atrax27407 Posted May 8, 2020 Share Posted May 8, 2020 Fred's program is now up to Vn 7.1b and is available on his site. 8 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted May 9, 2020 Share Posted May 9, 2020 (edited) http://www.ti99-geek.nl/Projects/ti99dir/ti99dir.html#tidir search tag: ti99dir Edited May 9, 2020 by Schmitzi 5 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 11, 2020 Share Posted June 11, 2020 Feature request for TIDIR. I just did some "processing", and generated 3 x 48 sets of PC TXT files. These files need to be converted to DV80 files. I jus discovered I can highlight all the files, but only one file will be converted, not the whole batch. It would be nice to be able to process all the files at once rather than individually, especially since I have to use the drop down menu for how to handle the CR/LF characters. Beery 4 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 12, 2020 Share Posted June 12, 2020 http://endlos99.github.io/xdt99/#xdm99 I find this tool most useful for such things, and it can be scripted... a little text editor kung-fu and you have a script that will iterate all your files... Here is a typical session converting a native txt file, with CRLF to a TI DV80 file, hexdumps included so you can see the result... CRLF correctly removed... ➜ ~ hexdump -C blah.txt 00000000 48 45 4c 4c 4f 20 57 4f 52 4c 44 0d 0a 49 20 61 |HELLO WORLD..I a| 00000010 6d 20 61 20 66 69 6c 65 20 77 69 74 68 20 6c 6f |m a file with lo| 00000020 74 73 20 6f 66 20 74 65 78 74 20 69 6e 20 69 74 |ts of text in it| 00000030 2e 0d 0a 49 20 64 6f 6e 27 74 20 6b 6e 6f 77 20 |...I don't know | 00000040 77 68 61 74 20 6d 79 20 45 4f 4c 20 69 73 2e 2e |what my EOL is..| 00000050 0d 0a |..| 00000052 ➜ ~ xdm99.py -T blah.txt -t -f DV80 -n BLAH -o BLAH ➜ ~ hexdump -C BLAH 00000000 07 54 49 46 49 4c 45 53 00 01 80 03 4f 50 01 00 |.TIFILES....OP..| 00000010 42 4c 41 48 20 20 20 20 20 20 00 00 00 00 b3 5a |BLAH .....Z| 00000020 28 cb b3 5a 28 cb ff ff 20 20 20 20 20 20 20 20 |(..Z(... | 00000030 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 | | * 00000080 0b 48 45 4c 4c 4f 20 57 4f 52 4c 44 24 49 20 61 |.HELLO WORLD$I a| 00000090 6d 20 61 20 66 69 6c 65 20 77 69 74 68 20 6c 6f |m a file with lo| 000000a0 74 73 20 6f 66 20 74 65 78 74 20 69 6e 20 69 74 |ts of text in it| 000000b0 2e 1d 49 20 64 6f 6e 27 74 20 6b 6e 6f 77 20 77 |..I don't know w| 000000c0 68 61 74 20 6d 79 20 45 4f 4c 20 69 73 2e 2e ff |hat my EOL is...| 000000d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| * 00000180 -T says take a plain file, and create a FIAD, -t says use TIFILES format, -f says the TI disk storage mode should be DV80, -n names the file within the FIAD, -o names the file on your host filesystem Not to discount the feature request... just saying... 1 Quote Link to comment Share on other sites More sharing options...
F.G. Kaal Posted June 13, 2020 Share Posted June 13, 2020 On 6/11/2020 at 3:33 AM, BeeryMiller said: Feature request for TIDIR. I just did some "processing", and generated 3 x 48 sets of PC TXT files. These files need to be converted to DV80 files. I jus discovered I can highlight all the files, but only one file will be converted, not the whole batch. It would be nice to be able to process all the files at once rather than individually, especially since I have to use the drop down menu for how to handle the CR/LF characters. Beery I've made a note for this feature. Fred 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted June 15, 2020 Share Posted June 15, 2020 Fred, One other "slight" request to TIDIR. When viewing a file in hexadecimal, either a menu option to see the file including the header (perhaps as a new menu item in the drop down menu) or as a clickable option. Beery Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted June 15, 2020 Share Posted June 15, 2020 (edited) Dammit.mp4 I think I had this problem before, but I cannot remember what the solution was. HELP! Never mind, I figured it out. Edited June 15, 2020 by Omega-TI Update Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted June 15, 2020 Share Posted June 15, 2020 6 hours ago, BeeryMiller said: One other "slight" request to TIDIR. When viewing a file in hexadecimal, either a menu option to see the file including the header (perhaps as a new menu item in the drop down menu) or as a clickable option. How about a built-in hex editor as well? It's kind of nice to be able to see the EA/5's internals, but if we could use it to modify them too that would be useful. Quote Link to comment Share on other sites More sharing options...
F.G. Kaal Posted June 16, 2020 Share Posted June 16, 2020 23 hours ago, BeeryMiller said: Fred, One other "slight" request to TIDIR. When viewing a file in hexadecimal, either a menu option to see the file including the header (perhaps as a new menu item in the drop down menu) or as a clickable option. Beery Okay, also made a note of this. 4 Quote Link to comment Share on other sites More sharing options...
F.G. Kaal Posted July 6, 2020 Share Posted July 6, 2020 (edited) Ti99Dir v7.2a is available for download. - Conversion option for PC files to TI files is used for all selected files - Conversion option for TI files to PC files is used for all selected files of the same type also posible for all selected files - Conversion of PC files to DSK image and Cf7a+ or nanoPeb DSK image also posible for all selected files - Copying of PC files to a DSK image or Cf7a+ or nanoPeb DSK image also posible (jumps to conversion dialog in this case) Edited July 6, 2020 by F.G. Kaal - Header data of V9t9 or TIFILES is displayed in editor window when displayed in hex 6 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted July 8, 2020 Share Posted July 8, 2020 Fred, Thanks for the update. I got it up and working, and I really like the way you implemented the display of the header information. Much appreciated. I think you are also author of DM2K, and I would like to report I am able to use it with the TIPI and the Geneve in Rompage mode. What I did find was that I needed to access the TIPI as DSK0 and not as TIPI. Accessing it as DSK0, I was able to copy files to/from my WDS (Myarc HFDC). Beery Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted July 8, 2020 Author Share Posted July 8, 2020 Anyone else having problems getting the .chm files to display/print in this version? I'm using Windows 10 build 1909. Thanks Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted July 9, 2020 Author Share Posted July 9, 2020 (edited) I found and solved the problem!! Windows 10 blocks opening ,chm files because of the general risk involved in opening downloaded random .chm files. I right-clicked the file, opened properties and checked the "unblock" box. It now display/prints normally. Edited July 9, 2020 by atrax27407 3 Quote Link to comment Share on other sites More sharing options...
+9640News Posted December 26, 2020 Share Posted December 26, 2020 I'm using TIDIR V 7.2a. When I list some files I have on a TIPI, I see some files listed as 'tifiles', and others listed as "classic99". What is the difference between the two as they both show a TIFILES header with the hex editor. Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted December 26, 2020 Author Share Posted December 26, 2020 The current update is Vn 8.1a Quote Link to comment Share on other sites More sharing options...
+9640News Posted December 27, 2020 Share Posted December 27, 2020 I have TIDIR on several systems, and apparently that was one PC I had not updated. It is now updated. Either way, what is the difference between a tifiles header, and a tifiles header that TIDIR calls classic99? Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted December 27, 2020 Author Share Posted December 27, 2020 (edited) Based on an examination with a with a hex editor, it might be that the TIFILES header (in TIDir) is a single file while the PC99 file is an archived file with a TIFILES header. That is the conclusion I have reached based on my very limited sample. Edited December 27, 2020 by atrax27407 Quote Link to comment Share on other sites More sharing options...
+9640News Posted January 13, 2021 Share Posted January 13, 2021 I've got a request for something that I think may be along a minor tweak for TIDIR as I think the core routines are already present. I am testing Github as a repository for TI source files for assembly on a Geneve and/or TI-99/4A. Uploading files with TIFILES headers is not a problem, just the file can not be viewed on GitHub if someone wants to view the file. Please note these files are originating from a TIPI share but could just as easily original from a source file on a DSK or HDIMG file. It would be nice to convert a mass of directories of source files into text files at a second path with preservation of all TI formatting including tab spacing, that could then be uploaded to Github, and then if someone downloads files, those files could then be converted back to a D/V80 file with a TIFILES header maintaining the original format. I am not entirely sure if GitHub will default to a TXT viewer of the file if there is no extension of the filename, so that may be a requirement. I would also suggest that when reading the TIFILES header, if it detects a DIS/FIX 80 file or a Program Image file, it copies but treats those files as possible binary files with no file manipulation. From what I can tell, TIDIR has the capability, just a tad more involved. What I was hoping what could be done would be to have a GitHub option on the menu bar with two options, Convert for Upload, Convert back from Download. Then TIDIR would store the configuration parameters for file format (DIS/VAR 80) with the appropriate CR/LF requirements, without having to remember all the specific details. I think something along these lines would allow us to create more easily source file repositories for those individuals not using compilers and assemblers that use a .text format on other platform computers. Where I have also seen issues and I know there is not an easy solution, is on those other platforms, individuals have used the true tab character in their spacing that makes converting back to a clean and neat DIS/VAR 80 format for the TI more difficult as our editors treat the tab character differently than the way we may tab while programming. Thus, the first goal would be to handle a DIS/VAR 80 source file option for moving files around. I am looking for point click, highlight, select transfer option, watch and wait, and it is done. Beery Quote Link to comment Share on other sites More sharing options...
+hloberg Posted January 26, 2021 Share Posted January 26, 2021 FYI: My Windows Defender in Win10 has suddenly started blocking TIDIR memory access and marking it as an intrusion. This has the effect of not allowing TIDIR to make writes to CF7 and other disk types. Started after an update a few weeks ago. I had to go into the Defender settings and set TIDIR as OK to make memory changes. This is even with the intrusion settings set to LOW. Some PCs have notifications set OFF so it may not be showing on your PC but still screwing up TIDIR. If you get weird things happening in TIDIR you might want to check the Defender LOG and see if TIDIR is blocking memory access. Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted January 27, 2021 Author Share Posted January 27, 2021 I solved that problem. I disabled Defender and use another anti-virus program. 2 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted January 27, 2021 Share Posted January 27, 2021 I also solved all my other problems. I disabled Windows 10 and re-installed 8.1 2 Quote Link to comment Share on other sites More sharing options...
