GDMike
Assembly code samples
I can't edit my last post, I can't upload a photo I Made. I'm rebooting my phone..one sec
Posted (edited)
Now I don't want to BL to this routine, but Im trying to figure out how to enter and keep my R4 alive.
So I'm stuck rt here at the moment..
Edited by GDMike
My super awesome random number generator!
First, you need to initialize the 9901 counter at the start of your application:
* Set up 9901 counter
       CLR  R12                        * CRU base of the TMS9901
       SBO  0                          * Enter timer mode
       LI   R1,>3FFF                   * Set counter
       INCT R12                        * Address of bit 1
       LDCR R1,14                      * Load value
       DECT R12
       SBZ  0                          * Exit clock mode, start decrementer
Then, the following routines will generate either a 16-bit word size random value, or any value from 0 to max-1. I've set them up to have their own workspace but you don't need to do this if you don't want to.
* Random number generator (Range in R3, Result in R4)
* Returns 0 to R3-1
RNDNUM DATA VWS,RAND2
RAND2  BL   @RNDGEN
       MOV  @>0006(R13),R3
       CLR  R4
       DIV  R3,R4
       MOV  R5,@>0008(R13)
       RTWP
* Random number generator 16-bit (Result in R4)
* returns 0-65535
RANDOM DATA VWS,RAND1
RAND1  BL   @RNDGEN
       MOV  R4,@>0008(R13)
       RTWP
* Random number generation
RNDGEN LI   R4,23729                   * Load with 15-bit value
       MPY  @RSEED,R4                  * Multiply by the random seed
       AI   R5,31871                   * Add a 15-bit value to the lower word
       STCR R0,15                      * Read current value (plus mode bit)
       SRL  R0,1                       * Get rid of mode bit
       SBZ  0                          * Exit clock mode, decrementer continues
       ANDI R0,>000F                   * Filter to 0-15
       JEQ  RNDGN1                     * If zero, skip
       SRC  R5,0                       * Rotate seed based on clock value
RNDGN1 MOV  R5,@RSEED                  * Copy back to RSEED
       RT
Posted (edited)
Fantastic!!! Now I see what I was hunting for..here
* returns 0-65535
Edited by GDMike
Posted (edited)
Where is that? Are you seeing double, double mr.Roboto
Robocall
But I have a million uses for that generator! Very very cool. Thank you!!
Edited by GDMike
Posted (edited)
Yup. If I do a BL @ search and a rt occurs, doesn't or won't that put me at SEARCH again?
Edited by GDMike
I'm just trying to line up the address in R4 with the word on the screen..
Posted (edited)
2 hours ago, GDMike said:
looking at LI R0, LI R1, LI R0, LI R1... you realize that the last two prevail?
Edited by HOME AUTOMATION
I was trying to make sure that my word that I'm searching for that I actually put on the screen wasn't being found later by the search program
All right I'm going to give you the code that I've got I keep coming up with a hit and I shouldn't be hitting
Posted (edited)
3 hours ago, GDMike said:
LIBAD7
SHP
S32P1
LBWRD  TEXT 'SEARCH'
             DATA 0  *These are the zeros that need to follow the search term!
SRCHF
oops ... had DATA 0, in the LABEL field!
Here's the updated code test
I'm putting an "A" at pos 0 on the screen if it's a bad search. If it's a good search, then I'm placing an asterisk on the word. I'm having to convert the address in R6 to the screen location. But I didn't have any luck, I tried inct in my loop and just a Inc but I always seem to place an asterisk at the position it shows now.
And I'm always hitting a positive search no matter what my search word is.
I can't see straight..I'm going to dream about getting a great result. I'll wake up and it'll hit me..or something will..
Posted (edited)
I changed my search word a couple times, first it was"SEARCH" and it was a positive hit, then changed to Mike, it too was a positive hit.
I wanted to make sure that I wasn't placing the search word into my copied screen page, as I thought that was happening. But I don't think it was.
Is it ok if I crash? At this moment im starting to screw with things and I'm messing it up. I'll read notes in a couple hours 😊😁
Edited by GDMike
15 minutes ago, GDMike said:
I explained this wrong...
LIBCLR was moving WORDs starting in ROM @>0000.
...Now it's just copying  the WORD @>0000, repeatedly.
anyhow... no need to do this.
