mozzwald #1 Posted November 8, 2020 This thread will get posts when a new firmware update is available from https://fujinet.online/download so that you may subscribe and get notifications if you wish. Please keep replies to a minimum (none is preferable) as to not overload notifications to those subscribing. You can use the other appropriate threads for questions relating to firmware/hardware/troubleshooting/etc. A new firmware update is available at https://fujinet.online/download Notable new features: Ability to save application configuration information on SD card (Device $70, SIO commands $DB-$DE) for use by developers writing new Atari applications. Used by the latest weather app from @bocianu Modem Sniffer 5 Quote Share this post Link to post Share on other sites
mozzwald #2 Posted November 14, 2020 A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.ce7a9391 Version Date/Time: 2020-11-14 01:43:21 Build Date/Time: Sat Nov 14 02:43:44 UTC 2020 New features: Ability for device slots to have their read/write modes toggled in CONFIG (R and W keys) MOUNT and BOOT in CONFIG now unmounts CONFIG from D1: Can now press OPTION or B to boot from CONFIG Bug Fixes CONFIG no longer tries to mount and EMPTY host slot if selected Modem sniffer turned off by default Fix MAC address display to show leading zeros New FujiNet SIO Commands ($70): $DA - Get Device Slot Filename https://github.com/FujiNetWIFI/fujinet-platformio/wiki/SIO-Command-$DA-Get-Device-Slot-Filename $D9 - Toggle CONFIG disk on/off in D1: https://github.com/FujiNetWIFI/fujinet-platformio/wiki/SIO-Command-%24D9-Enable-Disable-CONFIG-in-D1 1 Quote Share this post Link to post Share on other sites
mozzwald #3 Posted November 15, 2020 A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.52c0a446 Version Date/Time: 2020-11-15 18:26:23 Build Date/Time: Sun Nov 15 18:50:57 UTC 2020 New Features: R: / Modem telnet support ATNET1 command to enable telnet AT+TERM=<DUMB,VT52,VT100,ANSI> command to set term type IceT XE telnet to a linux box, running 'htop': Option to disable CONFIG boot disk from web interface (for SDX users) 4 Quote Share this post Link to post Share on other sites
jamm #4 Posted November 15, 2020 This seems like it should be pinned. 1 Quote Share this post Link to post Share on other sites
Stguild #5 Posted November 20, 2020 Is there a way to get older firmware so I can go back to a older one if I want to? Quote Share this post Link to post Share on other sites
tschak909 #6 Posted November 20, 2020 13 minutes ago, Stguild said: Is there a way to get older firmware so I can go back to a older one if I want to? Currently not as a binary, you can pull an older commit, and compile in VS.CODE, the bring-up instructions are in the wiki. -Thom Quote Share this post Link to post Share on other sites
Stguild #7 Posted November 20, 2020 23 minutes ago, tschak909 said: Currently not as a binary, you can pull an older commit, and compile in VS.CODE, the bring-up instructions are in the wiki. -Thom I am sorry I do not know how to do ANY of that. Quote Share this post Link to post Share on other sites
+DrVenkman #8 Posted November 20, 2020 Please heed @mozzwald's request and stop posting in this thread. There are likely dozens if not hundred of people with this thread on Notification so we don't miss update notices. Perhaps @Albert or another moderator could lock it to all except mozzwald's notifications? 1 Quote Share this post Link to post Share on other sites
KPeter #9 Posted November 21, 2020 The firmware update at https://fujinet.online/download is infected by URL:Blacklist ... Please, verify! Peter Quote Share this post Link to post Share on other sites
tschak909 #10 Posted November 22, 2020 21 hours ago, KPeter said: The firmware update at https://fujinet.online/download is infected by URL:Blacklist ... Please, verify! Peter false positive. We have appealed. Thanks for letting us know. -Thom 1 Quote Share this post Link to post Share on other sites
mozzwald #11 Posted December 7, 2020 A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.d7586b80 Version Date/Time: 2020-12-05 20:18:46 Build Date/Time: Mon Dec 7 04:28:35 UTC 2020 Notable Bits: Additional fonts for Epson printer emulation & other various printer fixes fixes for cassette emulation tcp/ip tweaks for better modem emulation. ATASCII BBSs now work, but can freeze up (still investigating) Increase RAM to fix some ATX loading issues 4 Quote Share this post Link to post Share on other sites
mozzwald #12 Posted December 14, 2020 A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.8d1a6210 Version Date/Time: 2020-12-14 03:53:18 Build Date/Time: Mon Dec 14 18:29:19 UTC 2020 Memorable changes: * Altirra based ATASCII BBSs now work thanks to @JohnPolka * Cassette images can now be mounted to slot 8 in config. Selection of a CAS file automagically puts it in D8 5 1 Quote Share this post Link to post Share on other sites
mozzwald #13 Posted December 19, 2020 A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.8edf468d Version Date/Time: 2020-12-19 04:49:28 Build Date/Time: Sat Dec 19 05:48:26 UTC 2020 Fanciful Fixes: * BIG BUGFIX: double density disks (ATR) now calculate correct sector offset * Modem: auto-answer can now happen during status * Modem: add RAUTOANS tool to enable/disable auto answer * Modem: Type 1 poll changed to 16 tries, from 26, handler loading now reliably works. * Modem: Backspacing too far no longer crashes modem in command mode (@mleair) * Modem: CRX now updated when somebody connects 1 Quote Share this post Link to post Share on other sites
KPeter #14 Posted December 19, 2020 10 hours ago, mozzwald said: A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.8edf468d Version Date/Time: 2020-12-19 04:49:28 Build Date/Time: Sat Dec 19 05:48:26 UTC 2020 Fanciful Fixes: * BIG BUGFIX: double density disks (ATR) now calculate correct sector offset * Modem: auto-answer can now happen during status * Modem: add RAUTOANS tool to enable/disable auto answer * Modem: Type 1 poll changed to 16 tries, from 26, handler loading now reliably works. * Modem: Backspacing too far no longer crashes modem in command mode (@mleair) * Modem: CRX now updated when somebody connects I updated my FujiNet today. Unfortunately it does not work. With version before I could start it from SpartaDOS X - of course, with no success, but after that went back to the SDX command line. Now ATARI freezes, just Reset can restart it. Still I am waiting for extending of characters to the special, like | . I saw C code modification day, after I reported this issue a month ago, but this correction is still not in updates (at least in 2 next after my report). Again: If my password includes | character it works like EOL or some text separator in the password. Characters after this are interpreted like file name ... Please, correct this character issue. To change password in my home's network system is a big issue for its complexity and number of attached equipment on wifi ... So, the only way to extend the character-set accepted by the password on FujiNet. Thanks you, Peter Quote Share this post Link to post Share on other sites
+DrVenkman #15 Posted December 19, 2020 PLEASE DO NOT POST COMMENTS IN THIS THREAD! There are probably hundreds of people who have notifications turned on so we see @mozzwald’s posts - comment in another thread or start a new one! 1 2 Quote Share this post Link to post Share on other sites
mozzwald #16 Posted December 19, 2020 2 hours ago, KPeter said: Still I am waiting for extending of characters to the special, like | . A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.8edf468d Version Date/Time: 2020-12-19 04:49:28 Build Date/Time: Sat Dec 19 19:09:59 UTC 2020 The only change is to FujiNet CONFIG: * increase inputtable characters again because some people have ~ and | and { } Please do not respond to this thread. If you have an issue, start a new post in the FujiNet subforum, open an issue on the github tracker or ask for assistance in Discord chat. 2 1 Quote Share this post Link to post Share on other sites
mozzwald #17 Posted December 26, 2020 A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.8edf468d Version Date/Time: 2020-12-19 04:49:28 Build Date/Time: Sat Dec 26 23:37:44 UTC 2020 Unbelievable Upgrades: * Host & Disk slots shown in Web admin page * Disable WiFi Power Saving for better latency Please do not respond to this thread. If you have an issue, start a new post in the FujiNet subforum, open an issue on the github tracker or ask for assistance in Discord chat. 4 Quote Share this post Link to post Share on other sites
mozzwald #18 Posted December 27, 2020 A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.fe08a639 Version Date/Time: 2020-12-27 21:07:58 Build Date/Time: Sun Dec 27 21:27:27 UTC 2020 Fancy New Features: * Can now skip WiFi setup in CONFIG * Disengage CONFIG disk if READ happens before STATUS is completed (meaning something else has responded to D1:) Please do not respond to this thread. If you have an issue, start a new post in the FujiNet subforum, open an issue on the github tracker or ask for assistance in Discord chat. Quote Share this post Link to post Share on other sites
mozzwald #19 Posted January 16 A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.e09997c5 Version Date/Time: 2021-01-16 02:23:59 Build Date/Time: Sat Jan 16 23:27:52 UTC 2021 New Stuff For You: * Web UI: now shows working path & filename for mounts * Web UI: new rewind button for CAS files. After CSAVE you can rewind cassette to the beginning for playback * Modem bugfix: increase delay for loading handler * SIO2BT: state is saved in config file. If BT is enabled it will startup in SIO2BT mode (Feature request by @MrFSL) Please do not respond to this thread. If you have an issue, start a new post in the FujiNet subforum, open an issue on the github tracker or ask for assistance in Discord chat. 2 2 Quote Share this post Link to post Share on other sites
mozzwald #20 Posted January 19 A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.bec03534 Version Date/Time: 2021-01-18 22:12:42 Build Date/Time: Tue Jan 19 19:12:09 UTC 2021 Extravagant Enhancements: * N: Firmware rewrite now merged in (FTP not working yet). Thanks @tschak909! * CP/M support, more info here: https://github.com/FujiNetWIFI/fujinet-platformio/wiki/CP-M-Support Thanks @tschak909! * Added phonebook support to the MODEM. Phonebook saved to config file. Thanks @manterola! * Key clicks disabled in CONFIG Please do not respond to this thread. If you have an issue, start a new post in the FujiNet subforum, open an issue on the github tracker or ask for assistance in Discord chat. 5 2 Quote Share this post Link to post Share on other sites
mozzwald #21 Posted January 22 A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.7d4cf107 Version Date/Time: 2021-01-21 23:30:55 Build Date/Time: Fri Jan 22 00:43:13 UTC 2021 Fabulous Features: * Added SIO set PROCEED timer rate command to N: * Removed debugger from CPM * Started adding BDOS CP/M commands for N: * CPM I/O speed improvements Please do not respond to this thread. If you have an issue, start a new post in the FujiNet subforum, open an issue on the github tracker or ask for assistance in Discord chat. 2 1 Quote Share this post Link to post Share on other sites
mozzwald #22 Posted January 25 A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.e6b3e94e Version Date/Time: 2021-01-22 01:42:35 Build Date/Time: Mon Jan 25 02:25:21 UTC 2021 Crazy Config Changes: * Once you have saved your Wifi credentials, CONFIG will skip the first scan/connect at startup. (ESP32 will automatically connect during bootup) * If Wifi is not connected when CONFIG starts, it will attempt to connect to the saved AP and re-scan if it cannot connect * Selector bar is now green or red. Green means Wifi connected, Red is not connected * If you are not connected to Wifi and you choose a TNFS server in the host list you are taken to the Wifi scan screen Please do not respond to this thread. If you have an issue, start a new post in the FujiNet subforum, open an issue on the github tracker or ask for assistance in Discord chat. Quote Share this post Link to post Share on other sites
mozzwald #23 Posted February 7 A new firmware update is available at https://fujinet.online/download Unimaginable Upgrades: * By popular demand, Config can now copy files from one host slot to another * Bluetooth Device name, baudrate and enable at boot options added to fnConfig.ini * Atari COMMAND assertion will break FujiNet out of MIDIMaze mode if active * SDMMC to SDSPI fixes for latest Espressif IDF/PlatformIO updates Please do not respond to this thread. If you have an issue, start a new post in the FujiNet subforum, open an issue on the github tracker or ask for assistance in Discord chat. 2 2 Quote Share this post Link to post Share on other sites
mozzwald #24 Posted February 21 A new firmware update is available at https://fujinet.online/download FujiNet Version: 0.5.fa579e3f Version Date/Time: 2021-02-13 19:34:11 Build Date/Time: Sun Feb 21 00:49:34 UTC 2021 Distinguished Developments: * UART2 FIFO Fix so soft RESET works properly * Aggressive memory leak fixes for TCP * BBS support for CP/M (BDOS functions to support BYE.COM in fujinet-cpm-tools) * Tons of N: HTTP work. * Set MODEM default baud rate to 300 baud * Lots of little Modem bugs squashed. * update AT? (AT help) command for MODEM * MODEM STATUS changes so FoReM 850 can operate Please do not respond to this thread. If you have an issue, start a new post in the FujiNet subforum, open an issue on the github tracker or ask for assistance in Discord chat. 1 Quote Share this post Link to post Share on other sites
mozzwald #25 Posted February 21 Also, the FujiNet-Flasher has been upgraded to use the latest esptool v3.0 if you want to download it. It is not necessary to upgrade, the previous flasher will continue to work. 1 Quote Share this post Link to post Share on other sites
