Randy Posted August 10, 2020 Share Posted August 10, 2020 Hi all, looking for a good date and clock program that displays the current date and time on the desktop as well as tags the files as they are created/copied/moved/etc. I do have a Tadiran battery as well as the UltraSatan built-in clock, would there be a preference when using the Mega STe? The 4160 STe of course would have to use the US RTC. Thanks! Quote Link to comment Share on other sites More sharing options...
Zogging Hell Posted August 10, 2020 Share Posted August 10, 2020 Hi Randy, if the computer has the time set the time/ date stamp on files should happen automatically so shouldn't be a problem. For a clock on the desktop you will probably need to search what we called back then 'Public Domain' (Freeware) stuff, it will probably be a desktop accessory. If you trawl through the Floppyshop archive you should find something (search for clock or time in the utilities section) https://exxoshost.co.uk/atari/PDL/FLOPPYSHOP/index.htm Just be aware the seemingly best choices which place the clock in the top right hand bit of the desktop menu can clash with some programs, so you might want to go for one that displays the clock in a window. 1 Quote Link to comment Share on other sites More sharing options...
snarkdluG Posted August 10, 2020 Share Posted August 10, 2020 For a clock in the corner of the screen, try Clocky. For setting TOS time with UltraSatan use RealTimeClockTool by Jookie. 1 Quote Link to comment Share on other sites More sharing options...
Randy Posted August 10, 2020 Author Share Posted August 10, 2020 Thanks guys, I'll give these a try! Quote Link to comment Share on other sites More sharing options...
