wfletcher3 Posted July 10, 2020 Share Posted July 10, 2020 I saw so many good things about stella and how much work you guys have put into it. I bought a retroN77. I read thru the user guide and very generic and based more for computer usage and keyboard.. I don't have an adapter to use a keyboard thru the micro power switch and funds are limited. As soon as I got it; upgraded it to 6.2.1 (formatted in Fat32 as stated for raspi) before running image. 1) In the ROM menu I do not see the bottom menu items (Select/Go UP/Options/Quit) 2) I can bring up the advanced menu, but cannot adjust the screen size after selecting vertical size. How do I do this? This screen is not in current stella user manual. 3) I cannot open cartridges. How do I do this? 4) How do I download from my cartridges and can I overwrite ones I downloaded from the web? 5) Will these changes be saved when game shut down? 6) Asked in another thread; but adding here incase. How do I set up paddles? Sorry about so many questions; not a programmer, not a big gamer; but an old gamer and I can follow directions. And this may lead to other functionality questions later (sorry ? ). I do promise though to help other newbees when they join. I'll even document everything for the retroN77 if someone would want it. Thnx again up front!!! w- Quote Link to comment Share on other sites More sharing options...
fluxit Posted July 12, 2020 Share Posted July 12, 2020 (edited) On 7/10/2020 at 1:30 PM, wfletcher3 said: 1) In the ROM menu I do not see the bottom menu items (Select/Go UP/Options/Quit) The Retron's launcher is simplified as it doesn't have a mouse(or an OS UI to return to.) On 7/10/2020 at 1:30 PM, wfletcher3 said: 2) I can bring up the advanced menu, but cannot adjust the screen size after selecting vertical size. How do I do this? This screen is not in current stella user manual. Some of these changes will not be seen until the Retron has been turned off. Also, left/right to navigate, up/down changes options, fire for check-boxes and buttons. On 7/10/2020 at 1:30 PM, wfletcher3 said: 3) I cannot open cartridges. How do I do this? Physical cartridges? They should just work when plugged in(or not- if the particular game can't be successfully dumped via the cart slot.) On 7/10/2020 at 1:30 PM, wfletcher3 said: 4) How do I download from my cartridges and can I overwrite ones I downloaded from the web? This isn't currently supported, at least not in a straightforward manner directly on the Retron 77. On 7/10/2020 at 1:30 PM, wfletcher3 said: 5) Will these changes be saved when game shut down? Probably. Which changes? On 7/10/2020 at 1:30 PM, wfletcher3 said: 6) Asked in another thread; but adding here incase. How do I set up paddles? Assuming the game supports them, they shouldn't require any setup if they are up to the R77's 'standards.' Edited July 12, 2020 by fluxit additional information added Quote Link to comment Share on other sites More sharing options...
