+Random Terrain Posted February 16, 2020 Share Posted February 16, 2020 Back in 2013, roland p told me about Voder: youtu.be/0rAyrmm7vv0 youtu.be/5hyI_dM5cGo EricBall said this in 2017: Quote The patent for the Voder shows it's done by passing a pitched buzz or white noise through a set of ten dynamically weighted band pass filters. Not the same as AUDC / AUDF / AUDV. However, it would be interesting to see whether AUDC / AUDF / AUDV could be used to generate phonemes. EricBall also made a blog post about it: TIA Audio Noise Generator Redux As I've said in other threads, I bet someone with a big brain could figure out how to produce phonemes by only fiddling with AUDV, AUDC, and AUDF, since certain tone frequency combinations almost sound like a human voice already. For example, you can make a T sound using AUDC 8, starting at AUDF 31 and flipping over to 0 and maybe ending at 1, 2, or 3: randomterrain.com/atari-2600-memories-program-tone-toy-2008.html I've been hoping that instead of using digitized speech or an external speech synthesizer, we could track down or bring out the phonemes that already exist inside of the Atari 2600. We could have a collection of phonemes that programmers could play in a sequence to make words or maybe even sing. Programmers would no longer have to waste space on digitized speech or hope that players have an external speech synthesizer. The amount of space needed for Voder-like phoneme data should be much smaller than what is needed for digitized speech. I've tried to find phonemes by randomly goofing around with Tone Toy 2008, but with no real understanding of phonemes or how sound works on the Atari 2600, it could take a few thousand years. I'm confident that someone who knows about phonemes and Atari 2600 sound could create Voder-like data that programmers can use in their games. 1 Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted February 19, 2020 Share Posted February 19, 2020 From what I understand the speech in Draconian is made by updating the sound every scanline, So I thought about just looping through the sound updates a couple times in bB, it wouldn't be every scanline, but atleast more complex sounds with several updates per frame, not sure if it works but this sounds very motory. If it works you could do phonemes. AUDV0 = 10 : AUDC0 = 8 for temp5 = 0 to 31 AUDF0= temp5 AUDC0 = temp5 next 2 Quote Link to comment Share on other sites More sharing options...
RevEng Posted February 22, 2020 Share Posted February 22, 2020 I took another stab at this recently. At this point I think it's a lost cause using just TIA waveforms, due to the lack of difference in texture between them. Varying them quicker than 60Hz sounds promising in theory, but you don't know the phase of the waveform as you cut it off, and changing a waveform at different points in it's phase result in different frequency content. Someone might get somewhere with DPC+ style soft-synth, since then it's just a matter of doing your wave simulation on the ARM, but there are trade-offs with that technique because you need to update the sound register throughout vblank and overscan too. FWIW I know enough about phonemes that I wrote a big chunk of a speakjet clone on a low-powered microcontroller, before getting bored with the project (static vowel sounds, vowel sounds that shifted from start to finish, some fricatives, and probably more I'm forgetting). I've tried the same technique that works great on the microcontroller - modulating sine or glottal shaped waves - only using TIA's squarish waves, but it doesn't really work. 1 Quote Link to comment Share on other sites More sharing options...
