Moe
Commodore 128 - 80 Columns w/OSSC
Hey everyone,
I just got a Commodore 128 last week, and I also ordered a OSSC about 2 weeks ago (I should receive it in a few weeks, I hope).
If I want to run my C128 in 80 column mode I need to use the RGBI output.  Can I connect the RBGI port, on the C128, directly to the VGA port on the OSSC?  Or do I need to use a CGA2RGB to convert the digital RBGI signal to analog, before feeding it into the OSSC's VGA port?  I have seen a few posts about doing this with a GBS-8200, but none using a OSSC.
Any information you might have will be greatly appreciated.
Cheers,
Moe
The RGBI uses TTL levels (nominally 5V, I believe). All documentation about the OSSC warns from connecting such signals directly, so you need a converter to make it analog RGB. I don't know about the CGA2RGB specifically, but if you are into soldering it is relatively easy to build a voltage divider per one of the SCART schematics online.
Thanks for the info!  The CGA2RGB can convert from RGBI to RGBs (https://gglabs.us/node/2063), and the OSSC can accept an RGBs signal.  I order a CGA2RGB to test with my C128 and OSSC.
Once I receive the CGA2RGB I'll update this topic with my results.
Cheers,
Moe
Moe, what was the final verdict?  I'm trying to attempt the same - CGA2RGBv2 / OSSC / C128 in 80-column mode.
Any settings you had to tweak on the OSSC?  Thanks!
Thanks for asking, it forced me to get back to it!
Yes, I was able to get 80 column mode working with the CGA2RGBv2 & OSSC.
CGA2RGBv2
DIP1 to DIP4 = off
Jumper J4 - pin 2-3
I created a USB 5V power cable to power the CGA2RGBv2, since the OSSC does not provide the power.
OSSC
AV3 - RGBHV
Cheers,
Moe
I was able to dramatically improve the picture of the CGA2RGBv2 & OSSC combination by doing a deep dive into the OSSC settings with help from VGP forum:
https://videogameperfection.com/forums/topic/commodore-128-cga2rgbv2/
Attached are some photos - it looks a lot better in person, for example none of the color fringing in the GEOS128 photo is present in person.
Settings I am using:
240p / Line2x
H. samplerate 1016
H. synclen 20
H. backporch 241
H. active 640
V. synclen 3
V. backport 36
V. active 200
Sampling Phase 11 degrees
Edited by djc6
