+Vorticon Posted April 5, 2020 Share Posted April 5, 2020 2 hours ago, HOME AUTOMATION said: Looks like, you left out this reciprocal instruction... MOV R11,@RETADR Fortean 99 handles that automatically. All I have to do is reserve 4 bytes in BASEAD and RETADR. I should clarify that the subprogram returns normally to the main program and the main issue is when that main program terminates. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted April 6, 2020 Share Posted April 6, 2020 OK I figured out how to properly restore the Fortran 99 environment after accessing files in bitmap mode with assembly subroutines. Apparently the CRT has to be reopened as FILE 6 using something called the File Open Processor routine located at >2070 and I have no clue as what that routine does exactly. I got this straight out from the CALL FILES subroutine by sheer trial and error. Here's the revised bitmap image display routine: DEF IMGSHW VMBW EQU >2048 DSRLNK EQU >2058 OPFILE EQU >2070 FILE OPEN PROCESSOR PABADR EQU >3A12 PAB ADDRESS IN VDP BASEAD BSS 2 SUBROUTINE RETURN POINTER RETADR BSS 2 SUBROUTINE RETURN POINTER IMGSHW DATA 0 NUMBER OF PASSED ARGUMENTS DATA BASEAD PABP DATA >0500,>0000,>0000,>1800,>000D TEXT 'DSK3.VIGER4_P' EVEN PABC DATA >0500,>2000,>0000,>1800,>000D TEXT 'DSK3.VIGER4_C' EVEN CRTPAB DATA >0003,>0000,>5000,>0000,>0003 TEXT 'CRT' EVEN * LOAD PATTERN FILE LI R0,PABADR LI R1,PABP LI R2,23 BLWP @VMBW LI R6,PABADR+9 MOV R6,@>8356 BLWP @DSRLNK DATA 8 * LOAD COLOR FILE LI R0,PABADR LI R1,PABC LI R2,23 BLWP @VMBW LI R6,PABADR+9 MOV R6,@>8356 BLWP @DSRLNK DATA 8 * RETURN TO MAIN PROGRAM LI R0,6 LI R1,CRTPAB BL @OPFILE MOV @BASEAD,R3 MOV @RETADR,R11 B *R11 END The 3 lines below the RETURN TO MAIN PROGRAM comment is where the magic occurs. Don't ask me why but would love to hear an explanation if somebody has one 1 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted April 6, 2020 Author Share Posted April 6, 2020 Finally got some simple i/o going... Some first observations: 1) I kept getting an odd error - don't understand >eod - Vorticon nailed this error, some junk had appeared after end... ( I think this is a bug)... Easy enough to work around once you know what the problem is..... 2) the end in the read, seems to sense end of data line, not end of file, I had to default to reading for a z (or 9999) record at the end of the data file. 3) could not get Hollerith or S types to work in a file read. 4) could not get just A to work. 5) what ended up working was 8a1 - because, it seems like fortran99 only wants to do single character i/o. 1 99 FORTRAN File: DSK2.FI_S Page 1 1. C FI_S - FILE I/O SOURCE 04/06/2020 2. C2345678 3. C DEFINE DATA TYPES 4. CHARACTER NAME(8) 5. INTEGER ERRSTS, NSTU, GRATOT, AVGGRA 6. 7. INTEGER FILEID(8), GRADE 8. DATA FILEID / 10HDSK2.FI_D / 9. 10. C INITALIZE DATA 11. NSTU = 0 12. GRATOT = 0 13. AVGGRA = 0 14. 15. CALL FILES (3) 16. CALL OPEN ( 3, FILEID, 2, 0, 1, 0, 80, ERRSTS) 17. 18. 1 FORMAT (' ', C12, M1.1, ' *** GRADES ***' ) 19. 2 FORMAT (' ', ' ') 20. WRITE (6,1) 21. WRITE (6,2) 22. 23. 10 FORMAT ( 8A1, I3) 24. 11 READ (3, 10, END=99, STATUS=ERRSTS ) NAME, GRADE 25. 26. IF (GRADE.EQ.999) THEN 27. GO TO 25 28. ENDIF 29. 30. 20 FORMAT (' ', 8A1 , 1X, I3) 31. WRITE (6,20) NAME, GRADE 32. 33. GRATOT = GRATOT + GRADE 34. NSTU = NSTU + 1 35. 36. GO TO 11 37. 38. 39. 25 CONTINUE 40. 30 FORMAT (' ',' ') 41. 35 FORMAT ('+', 'AVG GRADE:') 42. WRITE (6,30) 43. WRITE (6,35) 44. 45. C CALCULATE AVG GRADE - SIMPLE AVG 46. AVGGRA = GRATOT / NSTU 47. 40 FORMAT (' ', I3) 48. WRITE (6,40) AVGGRA 49. 50. 51. C 3 - FILE NUMBER, NO EQ TO A FORTRAN UNIT NUMBER USED IN FORMAT 52. C 2 - INPUT MODE 53. C 0 - DISPLAY 54. C 1 - VARIABLE 55. C 0 - SEQ ACCESS 1 99 FORTRAN File: DSK2.FI_S Page 2 56. C 80 - MAX RECORD LENGTH 57. C ERROR - VARIABLE TO RETURN ERROR IN 58. 59. C SEE PAGE 07-11 - FILE I/O REF 60. C SEE CALC1 FOR FILE I/O EXAMPLES 61. 62. C NAME = 8 HOL 63. C SPACE = 1 HOL 64. C GRADE = 3 INT 65. 66. 67. 99 CALL CLOSE ( 3 ) 68. STOP 69. END and the data file... 1 99 FORTRAN File: DSK2.FI_D Page 1 1. DAN 060 2. SALLY 100 3. BOB 074 4. JOE 097 5. EOF 999 Small working, byte size pieces of code is what you build off of. 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted April 6, 2020 Share Posted April 6, 2020 Yeah file I/O in Fortran 99 is not for the faint of heart I feel it would be better and much faster to do all file access from assembly except for the simplest of tasks... Quote Link to comment Share on other sites More sharing options...
+dhe Posted April 7, 2020 Author Share Posted April 7, 2020 So, it was asked here, how does fortran99 compare speed wise to other compilers. I decided to write two little programs that looped and printed a value. Our first contender, while not a compiled language, was BASIC 10 FOR I=1 TO 100 20 PRINT I 30 NEXT I This took 19 seconds to run. For a comparison - in BASIC on my little Cambridge Z88 - it took 8 seconds. Next up was FORTRAN99 1 99 FORTRAN File: DSK2.SC_S Page 1 1. C QUICK FOR LOOP SPEED COMPARISON VS TI BASIC 04/07/2020 2. C234567 3. INTEGER I 4. 5. CALL CLEAR 6. 7. I = 1 8. DO 1 I=1,100 9. PRINT , I 10. 11. 1 CONTINUE 12. STOP 13. END This took 8 seconds to run. Of course, even the simplistic program wasn't a walk in the park and included a fight with the compiler and linker. Over and above speed, not being tied to line numbers is great. I think Microsoft realized late in life, line numbers {BAD}, because on the Tandy Model 100, the last machine, I'm told that Bill Gates worked on, when you type edit, the line numbers are there, but your in full screen editing mode. VORTICON again came to my rescue. The take away, I believe, if you want to use call clear (and maybe print) you have to link in the gl (graphics) library. The manual says, you will keep being prompted for libraries, until all dependencies have been resolved. That was not the behavior I was seeing. Instead, I would enter fl, and it would take me to the section about symbolic debugging. To force what I needed to happen, I entered gl on the library line, the linker, then prompted me again, for a library, this time, I entered fl. That did the trick, I was now able to run the program, I did end up with so oddities, in the compiler. It would say I had 1 Error(s) - but it wouldn't tell me what that error was! fortran99 can be a tough task master! ? I'm very much, hoping someday the source for FORTRAN99 show up, because, as a new user, I'm seeing a few rough spots, that probably wouldn't be that hard to fix, with specific test cases. d. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted April 7, 2020 Share Posted April 7, 2020 (edited) In Extended Basic it takes about 10 secs. I believe programs that scroll the screen will spend most of their time in the scrolling routine, so it's not a good comparison of the actual languages. Edited April 7, 2020 by Asmusr Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 7, 2020 Share Posted April 7, 2020 About 2 seconds in fbForth: : SC_S \ print index value of 100 times through loop CLS \ clear screen 100 0 DO I . \ print loop index LOOP ; ...lee Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 8, 2020 Share Posted April 8, 2020 : SC_S \ print index value of 100 times through loop PAGE \ clear screen 100 0 DO I . \ print loop index LOOP ; Same here. I would think that this Fortran compiler is pretty naive, meaning it doesn't have a lot of room for optimizing options and simply converts the source code one way. The TI99 doesn't give it much room to flex those kind of muscles. It's remarkable that it does as much as it does. It would be fun to see the table of emitted routines. 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted April 8, 2020 Share Posted April 8, 2020 13 hours ago, Asmusr said: In Extended Basic it takes about 10 secs. I believe programs that scroll the screen will spend most of their time in the scrolling routine, so it's not a good comparison of the actual languages. Indeed! Rewriting the Fortran program to avoid scrolling, it took it 2.63 seconds to complete the loop. It would have been even faster without the CALL CLEAR at the beginning. It took TI BASIC 13.18 seconds for something similar, so about 5x slower. PROGRAM LOOP CALL CLEAR DO 10 I = 1, 100 10 WRITE(6, 20) I 20 FORMAT('+', I3) STOP END Now taking the CALL CLEAR and PRINT out of the programs, TI BASIC clocked at 0.93 seconds! I couldn't time the Fortran equivalent as it was way too fast for my reflexes. The lesson? Don't print anything to screen unless you absolutely have to 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 8, 2020 Share Posted April 8, 2020 Does Fortran default to floating point or integers? Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted April 8, 2020 Share Posted April 8, 2020 So I've been playing with this Fortran package for a couple of weeks. Impression? It's definitely a clunky language with very limited file I/O and no support for string functions, but with superior math functions and numerical representations. It has its limited uses, but it's certainly not a good general purpose language, although the addition of the TI specific graphic extensions helped getting it closer in that direction. As TheBF mentioned, it likely does not optimize code very well, so performance has much to be improved upon. Of course the latest version of Fortran (Fortran 2018) has since brought the language pretty much on par with modern languages with all the associated facilities such as OOP for example. Nonetheless, it's still an impressive achievement given the limitations of the TI, and had it come out earlier in the prime of the TI market window (early 80's), it would have been a runaway hit particularly among the engineering types. So what to do with it? I'd really like to come up with a project using it as a personal challenge and I have a couple of ideas. Developing in Fortran 99 is rather painful for complex programs, so that will be interesting, but since I've put in the effort to learn it, I should at least have something to show for it I have a simple rule: if I learn a new language, I should create at least one meaningful program using it. This has been true for TI BASIC, XB, TurboForth, C99, Turbo Pascal, TMS9900 assembly, Intel 8080 assembly, and Python, so I'm going to try not to break with that tradition! 2 Quote Link to comment Share on other sites More sharing options...
+dhe Posted April 8, 2020 Author Share Posted April 8, 2020 (edited) >Does Fortran default to floating point or integers? variables starting with i,j,k,l,m,n are by default integer. Edited April 8, 2020 by dhe 1 Quote Link to comment Share on other sites More sharing options...
wolhess Posted April 8, 2020 Share Posted April 8, 2020 4 hours ago, Vorticon said: This has been true for TI BASIC, XB, TurboForth, C99, Turbo Pascal, TMS9900 assembly that is very impressive! What kind of program did you develop in Turbo Pascal? With Turbo Pascal I wrote a few small programs on a Schneider CPC464 more than 30 years ago. On the TI-99, I want to look at that again. I am despite the mentioned drawbacks of the opinion that Fortran deserves a chance on the TI. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted April 8, 2020 Share Posted April 8, 2020 2 hours ago, wolhess said: that is very impressive! What kind of program did you develop in Turbo Pascal? With Turbo Pascal I wrote a few small programs on a Schneider CPC464 more than 30 years ago. On the TI-99, I want to look at that again. I am despite the mentioned drawbacks of the opinion that Fortran deserves a chance on the TI. I agree. It's just not the easiest of environments to work with, although UCSD Pascal comes close Here are my Turbo Pascal projects, all done on the Coleco Adam computer under CP/M. The ADAM computer uses the same 9918 VDP chip as the TI incidentally. 1 Quote Link to comment Share on other sites More sharing options...
wolhess Posted April 8, 2020 Share Posted April 8, 2020 There is a lot of work involved, for me it looks as if you have adapted Turbo Pascal to the Coleco Adam very well. Thank you for providing the videos. I find the possibility of supplementing Turbo Pascal with assembly routines very good. Would that also be possible on the TI Turbo Pascal? Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted April 8, 2020 Share Posted April 8, 2020 59 minutes ago, wolhess said: There is a lot of work involved, for me it looks as if you have adapted Turbo Pascal to the Coleco Adam very well. Thank you for providing the videos. I find the possibility of supplementing Turbo Pascal with assembly routines very good. Would that also be possible on the TI Turbo Pascal? Turbo Pasc 99 is an incomplete implementation of Pascal, and is missing pointers among other things. Also I don't think we ever got the compiler to fully work. Anders Persson translated the docs from German (not an issue for you though!), and I'll have dig them out to see if there is access to assembly subroutines with it. UCSD Pascal is a far better implementation, but the environment is clunky. Anders is the resident guru on it and has done some amazing extensions to it. 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted April 8, 2020 Author Share Posted April 8, 2020 Today's quicky. Graphics Experiment. Unlike my previous attempts, this one worked exactly as expected the first time~! 1 99 FORTRAN File: DSK2.GE_S Page 1 1. C GRAPHICS EXAMPLE - 04/08/2020 - DHE 2. C2345678 3. CALL SET32 4. C THIS GETS YOU COLOR AND SPRITE ROUTINES 5. 6. CALL COLOR ( 10, 10, 1) 7. C CHAR SET, FORE, BACK COLORS 8. 9. CALL CHAR ( 111, '1824429999422418'X ) 10. C SPRITE BUILT WITH FSF.IO SPRITEPAINTER 11. 12. PRINT , 'Hello World' 13. 14. CALL DELAY ( 30 ) 15. C WAITS 3 SECONDS, COMPARE WITH CALL WAIT 16. 17. CALL SPCHAR ( 128, '1824429999422418'X ) 18. C CHARCODE 128-255 ONLY 19. CALL SPRITE ( 1, 128, 5, 92, 1, 24, -1, 3) 20. 21. CALL DELAY ( 40 ) 22. 23. STOP 24. END 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 8, 2020 Share Posted April 8, 2020 3 minutes ago, Vorticon said: Turbo Pasc 99 is an incomplete implementation of Pascal, and is missing pointers among other things. Also I don't think we ever got the compiler to fully work. I managed to write some few TurboPasc'99 programs back in those days. If someone is interested in trying UCSD Pascal, remember that it is available in MAME, maybe just to get an idea (and for the sensation of having have saved several hundreds of DM/Dollars/FF/Pta/Lit (no Euro in that era)). 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted April 8, 2020 Share Posted April 8, 2020 dhe, would it be possible for you to post the program listings without line numbers and use the code functionality of the forum (</> icon in the message bar)? As they are, it is difficult to copy and paste the programs without significant editing... Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted April 8, 2020 Share Posted April 8, 2020 41 minutes ago, mizapf said: I managed to write some few TurboPasc'99 programs back in those days. If someone is interested in trying UCSD Pascal, remember that it is available in MAME, maybe just to get an idea (and for the sensation of having have saved several hundreds of DM/Dollars/FF/Pta/Lit (no Euro in that era)). It's definitely usable, but without pointers, linked lists etc..., certainly crippled. I think the problem with the compiler is a bad disk image. If you happen to still have the disks, would you mind posting them? As for UCSD Pascal, it's Achilles heel was the very high cost of entry (3 disk drives, 32K, pcode card), so yes using an emulator is definitely the cheaper option I should mention that it is also fully implemented in Classic 99 as well. Quote Link to comment Share on other sites More sharing options...
+dhe Posted April 8, 2020 Author Share Posted April 8, 2020 What I have been doing, is printing the source {one of the options on the edit menu} to DSK4.?W.{SOMETHING}_LI - and then just navigating to that directory with textpad. Here is another, iteration. ti99dir, in to the source disk and then opening the file. C GRAPHICS EXAMPLE - 04/08/2020 - DHE C2345678 CALL SET32 C THIS GETS YOU COLOR AND SPRITE ROUTINES CALL COLOR ( 10, 10, 1) C CHAR SET, FORE, BACK COLORS CALL CHAR ( 111, '1824429999422418'X ) C SPRITE BUILT WITH FSF.IO SPRITEPAINTER PRINT , 'Hello World' CALL DELAY ( 30 ) C WAITS 3 SECONDS, COMPARE WITH CALL WAIT CALL SPCHAR ( 128, '1824429999422418'X ) C CHARCODE 128-255 ONLY CALL SPRITE ( 1, 128, 5, 92, 1, 24, -1, 3) CALL DELAY ( 40 ) STOP END 2 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 9, 2020 Share Posted April 9, 2020 21 hours ago, Vorticon said: It's definitely usable, but without pointers, linked lists etc..., certainly crippled. I think the problem with the compiler is a bad disk image. If you happen to still have the disks, would you mind posting them? I'll have to search through my collection. Maybe you can send me your copy so I can see whether it is really a corruption. I seem to remember that there was a glitch with the loader, which assumed that an unused memory space looks like FF00FF00... Quote Link to comment Share on other sites More sharing options...
+dhe Posted April 9, 2020 Author Share Posted April 9, 2020 I'm really hoping Beery can get the source to FORTRAN99, there are a couple of things, I'd like to change, and I think easy fixes and upgrades (even for me). Like, I'd like to normalize more the selections on edit/compiler and link (like on compile, listing file is the third item asked for, on link the first) - consistency would help. I'd also like to modify, so if you have a minimem, or supercart, your default selections would be saved after the first run. fortran99 could have used a few more years of active development and maybe 20 active developers to shake out rough patches.... d. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted April 9, 2020 Share Posted April 9, 2020 1 hour ago, mizapf said: I'll have to search through my collection. Maybe you can send me your copy so I can see whether it is really a corruption. I seem to remember that there was a glitch with the loader, which assumed that an unused memory space looks like FF00FF00... I don't actually own the original package. I just used the disk images in the pinned Development Resources thread on this forum... Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 9, 2020 Share Posted April 9, 2020 I just did some checks in MAME with the version from the Development Resources thread. - It is running in MAME, see the screenshots below. However, it seems as if there is some kind of copy protection, because after loading TP99, a lot of sectors are loaded before the greeting screen appears, and there is no file of that size. I let TIImageTool do a file system check, and the attached log proves it. - Files that were built with TP99 only run in MAME when the internal 16bit 32K is turned off, and the external 32K expansion is used. This is what I just verified with MAME when trying to load SIEVE1. The reason is, as I remember, that the loader tests whether the libraries have already been loaded by checking whether the memory is filled with FF00. The internal 32K are filled with 0000, so the libraries are not loaded. This was the reason why I stopped working with TurboPasc'99 around 1986, only a short time after I started with it. This was the time when I modded my TI console, and then, for some reason that was obscure to me back in those days, none of the Pascal programs could be loaded anymore. Maybe one can make them run again using a loop of CALL LOAD(A,255,0) over the relevant memory space. tp99compcheck.txt Quote Link to comment Share on other sites More sharing options...
