Frankie Posted September 3, 2019 Share Posted September 3, 2019 When I run uflash and try to upgrade SDX to 4.49 I get the message - "IDE Plus (SDX) : unrecognized flash ROM or writes disabled. Set device properties manually?" It currently has SDX 4.48 installed. As far as I know writes are not disabled but I don't know how to check for sure. Frank Quote Link to comment Share on other sites More sharing options...
tuf Posted September 3, 2019 Share Posted September 3, 2019 (edited) Isn't uflash just for SIDE/Ultimates/Incognitos? Edited September 3, 2019 by tuf Quote Link to comment Share on other sites More sharing options...
Frankie Posted September 3, 2019 Author Share Posted September 3, 2019 Uflash version 3 supports: SIDE/SIDE2 cartridge MyIDE/Flash cartridge MyIDE II cartridge AtariMax 1Mbit cartridge AtariMax 8Mbit cartridge Sic! cartridge IDE Plus (SDX ROM) Quote Link to comment Share on other sites More sharing options...
BillC Posted September 3, 2019 Share Posted September 3, 2019 Just now, Frankie said: Uflash version 3 supports: SIDE/SIDE2 cartridge MyIDE/Flash cartridge MyIDE II cartridge AtariMax 1Mbit cartridge AtariMax 8Mbit cartridge Sic! cartridge IDE Plus (SDX ROM) According to FJCs website support for these devices in V.3 is preliminary/experimental. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 3, 2019 Share Posted September 3, 2019 19 minutes ago, Frankie said: When I run uflash and try to upgrade SDX to 4.49 I get the message - "IDE Plus (SDX) : unrecognized flash ROM or writes disabled. Set device properties manually?" It currently has SDX 4.48 installed. As far as I know writes are not disabled but I don't know how to check for sure. Do you have U1MB or anything else on the system? Things seem to work (at least they detect automatically) here as long as IDE+ SDX is ON and no other ROMs are present in the same area. It could simply be that your IDE+ board has a flash ROM which UFLASH doesn't recognize, of course, which is what the error message seems to be telling us. This is the FPGA-based version, correct? What chip IDs does the standard DLT SDX flasher report? Quote Link to comment Share on other sites More sharing options...
Frankie Posted September 3, 2019 Author Share Posted September 3, 2019 18 minutes ago, flashjazzcat said: Do you have U1MB or anything else on the system? Things seem to work (at least they detect automatically) here as long as IDE+ SDX is ON and no other ROMs are present in the same area. It could simply be that your IDE+ board has a flash ROM which UFLASH doesn't recognize, of course, which is what the error message seems to be telling us. This is the FPGA-based version, correct? What chip IDs does the standard DLT SDX flasher report? Am29F800B. I just flashed it with the standard flasher instead. 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 3, 2019 Share Posted September 3, 2019 5 minutes ago, Frankie said: Am29F800B There you go. Unsupported 8Mbit chip, as per error message. I might see about supporting it in a future revision, but it's news to me that this configuration exists (prior IDE+ revisions had 3 x 4Mbit flash ROMs). Rev. F isn't emulated and I don't have an example of it here to test. Quote Link to comment Share on other sites More sharing options...
