+acadiel #1 Posted October 11, 2020 Let’s make a thread for technical info as we get it, including: Joystick Pinout Expansion Connector Pinout Cartridge Pinout Memory map PDFs of any technical documentation (BASIC commands for assembly, etc.) It would be great to get a list going in a documentation thread with all known games and scans of the PDF manuals, including the user manuals. Lots of these systems come with no manuals, and these don’t seem to be readily available anywhere. Here’s a good start we will need to translate thanks to @tanam1972: http://www43.tok2.com/home/cmpslv/index.htm 1 Quote Share this post Link to post Share on other sites
+retroclouds #2 Posted October 12, 2020 Should probably be able to find a lot of details in emulator source code. Quote Share this post Link to post Share on other sites
wierd_w #3 Posted October 12, 2020 Here is the expansion port. Joystick port: Cassette Cable 3 Quote Share this post Link to post Share on other sites
tanam1972 #4 Posted October 12, 2020 Common Source Code Project http://takeda-toshiya.my.coocan.jp/pyuta/index.html 3 Quote Share this post Link to post Share on other sites
+acadiel #5 Posted October 12, 2020 Here's an English translation of http://www43.tok2.com/home/cmpslv/Pyuuta/EnrPt.htm - attached as PDF. Below are all the pictures from the PDF. CPU: System Rom: I/O: Keyboard and Joystick: Keyboard Matrix: TP1101 Joystick: Sound: VDP: Connector pinouts: 64K cart diagram: Enri's Home PAGE (TP1000).pdf 5 Quote Share this post Link to post Share on other sites
mizapf #6 Posted October 12, 2020 Also have a look at Raphael Nabet's work in MAME: https://github.com/mamedev/mame/blob/master/src/mame/drivers/tutor.cpp 3 Quote Share this post Link to post Share on other sites
+acadiel #7 Posted October 20, 2020 Here's an older page of @tanam1972 https://tms9918.hatenablog.com/entry/2018/05/15/110023 Technical information on his game adapter: https://tms9918.hatenablog.com/entry/2018/12/15/142407 A game adapter that allows you to run 32KB ROMs, etc. in the expansion slot of the first Pyuta. If you write the BIOS to 27C512 on the ROM writer, it will be upgraded to mk2. Pyuta It is not available in Jr/mk2. It is only for the first generation Pyuta. 1: The second half of 27C512 (8000-FFFF) 2: First half of 27C512 (0000-7FFF) 16: BIOS valid range (0000-3FFF) 32: BIOS valid range (0000-7FFF) KILL: Disables the main BIOS and enables the BIOS written to 27C512 Cartridging G-BASIC Games: https://tms9918.hatenablog.com/entry/2018/02/12/234003 TMS9918 program: https://tms9918.hatenablog.com/entry/2016/01/17/000815 Try connecting the RAM & ROM cartridge to Pyuta's expansion slot Part 6: https://tms9918.hatenablog.com/entry/2018/01/18/211846 There is a lot more on his blog. @tanam1972 - Can you please post some of your best article links? Thanks! Quote Share this post Link to post Share on other sites
kl99 #8 Posted October 22, 2020 here is one documentation of getting RGB out on Tomy Pyuta devices, partely using F18A https://sions-papa.blogspot.com/2012/10/tms9918rgb.html 1 Quote Share this post Link to post Share on other sites
+acadiel #9 Posted November 5, 2020 I adapted @jedimatt42's pinout from his picture into an actual pinout for the joysticks. This is looking at a DB9 female that would plug into the unit, with pin #1 top left, pin #5 top right, #6 bottom left, #9 bottom right. Note, all six pins that aren't ground (L/R/U/D/BT1/BT2) need 1N614 diodes with the cathode pointing to the controller side. ------------------------------ \ 1 2 3 4 5 / \ 6 7 8 9 / ------------------------- GND P1 GND P2 Button 1 Button 2 Down Left Up Right N/C I might have some of these backward, but will post pictures of the adapter that I made. 1 Quote Share this post Link to post Share on other sites
+acadiel #10 Posted November 7, 2020 From Tanam: --- Internal ROM images IPL.ROM $0000-$7FFF BASIC.ROM $8000-$BFFF (if exists) --- Cart ROM images Cart ROM is mapped to $8000-$BFFF or $4000-$BFFF Quote Share this post Link to post Share on other sites
+acadiel #11 Posted November 10, 2020 Amazing how little current the Tutor draws. Quote Share this post Link to post Share on other sites
speccery #12 Posted November 11, 2020 Just now discovered this thread. Since there are schematics above, it seems there is all the necessary information to make FPGA version of the Tutor. I've built a TMS9995 system on breadboard in the past, but it's been a few years ago. It's mind-blowing how they just copied the TI-99/4A. Still no proper CPU RAM (sigh). Notably in the schematics VDP_CS is in the same address for both reads and writes, since the TMS9995 does not perform a read operation before each write, unlike the TMS9900. The TI-99/4A places VDP read and write ports to different address in order to avoid problems with these reads to write ports. Quote Share this post Link to post Share on other sites
+acadiel #13 Posted November 12, 2020 18 hours ago, speccery said: Just now discovered this thread. Since there are schematics above, it seems there is all the necessary information to make FPGA version of the Tutor. I've built a TMS9995 system on breadboard in the past, but it's been a few years ago. It's mind-blowing how they just copied the TI-99/4A. Still no proper CPU RAM (sigh). Notably in the schematics VDP_CS is in the same address for both reads and writes, since the TMS9995 does not perform a read operation before each write, unlike the TMS9900. The TI-99/4A places VDP read and write ports to different address in order to avoid problems with these reads to write ports. If you want minimal, check out the Jr layout. Wow! (From Cameron’s site) 1 Quote Share this post Link to post Share on other sites
speccery #14 Posted November 12, 2020 30 minutes ago, acadiel said: If you want minimal, check out the Jr layout. Wow! (From Cameron’s site) Thanks! Considering that there are 8 DRAM chips for the VDP, they really have simplified it! It appears they've removed the keyboard interface and probably some other things too. Could you share the URL as well? Quote Share this post Link to post Share on other sites
+acadiel #15 Posted November 12, 2020 1 hour ago, speccery said: Thanks! Considering that there are 8 DRAM chips for the VDP, they really have simplified it! It appears they've removed the keyboard interface and probably some other things too. Could you share the URL as well? Yep, his Jr. Site is here: https://www.floodgap.com/retrobits/tomy/pyuuta/pyuutajr.html A hardware question for you - instead of eight 16k x 1 bit chips, how easy is it to replace with one 16k x 8 chip? What would the wiring look like? Or something like this - but can it be made simpler? https://www.yumpu.com/en/document/read/46927596/sram-replacement-for-tms99x8-vram Quote Share this post Link to post Share on other sites
speccery #16 Posted November 12, 2020 38 minutes ago, acadiel said: Yep, his Jr. Site is here: https://www.floodgap.com/retrobits/tomy/pyuuta/pyuutajr.html A hardware question for you - instead of eight 16k x 1 bit chips, how easy is it to replace with one 16k x 8 chip? What would the wiring look like? Or something like this - but can it be made simpler? https://www.yumpu.com/en/document/read/46927596/sram-replacement-for-tms99x8-vram Thanks for the link! There are no 16k*8 DRAM chips. I suppose the closest would be to use two 64k*4 DRAM chips (4464 DRAMs). This would provide 64K of VRAM, of which 16K would be used, the highest address line would need to be a constant. I am not 100% if the DRAM refresh would work in this case though. I've seen the circuit you referred to before, for example here is something similar: https://www.tindie.com/products/mfkamprath/tms9918a-video-card-kit-for-rc2014/ It could be simplified by integrating all the logic into one CPLD, for example XC9572XL could do the job, then you'd have the 9918, CPLD and SRAM. The whole VDP+VRAM can be contained also in one FPGA, like I have done for example in my ICY99 project. But if one wants to retain the original TMS9918 (or TMS9928) then I think the lowest chip count is with the CPLD+SRAM solution. Thinking about it, if one wanted to use the original TMS9918 and TMS9995 - and it would be acceptable to use a CPLD, I think the Jr could be reduced five chips: TMS9995, TMS9918, SRAM for VRAM, ROM and a CPLD for everything else. hmmm... this would be a fun project to do! Although I would add one more SRAM to provide RAM for the TMS9995. And I do have all of this chips already at hand. hmmmm.... 3 Quote Share this post Link to post Share on other sites
+retroclouds #17 Posted November 12, 2020 Some further pictures on the Jr. can be found here 1 Quote Share this post Link to post Share on other sites
+acadiel #18 Posted November 15, 2020 @tanam1972 cartridge information website: https://tms9918.hatenablog.com/entry/2018/01/18/211846 Try connecting a RAM & ROM cartridge to the expansion slot of Tutor Part 6 I thought about how to connect 16KB RAM (CXK58257P-10L) and 24KB ROM (27C256) to the cartridge slot of Pyuta / Jr / mk2. The Tomy Tutor / mk2 in 16KB RAM (6000-7FFF / C000-DFFF ), the Jr 8KB RAM (6000-7FFF) was used. Please use the sample programs (16KB RAMTEST, TINY BASIC, PITFALL !, TI SCRAMBLE) here. http://www.geocities.jp/parallel_computer_inc/pyuta16kram.zip @tanam1972(the above link is dead, unfortunately.) Address A0 A1 A2 | /CE RAM /CE2 A14 A13 ROM >0000 0 0 0 | 1 1 - - >2000 0 0 1 | 1 1 - - >4000 0 1 0 | 1 0 1 0 >4000 >6000 0 1 1 | 0 >6000 1 - - >8000 1 0 0 | 1 0 0 0 >0000 >A000 1 0 1 | 1 0 0 1 >2000 >C000 1 1 0 | 0 >4000 1 - - >E000 1 1 1 | 1 1 - - Equations for the GAL: ; ; PYUTA16KRAM.EQN - PYUTA2 RAM&ROM CARTRIDGE ; TITLE PYUTA2 RAM&ROM CARTRIDGE PATTERN A REVISION 1.0 AUTHOR TANAM1972 COMPANY PARALLEL COMPUTER INC DATE 1/20/18 CHIP PYUTA2 GAL22V10 NC A2 A1 A0 NC NC NC NC NC NC NC GND NC CE_n CE2_n SELEXM A14 A13 NC NC NC NC NC VCC EQUATIONS CE_n = A0 * /A1 + A0 * A2 + /A0 * /A1 + /A0 * /A2 + /A1 + /A1 * A2 + /A1*/A2 CE2_n =/A0 * /A1 + /A0 * A2 + A1 * A0 + A1 * A2 SELEXM = /A0 * A1 + /A1 * A0 + /A2 * A0 + /A2 * A1 A14 = A1 A13 = A2 I tried to post from the circuit diagram of US TUTOR. http://www.floodgap.com/retrobits/tomy/ioport.gif It is said that the SELEX M signal (MEMORY) of the expansion slot operates in US TUTOR. For mk2, the RAM & ROM cartridge operated in the cartridge slot instead of the expansion slot. http://www43.tok2.com/home/cmpslv/Pyuuta/EnrPt.htm PYUTA(mk2) PIN 1 GND(0V) PIN 2 GND(0V) PIN 3 D7 PIN 4 /INT1 PIN 5 D6 PIN 6 /HOLD(GND) PIN 7 D5 PIN 8 A15 PIN 9 D4 PIN10 A13 PIN11 D3 PIN12 A12 PIN13 D2 PIN14 A11 PIN15 D1 PIN16 A10 PIN17 D0 PIN18 A9 PIN19 /IOPORT(/E000) PIN20 A8 PIN21 /MEMEN PIN22 A7 PIN23 A14 PIN24 A3 PIN25 A2 PIN26 A6 PIN27 /READY PIN28 A5 PIN29 /DBIN PIN30 A4 PIN31 /WE PIN32 A1 PIN33 /INT4 PIN34 A0 PIN35 SELEXM(MEMORY) PIN36 ROMCLK(/0000) PIN37 /RESET PIN38 /EXP0(GROM SEL) PIN39 /EXP1(GROM CLK) PIN40 /EXP2(VDP) PIN41 /EXP3(SOUND) PIN42 /EXM00(/0000) PIN43 /EXM40(/4000) PIN44 /EXM80(/8000) PIN45 /EXMC0(/C000) PIN46 CLKOUT PIN47 LAQ(/CRUIN) PIN48 KILLROM(-5V) PIN49 VCC(+5V) PIN50 VCC(+5V) Quote Share this post Link to post Share on other sites
Mobsie #19 Posted November 15, 2020 from this .zip file is the ramtest i used to test my mame patch Quote Share this post Link to post Share on other sites
jens-eike #20 Posted November 15, 2020 On 11/12/2020 at 4:32 PM, acadiel said: A hardware question for you - instead of eight 16k x 1 bit chips, how easy is it to replace with one 16k x 8 chip? What would the wiring look like? with a TMS9118 it would be only two TMS4416 RAMs (16k*4) Quote Share this post Link to post Share on other sites
+acadiel #21 Posted November 27, 2020 Made an Atari Style joystick adapter - put six 1N914 diodes for the four directional and two buttons. The unused pin 6 (or 9, depending on how you look at the female connector) I hooked up to SL2, for when I mod a joypad to use two fire buttons. 1 Quote Share this post Link to post Share on other sites
Mobsie #22 Posted November 30, 2020 Hi, I never was a hardware guy, only did some very small stuff, but I know want to learn this also. So I want to know how is the address decoding done on the cartridge port of the tutor (not the expansion port). In the cartridge port the RAM / ROM card from tanam work and you got the rom and also ram at c000. How they did it because the upper adress lines (a0 and a1 , means a14 and a15) are missing on this port? I ask tanam and he confirm me that it works. And what the following in the GAL chip did? ; ; PYUTA16KRAM.EQN - PYUTA2 RAM&ROM CARTRIDGE ; TITLE PYUTA2 RAM&ROM CARTRIDGE PATTERN A REVISION 1.0 AUTHOR TANAM1972 COMPANY PARALLEL COMPUTER INC DATE 1/20/18 CHIP PYUTA2 GAL22V10 NC A2 A1 A0 NC NC NC NC NC NC NC GND NC CE_n CE2_n SELEXM A14 A13 NC NC NC NC NC VCC EQUATIONS CE_n = A0 * /A1 + A0 * A2 + /A0 * /A1 + /A0 * /A2 + /A1 + /A1 * A2 + /A1*/A2 CE2_n =/A0 * /A1 + /A0 * A2 + A1 * A0 + A1 * A2 SELEXM = /A0 * A1 + /A1 * A0 + /A2 * A0 + /A2 * A1 A14 = A1 A13 = A2 Sorry for so much stupid questions, but maybe someone can explain me. Quote Share this post Link to post Share on other sites
+acadiel #23 Posted January 25 We probably need to do some reconciliation on the external printout. There are three that I've found in this thread: Enri's: http://www43.tok2.com/home/cmpslv/Pyuuta/EnrPt.htm Printer: https://www.floodgap.com/retrobits/tomy/iprinter.pdf.zip Typed tutor: And three different pinouts: Pin Tutor (printer) Tutor (typed) Pyuuta (Enri) 1 GND GND GND 2 GND GND GND 3 D0 (LSB) D7 4 D0 INT1/ INT1/ 5 D1 D6 6 D1 GND HOLD/ 7 D2 D5 8 D2 A0 A15/CRUOUT 9 D3 D4 10 D3 A2 A13 11 D4 D3 12 D4 A3 A12 13 A4 D5 D2 14 D5 A4 A11 15 A5 D6 D1 16 D6 A5 A10 17 A6 D7 (msb) D0 18 D7 A6 A9 19 E000/ (external) IOPORT/ 20 A7 A8 21 MEMEN/ MEMEN/ 22 A8 A7 23 A12 A1 A14 24 A12 A3 25 A9 A13 A2 26 A13 A9 A6 27 A10 READY/ READY 28 A10 A5 29 A11 DBIN/ DBIN/ 30 DBIN A11 A4 31 A14 WE/ WE/CPUCLK/ 32 WE A14 A1 33 A15 INT4/ (internal) INT4/ EC/ 34 A15/ (msb) A0 35 MEMORY (internal) SELEXM 36 0000-3FFF/ ROMCLK 37 RESET RESET/ 38 GROM SEL E4XX/ ext EXP0/ 39 GROM CLK EXP1/ 40 VDP/ EXP2/ 41 SOUND/ EXP3/ 42 0000-3FFF/ ext EXM00/ 43 4000-7FFF/ ext EXM40/ 44 8000-BFFF/ ext EM80/ 45 C000-FFFF/ ext EXMC0/ 46 CPUCLK OUT CLKOUT 47 CRUIN/ LAQHOLDA 48 Vbb (-5V) Vbb (-5V) KILL SROM/ 49 Vcc Vcc Vcc 50 Vcc Vcc Vcc Quote Share this post Link to post Share on other sites
+Ksarul #24 Posted January 25 Look carefully and you will see a pattern in the pin differences: in the first two, it looks like the printer is reversing even and odd pins everywhere except at the beginning and at the end. If you look at Enri's list, it looks like he is using standard pin descriptions for teh bits, instead of the inverted nomenclature TI uses. Those changes to the first and third chart eliminate a lot of the differences. . . 1 Quote Share this post Link to post Share on other sites
+acadiel #25 Posted January 31 On 1/25/2021 at 6:38 PM, Ksarul said: Look carefully and you will see a pattern in the pin differences: in the first two, it looks like the printer is reversing even and odd pins everywhere except at the beginning and at the end. If you look at Enri's list, it looks like he is using standard pin descriptions for teh bits, instead of the inverted nomenclature TI uses. Those changes to the first and third chart eliminate a lot of the differences. . . OK, If I flip every two in the first column, they do line up with the second one. And, if I reverse the numbering of the address lines and data bits, the second column and third column substantially line up. We just need to figure out the other important differences now. (Like the KILL SROM pin on the Pyuuta that's Vbb on the Tutor.) Pin Printer Tutor Pyuuta (Enri) 1 GND GND GND 2 GND GND GND 3 D0 D0 (LSB) D0 (D7) 4 INT1/ INT1/ 5 D1 D1 D1 (D6) 6 GND HOLD/ 7 D2 D2 D2 (D5) 8 A0 A0/CRUOUT (A15) 9 D3 D3 D3 (D4) 10 A2 A2 (A13) 11 D4 D4 D4 (D3) 12 A3 A3 (A12) 13 D5 D5 D5 (D2) 14 A4 A4 A4 (A11) 15 D6 D6 D6 (D1) 16 A5 A5 A5 (A10) 17 D7 D7 (msb) D7 (D0) 18 A6 A6 A6 (A9) 19 E000/(external) IOPORT/ 20 A7 A7 (A8) 21 MEMEN/ MEMEN/ 22 A8 A8 (A7) 23 A1 A1 (A14) 24 A12 A12 A12 (A3) 25 A13 A13 A13 (A2) 26 A9 A9 A9 (A6) 27 READY/ READY 28 A10 A10 A10 (A5) 29 DBIN DBIN/ DBIN/ 30 A11 A11 A11 (A4) 31 WE WE/ WE/CPUCLK/ 32 A14 A14 A14 (A1) 33 INT4/(internal) INT4/ EC/ 34 A15 A15/(msb) A15 (A0) 35 MEMORY(internal)SELEXM 36 0000-3FFF/ ROMCLK 37 RESET RESET/ 38 GROM SEL E4XX/ EXP0/ 39 GROM CLK EXP1/ 40 VDP/ EXP2/ 41 SOUND/ EXP3/ 42 0000-3FFF/ ext EXM00/ 43 4000-7FFF/ ext EXM40/ 44 8000-BFFF/ ext EM80/ 45 C000-FFFF/ ext EXMC0/ 46 CPUCLK OUT CLKOUT 47 CRUIN/ LAQHOLDA 48 Vbb(-5V)Vbb(-5V) KILL SROM/ 49 Vcc Vcc Vcc 50 Vcc Vcc Vcc Quote Share this post Link to post Share on other sites
