Poison
Reharden question
Posted (edited)
Hi, I would like to ask if is possible to create xex which can be run from real floppy. I do not mean boot floppy and run xex :) Because demo takes, cca 50kb ? I think and atr format takes full floppy which can be used for next demos :)
http://a8.fandal.cz/detail.php?files_id=7487
thank you
poison
Edited by Poison
Unsure.  Generally full ATR demo disks just do raw sector reads with no regard to a standard Dos structure.
Even if it is a Dos structure, the problem can become the fact that most of memory gets used and a loader or Dos gets overwritten.
An alternative can be systems that load an entire disk image into Ram then emulate a disk drive, though in the case of this demo you'd likely want a 128K Ram machine.
Posted (edited)
I found somewhere this xex, which works with emulator. But does not work on real HW from floppy with dos or qmeg or AVG cart.
Reharden.xex
Edited by Poison
this demo uses xBIOS (ATR), there is a standard FS, xB doesn't impose any restrictions on the characters used in the directory, and that's been used in this demo.
This is chckxex of the exe file:
001:     $0200 $02A4: $00A5
002:     $02E2 $02E3: $0002
     INI $0200
003:     $0200 $020F: $0010
004:     $02D8 $02DF: $0008
005:     $030F $03A5: $0097
006:     $040F $041E: $0010
007:     $043F $04A5: $0067
008:     $0626 $0635: $0010
009:     $0800 $27F0: $1FF1
010:     $2800 $67FF: $4000
011:     $6800 $8184: $1985
012:     $849F $84F0: $0052
013:     $8659 $89C1: $0369
014:     $9000 $9026: $0027
015:     $9043 $94C5: $0483
016:     $9500 $9C7F: $0780
017:     $9CD6 $B25F: $158A
018:     $B263 $B64E: $03EC
019:     $B800 $CE33: $1634
020:     $CE36 $CFCA: $0195
021:     $DF07 $F2C5: $13BF
022:     $F882 $F8BF: $003E
023:     $F900 $F9BF: $00C0
024:     $FA00 $FF0A: $050B
025:     $D800 $DF00: $0701
026:     $02E0 $02E1: $0002
     RUN $9DB6
027:     $0015 $0015: $0001
028:     $0018 $0019: $0002
File 'C:\Users\msimecek\Downloads\Reharden.xex' is OK.
checkxex clearly shows there are blocks 001-009 that are loading into low mem areas including 009 where DOS is usually placed.
So this xex is for emulator only, however if you would play with SuperPacker , you could merge and pack these blocks and place it to load at the end, depack and run. - that could make it feasible for realhw (resp. running from DOS).
I just realized there are also blocks storing data under osrom... so it would not be that easy, because DOS is utilizing osrom for i/o calls.
And can be some easy solution such as repack this file to higher address ? The same thing which was done with some text games which starts on 0700 and were unrunable with AVG ?
Posted (edited)
8 minutes ago, matosimi said:
Not that easy, but possible... But at what cost?
When we will meet on Forever Party I will buy you One Beer :) or Two ?
Edited by Poison
You can .. you know .. report it to AVG cart author ? 😉
Iam not sure if I can.
But This is not problem of AVG. This xex cant be run from real floppy from DOS or Qmeg.
Edited by Poison
Load Xex will usually work fine in emulators because that option typically injects the segments into Ram without there being any loader needed or present beforehand.
Real hardware doesn't do this - about the closest you can get for such a "protected" situation is from the likes of IDE+ which have Rom based loaders that only need a little bit of Ram workspace to survive.
Well,
Reharden was released at Silly Venture 2017, so it can be found on the Silly Pack 2k17 by JAC! as a fileversion. Quoting JAC: "* Reharden - Now runs from DOS 2.5, packed 58K to 37K"
Silly Pack 2k17
EDIT: Added 90k bootable ATR, XEX fileversion and textfile...
Reharden.zip
Hmmm, now reading the topic about Silly Pack 2k17 again, I notice there is the "We plash" demo-movie by Nir Dary on it that originally requires an SIDE-2 with CF card -  it is available as an image file. Could this demo-movie run from an AVG cart as well (e.g. when changing the extender into .AVF) ?!? Is it PAL compatible ?
45 minutes ago, CharlieChaplin said:
Well,
Silly Pack 2k17
Hehe, so I'd say Poison owes me two beers 🙂 And believe me, that is cheap considering the 2 months time frame it took to fix it...
  • Like 5
  • Haha 2
There's two things I absolutely love - your Silly Packs, and your coding tutorials using WUDSN.  Well, I love WUDSN to death as well so make that three.  Could you be persuaded to perhaps do a coding tutorial of sorts, on the making of a Silly Pack?
Works Great, just tested :) Thanks to @JAC! and @CharlieChaplin very much :)
...and to answer my own question: We plash works fine from AVG cart., if you have a PAL system and rename *.IMG into *.AVF. It's a short but very nice video by Nir Dary from Israel for Silly Venture 2017.
I saw it only on YT, i do not know where to download this file. it is not on pouet, atarionline pl and google do not know too :)
It is in the Silly Pack 2k17, see link above (post #12) or use this direct link: http://www.wudsn.com/productions/atari800/sillypack2k17/sillypack2k17.zip
Download the whole pack and unzip SillyPack2k17-Weplash.img (approx. 62MB), then rename to e.g. Weplash.AVF and copy it onto your AVG cart.
