Lillapojkenpåön Posted December 19, 2019 Share Posted December 19, 2019 (edited) I found an old collision prevention example here on the forum (collision_prevention_with_detection_2013y_05m_14d_0155t) and started to try to implement it in a little test, it made alot of sense, this is how I understood that one temp5 = ((player0x-15)/4)+1 ;converts player0x right side coordinates to pfpixel coordinates temp3 = ((player0x-15)/4) ;converts player0x left side coordinates to pfpixel coordinates temp6 = ((player0y-1)/8)-1 ;converts player0y coordinates to pfpixel coordinates just above the sprite So I picture those cordinates changing every four regular pixels you move, kinda like a laggy roof that's following you then you pfread that area for pfpixels by checking left and top, and right and top if pfread(temp5,temp6) then if pfread(temp3,temp6) then goto __Skip_Move_Up But then I looked if it had been updated on RT and it had and I'm a little confused with the new one temp5 = (player0x-10)/4 temp6 = (player0y)/8 if temp5 < 34 then if pfread(temp5,temp6) then goto __Skip_Joy0_Down temp4 = (player0x-17)/4 if temp4 < 34 then if pfread(temp4,temp6) then goto __Skip_Joy0_Down temp3 = temp5 - 1 if temp3 < 34 then if pfread(temp3,temp6) then goto __Skip_Joy0_Down Why are there four conversions, and three pfread for up and down? Why check if the horisontal position is less than 34, isn't 31 the highest? And I get that two pfpixels covers the players width but how is the height taken care off for left and right? Edited December 19, 2019 by Lillapojkenpåön Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted December 19, 2019 Share Posted December 19, 2019 Do you have a link to the post that has "collision_prevention_with_detection_2013y_05m_14d_0155t"? Here are a few other versions we should look at: https://atariage.com/forums/topic/239220-collision-prevention-with-adjustable-sprite-height-and-width/ https://atariage.com/forums/topic/212293-attention-good-programmers-can-you-simplify-this-code/?do=findComment&comment=2756634 https://atariage.com/forums/topic/212293-attention-good-programmers-can-you-simplify-this-code/?do=findComment&comment=2758271 I don't remember why I used 34 instead of 32. The collision prevention programs on the bB page might need to be updated. Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted December 25, 2019 Author Share Posted December 25, 2019 (edited) Oh, I get it now This is as simple as I could make it simple_collision_prevention_with_detection.bas If we use the correct numbers, the player will overlap one scanline at the top, and be one scanline above the bottom, since it can only be placed every other scanline I guess. so I check one pixel above that for up, and also for the top pixel for left and right to keep it a box, that results in one scanline above and one below. Edited December 25, 2019 by Lillapojkenpåön 1 Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted December 26, 2019 Author Share Posted December 26, 2019 I made another one that supports variable speeds. If your speed is let's say three and you're going right it will loop and check ; 00111100A ; 01111110 ; 11000011 ; 10111101 ; 11111111 ; 11011011 ; 01111110 ; 00111100B ; 00111100 A ; 01111110 ; 11000011 ; 10111101 ; 11111111 ; 11011011 ; 01111110 ; 00111100 B ; 00111100 A ; 01111110 ; 11000011 ; 10111101 ; 11111111 ; 11011011 ; 01111110 ; 00111100 B ; 00111100 A ; 01111110 ; 11000011 ; 10111101 ; 11111111 ; 11011011 ; 01111110 ; 00111100 B if there is playfield in the way the player will snap to the edge, if not it will move normally. simple_collision_prevention_with_detection_for_variable_speed.bas Quote Link to comment Share on other sites More sharing options...
