarmerPotato Posted July 18, 2019 Author Share Posted July 18, 2019 On 7/16/2019 at 5:32 PM, Ksarul said: I recently sold the last one of these I had hiding in my spare parts boxes a couple of months ago. I made 20 of them based on the expressed community need back then. I'd have to have about ten more people looking for them to make another run of them economical (I have enough of the connectors, so that part isn't a problem). Me too on the waitlist for 1. I'm not in a hurry. I'm currently working on side port and cartridge port. No immediate plans for Pbox. Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted July 26, 2019 Share Posted July 26, 2019 Jim, you can put me on the waitlist for one too. Thanks Filip Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted July 26, 2019 Share Posted July 26, 2019 No problem on building the waitlist--and it looks like I will need to order these soon, as I have almost enough people wanting one to make it economical to make another run of them. 1 Quote Link to comment Share on other sites More sharing options...
