foft #451 Posted January 4 Worth putting on the latest, though I didn't see anything that'd fix fujinet in the changes: http://www.64kib.com/pokeymax_files/1.25_20210924/v2/build_10M08_quad_sid/output_files/core.bin Can use the (U)update core. Note that after a reboot you may then need to use pokey cfg again to unmute some channels (see thread above). Though I suspect the issue is more likely the diode thing. Better to check with a scope than multimeter, since its capturing the toggling lows/highs rather than a static level. 1 Quote Share this post Link to post Share on other sites
pirx #452 Posted January 5 Thanks again foft! Updated core, it did not help, as you predicted. Will have to dig these 40+ yrs old caps and diodes. Quote Share this post Link to post Share on other sites
olix #453 Posted February 25 @foft I am happy that i could buy a PokeyMaxV2 last week from an other ABBUC User. The Firmware is "113M08QP" I would like to do two things and don't know if this is possible: 1. Downgrade the Core-Model to Stereo with Covox "SC" 2. Update the Firmware to 1.25 Is this possible in one step by using the core.bin with pokeycfg_1_3 i found here: http://www.64kib.com/pokeymax_files/1.25_20210924/v2/build_10M08_stereo_covox_sample_auto/output_files/ Quote Share this post Link to post Share on other sites
foft #454 Posted February 25 Yes the hardware is identical and you have a license for any core smaller/equal to the one originally installed. The fpga size needs to match (10m02,10m04 etc). Also make sure to check the pinout of installation is the same. Quote Share this post Link to post Share on other sites
olix #455 Posted March 6 I search an install (wiring) diagram for my pokeymax 113M08QP (Quad PSG). In the PokeyMax Userguide v.1.0 the last entry is the QC (Quad Covox) but no diagram for the QP Quote Share this post Link to post Share on other sites
olix #456 Posted March 6 My PokeyMax (113M08QP) that i could buy some days ago makes only strange sounds. The sound is the same on the original DIN AV Port as on the Pokeymax Audio-Out. Keyboard function is ok and the Chip is detected with the Pokeymax detect program. Also the config tool detects the Pokeymax right. I think it's a early model V2 not the later V2b. You can hear the sound here: https://1drv.ms/v/s!AubfF7Hbqd6zkdJsZYGs7r5iCrg1BA?e=rWFrSl and here: https://1drv.ms/v/s!AubfF7Hbqd6zkdJrHHy9jLoN-5q9DA?e=6560sL Also i can't save the changes in the configtool an there is also no possibility to update the firmware. Although it is an M08 chip, which should be big enough. Does anybody have an idea? 1 Quote Share this post Link to post Share on other sites
foft #457 Posted March 6 Hi, Ok, two things things: i) Flash support for 08 was introduced in 1.14 ii) 1.13-1.15 have a dac bug Upgrading the core will fix both, though needs a usb blaster to do so. We thought we’d intercepted all the troublesome cores with the broken dac, I guess this one slipped through the net. Mark Quote Share this post Link to post Share on other sites
olix #458 Posted March 6 @foftThank you for your answer. I will ask "TF_HH" Jürgen, if he would update the PokeyMax with the USB Blaster. 1 Quote Share this post Link to post Share on other sites
olix #459 Posted March 7 ... one last question ( i hope it's the last - sorry if not 😉 ) If i like to update my PokeyMax 123M04SC (Stereo with Covox) to Firmware 1.25 - what is the right file? build_10M04_stereo_covox_auto/ or build_10M04_stereo_covox_no_right_detect/ What is the different? Quote Share this post Link to post Share on other sites
foft #460 Posted March 7 Use the auto one, the ‘no right detect’ is a special one. Think it just changes the default for the right channel auto-detection iirc. 1 Quote Share this post Link to post Share on other sites
patjomki #461 Posted March 10 (edited) I post here because the thing I noticed affects both PokeyMax 2 and 3 (with sid option). I disabled sid for testing purposes but I can still hear sid output when I play a tune. You can test it with the following basic code: 10 POKE 53772, 63: REM SET POKEYMAX INTO CONFIGMODE 20 POKE 53783, 0: DISABLE ALL CHIPS (SID, POKEY, PSG ETC) 30 POKE 53848,15: REM SET VOLUME ALL SID VOICES TO MAX 40 POKE 53829,25: REM SET ATTACK 1 (HIGH NIBBLE) AND DECAY 9 (LOW NIBBLE) VOICE 1 50 POKE 53830,68: REM SET SUSTAIN 4 (HIGH NIBBLE) AND DECAY 4 (LOW NIBBLE) VOICE 1 60 POKE 53825,29: REM SET FREQUENCY VOICE 1 HIGH BYTE 70 POKE 53824,69: REM SET FREQUENCY VOICE 1 LOW BYTE 80 POKE 53828,17: REM SET WAVEFORM VOICE 1 TO TRIANGLE Is this a bug in PokeyMax? Core is: 125M16HK Edited March 10 by patjomki Quote Share this post Link to post Share on other sites
foft #463 Posted March 12 Errr, yes looks like a bug. Oops! Will fix in 1.26. 2 2 Quote Share this post Link to post Share on other sites
foft #464 Posted March 18 (edited) 1.26 is released. * Cut 6581 bias (distortion on Basil!) * Synchronous clock enable length fixed * Disabled chips are no longer writable! Index of /pokeymax_files/1.26_20220318 (64kib.com) http://www.64kib.com/pokeymax_files/changelog.txt Dev guide also updated (corrections provided by @patjomki - thanks): http://www.64kib.com/pokeymax_files/pokeymax_dev_126.pdf Edited March 18 by foft edit: dev guide added 2 Quote Share this post Link to post Share on other sites
adam242 #465 Posted March 19 Still hoping to find someone US-based who is able and willing to update my M02 PokeyMax.. International shipping is prohibitively expensive. Quote Share this post Link to post Share on other sites
Frankie #466 Posted March 31 (edited) On 3/18/2022 at 4:51 PM, foft said: 1.26 is released. * Cut 6581 bias (distortion on Basil!) * Synchronous clock enable length fixed * Disabled chips are no longer writable! Index of /pokeymax_files/1.26_20220318 (64kib.com) http://www.64kib.com/pokeymax_files/changelog.txt Dev guide also updated (corrections provided by @patjomki - thanks): http://www.64kib.com/pokeymax_files/pokeymax_dev_126.pdf ---read previous posts - answered own question--- Edited March 31 by Frankie Quote Share this post Link to post Share on other sites
Frankie #467 Posted March 31 Anyone on this thread successful in getting a PokeyMax to work in a 576NUC? When I installed it the keyboard didn't work. All the characters were swapped around. Quote Share this post Link to post Share on other sites
mytek #468 Posted March 31 39 minutes ago, Frankie said: Anyone on this thread successful in getting a PokeyMax to work in a 576NUC? When I installed it the keyboard didn't work. All the characters were swapped around. Although originally it was intended to be possible, hence the inclusion of header J8 on the NUC that provided extra signals for a PokeyMax, there were compatibility issues that at least initially blocked this approach. I'm pretty sure the swapped character problem was resolved through core changes, but I've never had it confirmed if 100% compatibility was achieved. Since I personally do not have one of these devices to test with, I cannot confirm or deny whether the latest PokeyMax device is now working properly in a 576NUC+. Quote Share this post Link to post Share on other sites
Frankie #469 Posted March 31 2 hours ago, mytek said: Although originally it was intended to be possible, hence the inclusion of header J8 on the NUC that provided extra signals for a PokeyMax, there were compatibility issues that at least initially blocked this approach. I'm pretty sure the swapped character problem was resolved through core changes, but I've never had it confirmed if 100% compatibility was achieved. Since I personally do not have one of these devices to test with, I cannot confirm or deny whether the latest PokeyMax device is now working properly in a 576NUC+. If I understand correctly, the version I have 111 M02SC is not user upgradable so I cannot test the latest core either. Quote Share this post Link to post Share on other sites
Frankie #470 Posted March 31 On 3/18/2022 at 8:24 PM, adam242 said: Still hoping to find someone US-based who is able and willing to update my M02 PokeyMax.. International shipping is prohibitively expensive. Me too! Quote Share this post Link to post Share on other sites
foft #471 Posted March 31 There must be someone in the US that knows how to use a USB blaster and attach 6 wires! Quote Share this post Link to post Share on other sites
_The Doctor__ #472 Posted March 31 There are... and most people could just buy a usb blaster for next to nothing, so long as the update tool is painless it's hard to mess up. Probably faster and cheaper to do just that. Unless there is someone local to the folks, you still pay shipping to and from the person doing the updates. It's crazy that stuff ships from all over the world to the US for next to nothing, but shipping within the US or out from the US is so dear. Quote Share this post Link to post Share on other sites
mytek #473 Posted March 31 Yep pretty darn cheap. LINK I think the biggest issue I had when I bought one of these way back when, was how friggin big the Altera program was for Wndows - took a bit time to do the install. And it wasn't exactly intuitive to use. But I remember muddling through it and successfully updating some Sophia boards. Quote Share this post Link to post Share on other sites
Frankie #474 Posted March 31 The problem isn't having the hardware, it's that there are no updates to the earlier M02 Pokeymax. 1 Quote Share this post Link to post Share on other sites
adam242 #475 Posted April 2 On 3/31/2022 at 7:01 PM, Frankie said: The problem isn't having the hardware, it's that there are no updates to the earlier M02 Pokeymax. Precisely. I went and purchased a Blaster, only to be disappointed that there were no M02 update files available. Quote Share this post Link to post Share on other sites
