carlsson Posted September 16, 2019 Share Posted September 16, 2019 Some laptops have multiple functions on each key and that you'd use Fn to access the additional mode, though I can't say for sure without you telling the model or showing a picture of your keyboard. In that case you might have to use Ctrl + Fn + [other key] to achieve the Break function, if not Ctrl+C does it. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted September 21, 2019 Author Share Posted September 21, 2019 Here is another one with problems. Boolean Brain requires you to solve logic puzzles while walking around in a computer. Problem is when it displays the logic gates screen it is all green and the number keys don't respond. It is in Home computer magazine v 4.03 originally for the PCjr with corrections in v 5.2 to make it work on a normal pc. BOOLEAN2.BAS Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted September 21, 2019 Author Share Posted September 21, 2019 Finally got it working. Beware bad disk sectors in the computer. BOOLEAN3.BAS Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted September 23, 2019 Author Share Posted September 23, 2019 anyone know if there is a PCjr emulator with cartridge basic? One program in HCM only runs on PCjr Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted September 23, 2019 Share Posted September 23, 2019 Apparently, MAME can emulate PCJr. https://mamedev.emulab.it/etabeta/2010/04/09/mess-how-to-episode-i-ibm-pc-jr/ Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 23, 2019 Share Posted September 23, 2019 Dosbox does Jr emulation too. IIRC, you can also define cartridge roms. Let me check. Yup. https://www.dosbox.com/wiki/Configuration:DOSBox Quote PCjr: Refers not to a graphics mode but an entire system developed by IBM, and the company's first attempt at a home computer. Its graphics modes are identical to that of the Tandy, but it is not 100% compatible with any other IBM computer. Allows the user to boot cartridge files specifically designed for this system (.jrc). Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted September 23, 2019 Share Posted September 23, 2019 8 hours ago, wierd_w said: Dosbox does Jr emulation too. IIRC, you can also define cartridge roms. Let me check. Yup. https://www.dosbox.com/wiki/Configuration:DOSBox The problem with cartridge BASIC is that it depends on the ROM-embedded BASIC for the core functionality, and I don't think DOSBox gives you the original BASIC ROM (pesky copyright issues). So I'd be surprised if the cartridge or BASIC[A].COM even work on DOSBox. One suggestion on the DOSBox forum, though, is to use QBASIC, and if it needs SCREEN 5, use SCREEN 7 instead. Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 23, 2019 Share Posted September 23, 2019 You can totally dump the rom basic on a real jr. It shows up as a normal option rom. The same cart dumper used to grab the cart Roma can grab it too, because the cartridge space and the system bios memory areas overlap. You can completely replace the Jr bios with a cartridge in the slot. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted September 24, 2019 Author Share Posted September 24, 2019 I have the roms but I don't wanna run it in mame roms directory which is huge. Is there a way to run mess separate from mame? Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted September 24, 2019 Share Posted September 24, 2019 On 9/23/2019 at 1:28 PM, wierd_w said: You can totally dump the rom basic on a real jr. It shows up as a normal option rom. The same cart dumper used to grab the cart Roma can grab it too, because the cartridge space and the system bios memory areas overlap. You can completely replace the Jr bios with a cartridge in the slot. Does DOSBox support jamming a true ROM into that space? That would be awesome if it did. You'd need to dump F600:0 to A000 to get the cassette BASIC, then replace that section of memory in DOSBox. 1 hour ago, bradhig1 said: I have the roms but I don't wanna run it in mame roms directory which is huge. Is there a way to run mess separate from mame? The link I posted just says to run MESS by itself and not worry about the MAME front end. As far as the ROMs directory, I would guess that you only need what's necessary to start the PCJr, so the main system ROM and the cartridge. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted September 25, 2019 Author Share Posted September 25, 2019 doesn't load the cartridge and I don't have a scroll lock key on my laptop. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted September 25, 2019 Author Share Posted September 25, 2019 remapped the scroll lock. I can boot mouser cart image but not basic cart Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 25, 2019 Share Posted September 25, 2019 (edited) 4 hours ago, ChildOfCv said: Does DOSBox support jamming a true ROM into that space? That would be awesome if it did. You'd need to dump F600:0 to A000 to get the cassette BASIC, then replace that section of memory in DOSBox. The link I posted just says to run MESS by itself and not worry about the MAME front end. As far as the ROMs directory, I would guess that you only need what's necessary to start the PCJr, so the main system ROM and the cartridge. See Brutman's page about the dumper. https://www.brutman.com/PCjr/pcjr_cart_dumping.html This site claims to already have a dump of the system bios. http://retrograde.inf.ua/pcjr.htm From the sounds of it, you need the system to run the bios, which scans the cart space for the signature bytes, and then sets the correct entry points for basica. DosboxX, a "more advanced" version of dosbox, might do what you want. I have to head to work now, but can find out later. Edit: From this GIT commit from last year it appears booting a system bios is possible in dosboxX. https://github.com/joncampbell123/dosbox-x/issues/774 Not sure how mature it is now though. Worth looking into. Edited September 25, 2019 by wierd_w Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted September 25, 2019 Author Share Posted September 25, 2019 (edited) I have the system bios Says it loads at e800. I don't know how to load at certain memory addresses. Edited September 25, 2019 by bradhig1 Quote Link to comment Share on other sites More sharing options...
The Usotsuki Posted September 25, 2019 Share Posted September 25, 2019 Well, if you want the PCjr BASIC in DOSBOX, you can set the machine to Tandy and use the Tandy version of GW-BASIC as an alternative. Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 25, 2019 Share Posted September 25, 2019 Dosbox-X has a config option to load a binary blob into the adapter rom area and execute it, at least according to its reference conf file. https://github.com/joncampbell123/dosbox-x/blob/master/dosbox.reference.conf Quote call binary on boot: If set, this is the path of a binary blob to load into the ROM BIOS area and execute immediately before booting the DOS system. # This can be used for x86 assembly language experiments and automated testing against the CPU emulation. It has another option for a "Run once" to load another, DIFFERENT blob, that executes before the ROM bios. Quote call binary on reset: If set, this is the path of a binary blob to load into the ROM BIOS area and execute immediately after CPU reset. # It will be executed before the BIOS POST routine, only ONCE. The binary blob is expected either to IRET or to # jump directly to F000:FFF0 to return control to the BIOS. A little assembler-fu to jump execution with a loaded adapter rom (containing the whole image, not just cart basic), and you are all set. Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted September 25, 2019 Share Posted September 25, 2019 1 hour ago, wierd_w said: Dosbox-X has a config option to load a binary blob into the adapter rom area and execute it, at least according to its reference conf file. https://github.com/joncampbell123/dosbox-x/blob/master/dosbox.reference.conf It has another option for a "Run once" to load another, DIFFERENT blob, that executes before the ROM bios. A little assembler-fu to jump execution with a loaded adapter rom (containing the whole image, not just cart basic), and you are all set. That's a good start. But actually, it might be better to not load the PCJr ROM, unless DOSBox also emulates PCJr's completely incompatible keyboard interface and keyboard too. The interface goes through a special deserializer because it can use either wired or infrared keyboards. And the keyboard itself uses different scan codes. However, if you can insert just the BASIC image into ROM, and then add in the cartridge, then you should be able to start up PCJr BASIC from DOS. GW-BASIC might possibly be another solution, though you need to make sure it uses the same SCREEN modes as the PCJr. Quote Link to comment Share on other sites More sharing options...
The Usotsuki Posted September 25, 2019 Share Posted September 25, 2019 2 hours ago, ChildOfCv said: That's a good start. But actually, it might be better to not load the PCJr ROM, unless DOSBox also emulates PCJr's completely incompatible keyboard interface and keyboard too. The interface goes through a special deserializer because it can use either wired or infrared keyboards. And the keyboard itself uses different scan codes. However, if you can insert just the BASIC image into ROM, and then add in the cartridge, then you should be able to start up PCJr BASIC from DOS. GW-BASIC might possibly be another solution, though you need to make sure it uses the same SCREEN modes as the PCJr. The Tandy 1000 GW-BASIC (2.02 and 3.20) is specifically supposed to be compatible with PCjr BASIC. Here's the 3.20 version: http://3.buric.co/gwbasic32tdy.zip DOSBox seems not to work quite right in the Tandy modes with this gwbasic.exe regarding text input (except for 4, which is the same as 1 with different rules for how COLOR works). Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted September 28, 2019 Author Share Posted September 28, 2019 On 9/25/2019 at 4:44 AM, The Usotsuki said: The Tandy 1000 GW-BASIC (2.02 and 3.20) is specifically supposed to be compatible with PCjr BASIC. Here's the 3.20 version: http://3.buric.co/gwbasic32tdy.zip DOSBox seems not to work quite right in the Tandy modes with this gwbasic.exe regarding text input (except for 4, which is the same as 1 with different rules for how COLOR works). I just reedited Boolean Brain back to the original Pcjr version and the graphics modes don't work right like you said. Sound doesn't work either. Anyone have a real Pcjr to test this on? Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 28, 2019 Share Posted September 28, 2019 On 9/24/2019 at 11:12 PM, bradhig1 said: I have the system bios Says it loads at e800. I don't know how to load at certain memory addresses. DOS debug is your pal. https://montcs.bloomu.edu/Information/LowLevel/DOS-Debug.html It can be used to start execution of a binary rom blob, if it is loaded inside your emulation at the right address. It was frequently used on XT class machines to execute low-level format utilities baked into disk controllers. Specifically, you want the G operator. (Assumes data is already in memory, starting at E800) A:\debug.exe G E800 (program data at E800 executes) IF you have RAM mapped there instead of a ROM blob (Tell DOSBOX you want UMBs, which will fill the adapter rom area with ram), you can use debug to LOAD the blob there, THEN use G to execute it. Quote Name: N [pathname] [arglist] This command can be used to load files into DEBUG's Memory after you have started the program, but it's main function is to create a new file under control of the Operating System which DEBUG can WRITE data to. Normally, when you want to 'debug' a file, you'd start DEBUG with a command like this: C:\WINDOWS>debug test.com . But it's also possible to load a file into DEBUG's Memory from within DEBUG itself by using the 'N' command and then the 'L' command (with no parameters) like this: -n c:\temp\test.com -l which will load the file test.com into DEBUG's Memory starting at location CS:0100 (you cannot specify any other location when using the L command like this!). The 'N' command makes it quite easy to save data or an Assembly program created in DEBUG to a file on your hard drive! Since this loads into conventional memory without your ability to say otherwise, and at a fixed address, you will have to use the MOVE command after the load to move the loaded data to the correct address. Quote Move: M range address This command should really be called: COPY (not Move) as it actually copies all the bytes from within the specified range to a new address. Examples: 1) -m 7c00 7cff 600 Copies all the bytes between Offset 7C00 and 7CFF (inclusive) to Offset 0600 and following... Once the data is in the UMB RAM at the correct address, then you can G E800 and off it goes. 1 Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted September 29, 2019 Share Posted September 29, 2019 12 hours ago, wierd_w said: DOS debug is your pal. https://montcs.bloomu.edu/Information/LowLevel/DOS-Debug.html It can be used to start execution of a binary rom blob, if it is loaded inside your emulation at the right address. It was frequently used on XT class machines to execute low-level format utilities baked into disk controllers. Specifically, you want the G operator. (Assumes data is already in memory, starting at E800) A:\debug.exe G E800 (program data at E800 executes) IF you have RAM mapped there instead of a ROM blob (Tell DOSBOX you want UMBs, which will fill the adapter rom area with ram), you can use debug to LOAD the blob there, THEN use G to execute it. Since this loads into conventional memory without your ability to say otherwise, and at a fixed address, you will have to use the MOVE command after the load to move the loaded data to the correct address. Once the data is in the UMB RAM at the correct address, then you can G E800 and off it goes. You still need ROM BASIC loaded at F600:0 also. Both cartridge BASIC and disk BASIC(A) incorporate the cassette BASIC interpreter and add their own extensions using its hooks. One thing you can say about IBM BASIC: It's modular. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted September 30, 2019 Author Share Posted September 30, 2019 found several cartridge basic images and all keep generating the error message cartridge required. Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted September 30, 2019 Share Posted September 30, 2019 22 minutes ago, bradhig1 said: found several cartridge basic images and all keep generating the error message cartridge required. Interesting. Do you know which segment the cartridge BASIC is supposed to load into? PCJr-aware DOS is supposed to look at the header of the cartridge and determine if any commands are supported directly by the cartridge instead of run from disk. If you run debug.com (PC DOS disk 2), you should be able to see the header with the command: D xxxx:0 L 80 where the xxxx are the BASIC cartridge address. Starting at offset 6 should be a list of DOS commands. One will be BASIC and the other will be BASICA. Both will be followed by a 2-byte entry point that is supposed to start up DOS-aware PCJR cartridge BASIC. I can look at it in more detail tonight. Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted October 1, 2019 Share Posted October 1, 2019 The cassette BASIC ROM expects cartridge ROM to be loaded at E800:0. There's an undocumented extension to the boot command: BOOT BASIC.JRC -e ? Should print out the DOS commands that it implements. However: BOOT BASIC.JRC -e BASICA just results in DOSBox bombing out. So there's probably a reason that the extension is undocumented. Out of curiosity, I downloaded the source code and plan to sniff through it to see if I can see where it goes wrong. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted October 2, 2019 Author Share Posted October 2, 2019 Missile Math from issue 4.3 keeps causing an illegal function call in 490 when it tries to play the sound for a correct answer. Can't figure out why. MISSILEM.BAS Quote Link to comment Share on other sites More sharing options...
