mario64 Posted February 21, 2020 Share Posted February 21, 2020 I’m a bit confused as to the best Colecovision version of Donkey Kong (and DK Jr). I see there are ADAM versions but also see mention of SGM-enhanced versions by Opcode and also by Team Pixelboy. Thing is, I can’t find any real details nor any purchase links to these enhanced versions. Do they actually exist and, if so, where can you purchase them? Thanks Quote Link to comment Share on other sites More sharing options...
128Kgames Posted February 21, 2020 Share Posted February 21, 2020 Adam ddp versions have animations and 4th board, TP versions should have the same on cartridge. Opcode has not released their version. You can search auction sites and or look in the AA selling forum or post a wanted request. Quote Link to comment Share on other sites More sharing options...
mario64 Posted February 21, 2020 Author Share Posted February 21, 2020 4 minutes ago, 128Kgames said: Adam ddp versions have animations and 4th board, TP versions should have the same on cartridge. Opcode has not released their version. You can search auction sites and or look in the AA selling forum or post a wanted request. Thank you. So ADAM and Team Pixelboy versions are identical? Quote Link to comment Share on other sites More sharing options...
128Kgames Posted February 21, 2020 Share Posted February 21, 2020 2 minutes ago, mario64 said: Thank you. So ADAM and Team Pixelboy versions are identical? In theory I believe "yes" but I've never opened my TP copies and played them so I can't say for sure. Keep in mind to play the DDP versions you'll need an ADAM or ColecoVision expansion module #3 (which you probably already knew). Quote Link to comment Share on other sites More sharing options...
doubledown Posted February 21, 2020 Share Posted February 21, 2020 4 hours ago, 128Kgames said: In theory I believe "yes" but I've never opened my TP copies and played them so I can't say for sure. Keep in mind to play the DDP versions you'll need an ADAM or ColecoVision expansion module #3 (which you probably already knew). And if you want to play the ADAM DDP version, do yourself a favor and get a disk drive, and play it off of that (or some other modern virtual drive concept) because DDP loading times are almost intolerable! Quote Link to comment Share on other sites More sharing options...
Swami Posted February 21, 2020 Share Posted February 21, 2020 3 hours ago, doubledown said: And if you want to play the ADAM DDP version, do yourself a favor and get a disk drive, and play it off of that (or some other modern virtual drive concept) because DDP loading times are almost intolerable! I've always wondered how much of a leap it would be from the SGM to an EM3 clone with an interface like the Atari 8-bit SDrive-MAX that can read disk, cassette and ROM images, and a keyboard port. Since the Adam can play SGM carts without the SGM, I sense there is some similarity between the Adam and SGM. Quote Link to comment Share on other sites More sharing options...
mr_me Posted February 22, 2020 Share Posted February 22, 2020 The sdrive-max just emulates the device. With a colecovision not only do you have to emulate the device but you have to emulate the adamnet bus and controller. The only thing the opcode sgm has from the adam is ram. Converting the ddp extra large games to high capacity cartridges is the logical thing to do. And the opcode sgm also has a sound chip that the adam doesn't have. But emulating an adam expansion in fpga is certainly doable, although I don't think an fpga adam exists so there's a bit of work there. Quote Link to comment Share on other sites More sharing options...
NIAD Posted February 22, 2020 Share Posted February 22, 2020 On 2/21/2020 at 12:57 PM, doubledown said: And if you want to play the ADAM DDP version, do yourself a favor and get a disk drive, and play it off of that (or some other modern virtual drive concept) because DDP loading times are almost intolerable! For the DK and DK Junior Super Games, the load times from data pack were not that bad at all especially considering that the ADAM basically multitasks and loads the next level while you are playing the current level. FWIW, the best option is the ADAM Drive Emulator (ADE) by Sean Myers (opensource project can be found on GitHub) to just run the Disk or Data Pack image files... that is if you own an ADAM. The cartridge conversions of these ADAM Super Games are hard to come by, so if they become available, a hefty price will have to be paid. Quote Link to comment Share on other sites More sharing options...
mr_me Posted February 22, 2020 Share Posted February 22, 2020 If you had a rom file of the cartridge conversion it should run through a flash cartridge or the phoenix system. Quote Link to comment Share on other sites More sharing options...
ColecoJoe Posted February 22, 2020 Share Posted February 22, 2020 They also run on the CoolCV emulator. PM me if you need the roms. Quote Link to comment Share on other sites More sharing options...
