BillDMatt Posted August 25, 2020 Share Posted August 25, 2020 Has anyone tried to sync a Flashback 8 wireless joystick to the 9 Gold ? My 9 gold wireless joystick is working ok but it seems to have a little lag especially compared to my FB 8 Gold. I would like to swap joysticks since I use my 9 more often because of the SD card. I tried but no luck. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
boggis the cat Posted September 20, 2020 Share Posted September 20, 2020 They’re not compatible, unfortunately. The joysticks seem to come ‘locked’ to certain frequencies, so you may find that another device is interfering with it. I got a second FB9 for my sister, and found that her P1 was terrible on her system. Swapped it for the P1 that came with mine, and it worked much better. (Slight degradation for the swapped P1 on my system, but I prefer the old wired joysticks anyway.) Quote Link to comment Share on other sites More sharing options...
BillDMatt Posted September 30, 2020 Author Share Posted September 30, 2020 On 9/20/2020 at 3:45 AM, boggis the cat said: They’re not compatible, unfortunately. The joysticks seem to come ‘locked’ to certain frequencies, so you may find that another device is interfering with it. I got a second FB9 for my sister, and found that her P1 was terrible on her system. Swapped it for the P1 that came with mine, and it worked much better. (Slight degradation for the swapped P1 on my system, but I prefer the old wired joysticks anyway.) ok thanks for the reply , makes sense. I'm thinking either buying a wired one and see how that works out. Thanks again. Quote Link to comment Share on other sites More sharing options...
