catmando
Atari Jaguar Scart Switch
Anyone know the purpose of this switch on my jaguar scart cable?
Looking inside it seems to be a selector between two wires.
Maybe to change between csync or sync on composite? Without any shielding really on that cable I’d probably chuck it.
Agreed. Looks like someone took an IDE cable and just wired it up to tap into the RGB points of the a/v connector and connected it to the corresponding SCART pins. I wouldn't trust it.
20 minutes ago, catmando said:
Interesting, the cable was supplied with my brother's Jaguar that he bought back in in the 90s
That's certainly not an "official" product ;)
Hell no.
The official Jag scart cable is among the finest quality 1st party cables.
It's as thick as your thumb and weighs a ton.
2 minutes ago, Gummy Bear said:
Hell no.
You got that right!
Scart vs. S-video - Atari Jaguar - AtariAge Forums
21 minutes ago, eightbit said:
You got that right!
I assume these are impossible to get? What's the next best thing available, I've read some posts about composite sync and csync - bit confused....
Old school custom job. :) Belongs in a museum!! The switch is as mentioned earlier, likely toggling between csync and luma or composite video. Monitors of the 80s and 90s could be pickier and only accept TTL level csync, which could damage consumer television sets so you used luma/composite for those.
Build your own or buy from Retro Access, they are consistent in following technical specifications with individual console video outputs.
Retro Access had a estimated date of May 3rd for the availability of the Jag SCART cable and then bumped it up to June something....so I don't know what the issue is there. So, not wanting to wait I ordered mine from Retro Gaming Cables in England on 4/23. It still has not arrived. No good fast way to get anything anymore ;)
I got a similar cable (but without the switch) with a sold-as-new boxed Jaguar I bought from Telegames UK. I can confirm the cable quality is poor, and that unlike the thick black cable which photo was posted above, it introduces interference.
Retro Access I think makes the best Jag RGB cable.  Nice slots to fit in the proper way too.
Brad at Best Electronics sells new Atari brand Jag RGB cable.  Mine had lose wire, but was able to repair it.
I have issues with random wavy lines with my RGC Jag RGB cable.  No slots like the Retro Access cable either, so its possible to install upside down.
I have one of these coming which outputs the RGB through a 9-pin DSUB connection. I have an OSSC and a cable that brings the 9-pin DSUB to a 15-PIN VGA style connector in order to connect it to the RGB VGA port on the OSSC. So I am excited to see how this all works out :)
  I got a whole bunch of the originals from Best Electronics a couple years ago. Not sure how quickly they are selling but he seemed to still have a lot of stock at the time.
Where are you getting this from?
I have the Retro Access cable and it works beautifully.  I have many of their cables and can't recommend them enough, plus they are really good at answering any questions you may have.  Here's a link to their Jaguar cables:
https://retro-access.com/collections/atari-jaguar-cables
Do the official jag cable, the retro-access cable and the retrogamingcables leads have any special circuits inside them or are they just pin to pin connections?
The switch appears to be connected to pins #8 (TV mode/AV mode switch) and #16 (composite mode/RGB mode switch) of the SCART plug.
Edited by Zerosquare
There are no special circuits in Jag cables.
The official one is massively shielded and isolated, hence its girth.
What about that part?  Did it come with the OSSC or the vector labs breakout box, or did you have to make it/acquire it elsewhere?
I'm not clear why the vector labs one uses a Dsub9 instead of Dsub15/VGA connector in the first place.  Can't you wire the Atari RGB output up to a VGA monitor and have it more or less just work, or are they trying to save us from ourselves here?
Nope, unless your VGA monitor supports 15 kHz signals (and most of them don't).
Do you know of a pin out diagram for jag to VGA? I have a monitor that might do this.
Anyone know what connector the jag uses?
Hmm, interesting.  I found this pair of diagrams on google:
Jaguar to SCART:
http://mirrors.arcadecontrols.com/eviltim/eviltim/gamescart/gamescart.htm
SCART to VGA:
http://www.geocities.ws/podernixie/htpc/cables-en.html#scartvga
So you could work out a direct version from that.
I think I'd seen a direct wiring Jaguar -> VGA connector diagram (with warnings it doesn't give you an *actual* VGA signal, probably related to what @Zerosquare is saying here, and IIRC it was missing some pins/signals or something?  I was still ramping up and skimmed it pretty quickly at the time) in my initial binge of Jaguar googling a few months ago before I gave up and bought a CRT TV to play on, but I can't immediately find it again.
What I was curious about here was more or less the pin-out of that Dsub9 connector, to understand how it could be converted to VGA and/or if such a cable already exists.
