Geoffrey Posted February 21, 2020 Share Posted February 21, 2020 Hi i bought a famicom disk system and i replaced the belt and i had it correctly on there but the belt came off after i turned the wheel a few times can someone help thanks Quote Link to comment Share on other sites More sharing options...
CatPix Posted February 22, 2020 Share Posted February 22, 2020 (edited) Have you cleaned the remains of the old belt? Sometime small bits get stick, or melted gunk remains and cause such jams. Also if it's clean, make sure to push the belt all the way down on the larger spool. There isn't any groove on it so if your belt is a little low on the spool it will slide out. Edited February 22, 2020 by CatPix Quote Link to comment Share on other sites More sharing options...
