Larry
C060609
I'm cleaning off my work table, and ran across an unmarked packet of chips (probably from Best Elec.).  It contained 2 each MB81464-10 drams and a C060609.  (BTW, the print on the chips is clearly C0, and not CO.) Does anybody recognize what the C060609 is, and what these are used for?  It's a 20-pin IC, so that should narrow it down.  I must have bought these for some type of upgrade -- 600XL, maybe?  Hope they are for the 600XL -- I have a new one that I'd like to upgrade this winter.
Thanks,
Larry
Thanks!  Now here's a second part -- can the 81464 be used for the 600XL upgrade?  The pinouts look the same.  If these are OK, I'll use them on that 600XL expansion.
9 minutes ago, ndary said:
Hi Larry.. These are 64k ram chip and an MMU
From the part#(81464) these RAM chips are likely 64k x 4 bit DRAM, the MMU is for the 1200XL/1400XL.
Just had a quick look at the datasheets. I have some TMS4164 RAM chips here and these can, I believe, be fitted to an XL (same pinouts as others I've seen fitted). I compared the datasheet to the chips you have and the pinouts are completely different.
@BillC are right 😉.
The xx464 DRAM chips are 64kx4 Bit organised (2 chips for 64kB, mostly used in ATARI XEGS, and some of the latest 65XE/800XE/130XE)
See Datasheet attached...
The xx164 instead are 64kx1 Bit organised (8 chips for 64kB), used in lots of XL/XE and lots of other system too...)
Gtx.,
andY
81464_DRAM.pdf
Edited by andymanone
Hi-
Thanks for the input.  The chips I was comparing the 81464 ones were 4464 which are typically mentioned in the 600XL 16k, 2-chip upgrades (to 64k, 2-chip memory).
