Captain Spazer Posted October 4, 2019 Share Posted October 4, 2019 I only have a basic grasp of the rnd, what I learned is thanks too Randomterrains wonderful website. But, I'm in a situation where I need to pick a random number between 0 and 5, is that possible somehow with math wizardry? Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted October 4, 2019 Share Posted October 4, 2019 2 hours ago, Captain Spazer said: I only have a basic grasp of the rnd, what I learned is thanks too Randomterrains wonderful website. But, I'm in a situation where I need to pick a random number between 0 and 5, is that possible somehow with math wizardry? How absolutely critical is it that it is in the range 0 to 5? Can you tweak your logic so that it's 0 to 7? Quote Link to comment Share on other sites More sharing options...
Captain Spazer Posted October 4, 2019 Author Share Posted October 4, 2019 Well, the reason is that I got a map grid of 5x5 rooms. If it's not possible, or super hard to do I guess I'll simply have to increase the number of rooms. I Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted October 4, 2019 Share Posted October 4, 2019 Failing being able to tweak the range, then you could choose a random number (0-255), and multiply by 6 and take the high byte. That will be a random number from 0 to 5. To multiply by 6 - just add 6 times would be your easiest. Here's an example; it requires a 2-byte zero page variable to hold the working sum. At the end, it spits out a number 0-5 in the accumulator. ; 6502 implementation lda #0 sta result+1 sta result jsr Rnd ; assumes random 0-255 now in 'rnd' ldx #5 mul6 clc lda rnd adc result sta result lda result+1 adc #0 sta result+1 dex bpl mul6 ; now accumulator= random from 0-5 inclusive Quote Link to comment Share on other sites More sharing options...
Captain Spazer Posted October 4, 2019 Author Share Posted October 4, 2019 Ahh, thank you! Quote Link to comment Share on other sites More sharing options...
bogax Posted October 5, 2019 Share Posted October 5, 2019 temp1 = rand/2 : temp1 = (temp1/2 + temp1)/32 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted October 5, 2019 Share Posted October 5, 2019 46 minutes ago, bogax said: temp1 = rand/2 : temp1 = (temp1/2 + temp1)/32 Very good. Is bB good aware enough to replace the divisions with shifts? Quote Link to comment Share on other sites More sharing options...
+Karl G Posted October 5, 2019 Share Posted October 5, 2019 8 minutes ago, Andrew Davie said: Very good. Is bB good aware enough to replace the divisions with shifts? Yes, assuming of course the division or multiplication is a power of two. Quote Link to comment Share on other sites More sharing options...
bogax Posted October 5, 2019 Share Posted October 5, 2019 10 minutes ago, Andrew Davie said: Very good. Is bB good aware enough to replace the divisions with shifts? Yes. this is the asm result jsr randomize lsr STA temp1 ; complex statement detected LDA temp1 lsr CLC ADC temp1 lsr lsr lsr lsr lsr STA temp1 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted October 5, 2019 Share Posted October 5, 2019 9 minutes ago, bogax said: Yes. this is the asm result jsr randomize lsr STA temp1 ; complex statement detected LDA temp1 lsr CLC ADC temp1 lsr lsr lsr lsr lsr STA temp1 Not much wrong with that! You could drop the CLC and save a couple of cycles and a byte and probably see no difference. Quote Link to comment Share on other sites More sharing options...
bogax Posted October 5, 2019 Share Posted October 5, 2019 (edited) another possibility temp1 = rand & 63 : temp1 = temp1 * 3 / 32 produces jsr randomize AND #63 STA temp1 ; complex statement detected LDA temp1 asl clc adc temp1 lsr lsr lsr lsr lsr STA temp1 Edited October 5, 2019 by bogax Quote Link to comment Share on other sites More sharing options...
bogax Posted October 5, 2019 Share Posted October 5, 2019 (edited) 40 minutes ago, Andrew Davie said: Not much wrong with that! You could drop the CLC and save a couple of cycles and a byte and probably see no difference. also the lda temp1 it's not as accurate as [similar] asm could be here's some javascript ranged rand generator the asm it produces asm jsr randomize sta temp1 lsr adc temp1 ror lsr lsr lsr lsr lsr sta temp1 end Edited October 5, 2019 by bogax Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 6, 2019 Share Posted October 6, 2019 I usually just grab stuff from the chart on the bB page until it matches what is needed: a = (rand/64) + (rand/128) + (rand/128) So that would be 0 to 3 plus 0 to 1 plus 0 to 1. Is that a more bloated way to do it? 1 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted October 6, 2019 Share Posted October 6, 2019 (edited) 52 minutes ago, Random Terrain said: I usually just grab stuff from the chart on the bB page until it matches what is needed: a = (rand/64) + (rand/128) + (rand/128) So that would be 0 to 3 plus 0 to 1 plus 0 to 1. Is that a more bloated way to do it? Don't know bB format, but doing the above using bitmasks instead of shifts would be way quicker... a = (rand & 3) + (rand & 1) + (rand & 1) The problem with this approach is that you are calling the random generator each time, and so, it becomes extremely slow in comparison to other methods. Edited October 6, 2019 by Andrew Davie 1 Quote Link to comment Share on other sites More sharing options...
bogax Posted October 6, 2019 Share Posted October 6, 2019 21 minutes ago, Andrew Davie said: Don't know bB format, but doing the above using bitmasks instead of shifts would be way quicker... a = (rand & 3) + (rand & 1) + (rand & 1) The problem with this approach is that you are calling the random generator each time, and so, it becomes extremely slow in comparison to other methods. it's also less random 1 Quote Link to comment Share on other sites More sharing options...
phoenixdownita Posted October 7, 2019 Share Posted October 7, 2019 If you have a grid 5x5 do 0 or 5 have special meaning? If not and you need a number from 0 to 4 (or 1 to 5 depending on how you index the grid), you could simply have a lookup table somewhere with the numbers 0,0,0,1,1,1,2,2,2,3,3,3,4,4,4,X (that's 16 entries). You can use the random 0-255 and just take the lowest 4 bits (aka AND 0x0F) as an index in the table. As you see the last element is X and there are options on how to go about its value/handling: 1) choose one and slightly change the balance (if you choose 0, that value would show up 4/16 instead of 3/16) 2) if you want more randomization you can start with 0 and every time X is the one picked up you add 1 to it so that you spread the unbalance over time (note that in this case the value you read from cell 0x0F has to be AND 0x0F) 3) if X comes up (meaning rand AND 0x0F == 0x0F) you can generate another rand, that happens around 1/16 so the extra cost is not executed that often it is smeared over avg of 15 good picks [actually given the rand gives you 0-255 you can just use the high part when that happens with no extra cost aka (rand AND 0xF0) LSR 4) for in as long as its value is also not 0x0F], note that 1/256 avg you need a 3rd rand, 1/4096 avg you need a 4th etc... etc... The same trick can be done for higher random values that are not perfect powers of two: just find a suitable multiplier that does not generate too big of a table and to which you can find a cheap way to compensate the unbalance. I do not know if you can spare 16bytes in your game for this table, strictly speaking a single byte can hold 2 values because your numbers are so small (0-4 -> 3bits) ... so it can be reduced to 8bytes (the high part contains one value, the low part the next), you can actually easily compress 3 of those values into one byte by choosing a different ordering for the elements in the lookup table and a suitable encoding if you really have to but that is even more code which may amount to more than the savings. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted October 28, 2019 Share Posted October 28, 2019 I usually have a counter variable that increments each start of the main program loop. Maybe he could use that to get extra range? if counter{0} then resultvar = rand&3 + 1 else resultvar = rand&3 Not the best code but I hope people see where I'm getting at. Quote Link to comment Share on other sites More sharing options...
