seastalker Posted October 12, 2020 Share Posted October 12, 2020 (edited) I have a Sega Saturn model 2 and have had a heck of a time trying to deal with the open/closed tray sensitivity. I've opened the Saturn's case, fine tuned the tray open/shut switch that triggers the on screen message, and even de-soldered and re-soldered the switch back in place. I have fine tuned and pitch perfect bent the metal as if I am trying to pick up a 1970s 'naughty' channel with precision direction of components. I cleaned and sanded the little copper strips in the switch and still had hit and miss functionality. Then I looked at the design of this tiny switch and thought it was crap. I love Sega, but this switch is the pits. I took the transparent plastic tip off of it so the nano-milometer of YES/NO connectivity had a much wider range and presto! It finally works as it should! Ironically, I have a MODE on the way and won't need the functionality anymore but still, I thought this fix may help others with this really annoying problem on the Sega Saturn. Edited October 12, 2020 by seastalker Quote Link to comment Share on other sites More sharing options...
