Tempest Posted September 28, 2019 Share Posted September 28, 2019 I have an IBM 5150 that has a weak power supply. When I put too many cards in my system there's noise on the 5v line which comes out the speaker as a 'whistle'. I cracked open my power supply today, but I can't see any obviously bad caps. Does anyone have any experience with fixing these? I think this may be beyond my abilities. Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 28, 2019 Share Posted September 28, 2019 I would check for hot voltage regulators. Quote Link to comment Share on other sites More sharing options...
Tempest Posted September 29, 2019 Author Share Posted September 29, 2019 41 minutes ago, wierd_w said: I would check for hot voltage regulators. Where are they? Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted September 29, 2019 Share Posted September 29, 2019 Apparently IBM never made schematics for their PSUs. Probably because they have upwards of 300V in places and don't want the average joe poking around in there. Sams Computerfacts has a reverse-engineered schematic for one of them though. If you see what looks like liquid residue around any of the large capacitors, that's a good sign of leakage. There does not seem to be an actual regulator on the 5V output line, only the -5V line. Instead, the early stage uses an oscillator to send square waves through a small transformer, which drives a larger transistor that outputs square waves through the large multi-tap transformer. One of those taps is the 5V output. It uses opto-isolators to decide when to cut back on oscillation. The most likely failure point does seem to be the capacitors though. Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted September 29, 2019 Share Posted September 29, 2019 Just another note though: The PSU can output up to 7A on its +5V line. If there are leaky capacitors on the motherboard, they could be consuming more than their share of that amperage. Quote Link to comment Share on other sites More sharing options...
