I have an ATR 8000 that does not power on. I was wondering if anyone has experience fixing or replacing the power supplies for these? Looks like an unusual PSU. Many thanks!
How do you know it's not powering on?  Have you tested voltages anywhere or are you just going by the light in the power switch?  Hard to be sure from the pic, but check the solder on the diodes next to the power connector block. Looks like there might be cracks.
Would love to get a dump of that EPROM  if you have the means.
Edited by JR>
No light. No hum. I do plan to check all the contacts. Am curious if anyone has actually replaced a PSU in one of these. Thanks!
The problem is probably limited to something between the wall outlet and transformer then.  Most of the "power supply" is built in to the motherboard.  There's really only the transformer, switch, power cord and socket that aren't part of the MB.
I think there may be an inline fuse on one of the wires between the power cord socket and the transformer.
The power supply circuit isn't unusual, other than the transformer not being external it is similar to the 1050 power supply circuit, the main difference is the use of a 14V center tap transformer(no voltage doubler circuit required for +12VDC). It has 2-7805 voltage regulators with, and 1-7812 without, heatsinks. The light color TO220 chip furthest from the transformer is a TIP30 used to generate -5V/-12V, most likely for the RS232 interface.
The power supply schematics I found at archive.org show an RFI filter, 3/4A fuse, switch and MOV between power and the transformer.
https://ia801604.us.archive.org/1/items/atr8000/ATR8K4.pdf
Manuals/rest of the schematics are there as well.
https://archive.org/details/atr8000
