ATRMNT
TGB1718
How does this work, no matter what I try it just responds with:-
139 Device NAK
or
Usage: ATRMNT [/B] [/U] ? ATRNAME[.AT
R]
/B: Make boot drive
/U: Unmount drive
There doesn't seem to be a MAN page with any examples
I have FATFS loaded and can see all the .ATR files on the designated drive.
Just a working example would be great
The version of ATRMNT on the most recently released toolkit disk appears to work fine.
Don't forget you have to specify the target drive specification as the first parameter, separately from any FAT drive spec you provide in front of the ATR name. The test I just ran here mounted an ATR on drive H: as drive A:.
ATRMNT A: H:TEST.ATR
30 minutes ago, TGB1718 said:
I used the kit on the latest Incognito download
I don't think ATRMNT appears on any of the ROMs; the copy on the APT Toolkit ATR is common to all firmware targets.
Firmware 3.10 tightened up DSTATS checking and revealed some sloppy values in older versions of the tools, so it's possible that using an older version of ATRMNT would cause the exact issue you're seeing.
